At present the tests assume that gawk is being used. Adjust the tests so
that the names are inserted in alphabetical order, so that awk is happy.
Also use PROCINFO to make gawk output in alphabetical order. This is not
ideal, since it changes the env-car ordering from what the user provided,
but it may be acceptable.
Reported-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
Fixes: https://source.denx.de/u-boot/u-boot/-/issues/10
GNU has a very useful third argument to match() but this is not supported
in the POSIX awk.
Update the code to cope, so that the script is POSIX-compliant.
Tested-by: Mark Kettenis <mark.kettenis@xs4all.nl>
At present U-Boot environment variables, and thus scripts, are defined
by CONFIG_EXTRA_ENV_SETTINGS. It is painful to add large amounts of text
to this file and dealing with quoting and newlines is harder than it
should be. It would be better if we could just type the script into a
text file and have it included by U-Boot.
Add a feature that brings in a .env file associated with the board
config, if present. To use it, create a file in a board/<vendor>
directory, typically called <board>.env and controlled by the
CONFIG_ENV_SOURCE_FILE option.
The environment variables should be of the form "var=value". Values can
extend to multiple lines. See the README under 'Environment Variables:'
for more information and an example.
In many cases environment variables need access to the U-Boot CONFIG
variables to select different options. Enable this so that the environment
scripts can be as useful as the ones currently in the board config files.
This uses the C preprocessor, means that comments can be included in the
environment using /* ... */
Also support += to allow variables to be appended to. This is needed when
using the preprocessor.
Reviewed-by: Marek BehĂșn <marek.behun@nic.cz>
Tested-by: Marek BehĂșn <marek.behun@nic.cz>
