path: root/scripts/get_default_envs.sh
2020-05-06scripts/get_default_envs.sh: preserve order of multiple entries for same ↵Rasmus Villemoes
variable It's possible that the default_environment[] array contains multiple entries for the same variable, e.g. a setting from env_default.h based on some CONFIG_* variable, and another from CONFIG_EXTRA_ENV_SETTINGS. In such a case, the last setting takes effect. Hence, in order to be able to use the output from this script as an CONFIG_DEFAULT_ENV_FILE and get the same default environment as one currently has, we need to preserve the order. So only sort by the variable name, and disable the last-resort comparison. We could pipe the result through uniq to remove duplicate lines, but I think there's some value in seeing that certain variables are defined multiple times. Signed-off-by: Rasmus Villemoes <rasmus.villemoes@prevas.dk> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-06-07script: Make get_default_envs.sh script exclude tools/envSeung-Woo Kim
If building envtools, there is env directory in tools directory. Mafe the get_default_envs.sh script exclude tools/env directory. Signed-off-by: Seung-Woo Kim <sw0312.kim@samsung.com>
2018-02-20script: Make the get_default_envs.sh script working with newest u-bootLukasz Majewski
This commit fixes several issues: - After moving env related code to ./env directory the env_common.o file is no longer present in the system (has been replaced with built-in.o). - Use ${OBJCOPY} if available, fallback to system default's objcopy if not present. - Extend the script to accept different build directory than current one. It is extremely handy with OE usage, where source code is separated from build. Signed-off-by: Lukasz Majewski <lukma@denx.de> Tested-by: Alex Kiernan <alex.kiernan@gmail.com>
2016-10-06scripts: Add script to extract default environmentLukasz Majewski
This script looks for env_common.o object file and extracts from it default u-boot environment, which is afterwards printed on standard output. Usage example: get_default_envs.sh > u-boot-env-default.txt The generated text file can be used as input for mkenvimage. Signed-off-by: Lukasz Majewski <l.majewski@majess.pl> Reviewed-by: Simon Glass <sjg@chromium.org>
