path: root/scripts/dtc/libfdt/fdt_rw.c
2018-05-31scripts/dtc: Update to upstream version v1.4.6-9-gaadd0b65c987Rob Herring
This adds the following commits from upstream: aadd0b65c987 checks: centralize printing of property names in failure messages 88960e398907 checks: centralize printing of node path in check_msg f1879e1a50eb Add limited read-only support for older (V2 and V3) device tree to libfdt. 37dea76e9700 srcpos: drop special handling of tab 65893da4aee0 libfdt: overlay: Add missing license 962a45ca034d Avoid installing pylibfdt when dependencies are missing cd6ea1b2bea6 Makefile: Split INSTALL out into INSTALL_{PROGRAM,LIB,DATA,SCRIPT} 51b3a16338df Makefile.tests: Add LIBDL make(1) variable for portability sake 333d533a8f4d Attempt to auto-detect stat(1) being used if not given proper invocation e54388015af1 dtc: Bump version to v1.4.6 a1fe86f380cb fdtoverlay: Switch from using alloca to malloc c8d5472de3ff tests: Improve compatibility with other platforms c81d389a10cc checks: add chosen node checks e671852042a7 checks: add aliases node checks d0c44ebe3f42 checks: check for #{size,address}-cells without child nodes 18a3d84bb802 checks: add string list check for *-names properties 8fe94fd6f19f checks: add string list check 6c5730819604 checks: add a string check for 'label' property a384191eba09 checks: fix sound-dai phandle with arg property check b260c4f610c0 Fix ambiguous grammar for devicetree rule fe667e382bac tests: Add some basic tests for the pci_bridge checks 7975f6422260 Fix widespread incorrect use of strneq(), replace with new strprefixeq() fca296445eab Add strstarts() helper function cc392f089007 tests: Check non-matching cases for fdt_node_check_compatible() bba26a5291c8 livetree: avoid assertion of orphan phandles with overlays c8f8194d76cc implement strnlen for systems that need it c8b38f65fdec libfdt: Remove leading underscores from identifiers 3b62fdaebfe5 Remove leading underscores from identifiers 2d45d1c5c65e Replace FDT_VERSION() with stringify() 2e6fe5a107b5 Fix some errors in comments b0ae9e4b0ceb tests: Correct warning in sw_tree1.c Commit c8b38f65fdec upstream ("libfdt: Remove leading underscores from identifiers") changed the multiple inclusion define protection, so the kernel's libfdt_env.h needs the corresponding update. Signed-off-by: Rob Herring <robh@kernel.org> [ Linux commit: 9130ba884640328bb78aaa4840e5ddf06ccafb1c ] [erosca: - Fixup conflicts in include/linux/libfdt_env.h caused by v2018.03-rc4 commit b08c8c487083 ("libfdt: move headers to <linux/libfdt.h> and <linux/libfdt_env.h>") - Fix build errors in lib/libfdt/fdt_ro.c, tools/libfdt/fdt_rw.c by: - s/_fdt_mem_rsv/fdt_mem_rsv_/ - s/_fdt_offset_ptr/fdt_offset_ptr_/ - s/_fdt_check_node_offset/fdt_check_node_offset_/ - s/_fdt_check_prop_offset/fdt_check_prop_offset_/ - s/_fdt_find_add_string/fdt_find_add_string_/] Signed-off-by: Eugeniu Rosca <erosca@de.adit-jv.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-09-23scripts/dtc: Update to upstream version v1.4.4-50-gfe50bd1ecc1dTom Rini
This adds the following commits from upstream: fe50bd1ecc1d fdtget: Split out cell list display into a new function 62d812308d11 README: Add a note about test_tree1.dts 5bed86aee9e8 pylibfdt: Add support for fdt_subnode_offset() 46f31b65b3b3 pylibfdt: Add support for fdt_node_offset_by_phandle() a3ae43723687 pylibfdt: Add support for fdt_parent_offset() a198af80344c pylibfdt: Add support for fdt_get_phandle() b9eba92ea50f tests: Return a failure code when any tests fail 155faf6cc209 pylibfdt: Use local pylibfdt module 50e5cd07f325 pylibfdt: Add a test for use of uint32_t ab78860f09f5 pylibfdt: Add stdint include to fix uint32_t 36f511fb1113 tests: Add stacked overlay tests on fdtoverlay 1bb00655d3e5 fdt: Allow stacked overlays phandle references a33c2247ac8d Introduce fdt_setprop_placeholder() method 0016f8c2aa32 dtc: change default phandles to ePAPR style instead of both e3b9a9588a35 tests: fdtoverlay unit test 42409146f2db fdtoverlay: A tool that applies overlays aae22722fc8d manual: Document missing options 13ce6e1c2fc4 dtc: fix sprintf() format string error, again d990b8013889 Makefile: Fix build on MSYS2 and Cygwin 51f56dedf8ea Clean up shared library compile/link options 21a2bc896e3d Suppress expected error message in fdtdump test 2a42b14d0d03 dtc: check.c fix compile error a10cb3c818d3 Fix get_node_by_path string equality check 548aea2c436a fdtdump: Discourage use of fdtdump c2258841a785 fdtdump: Fix over-zealous version check 9067ee4be0e6 Fix a few whitespace and style nits e56f2b07be38 pylibfdt: Use setup.py to build the swig file 896f1c133265 pylibfdt: Use Makefile constructs to implement NO_PYTHON 90db6d9989ca pylibfdt: Allow setup.py to operate stand-alone e20d9658cd8f Add Coverity Scan support b04a2cf08862 pylibfdt: Fix code style in setup.py 1c5170d3a466 pylibfdt: Rename libfdt.swig to libfdt.i 580a9f6c2880 Add a libfdt function to write a property placeholder ab15256d8d02 pylibfdt: Use the call function to simplify the Makefile 9f2e3a3a1f19 pylibfdt: Use the correct libfdt version in the module e91c652af215 pylibfdt: Enable installation of Python module 8a892fd85d94 pylibfdt: Allow building to be disabled 741cdff85d3e .travis.yml: Add builds with and without Python library prerequisites 14c4171f4f9a pylibfdt: Use package_dir to set the package directory 89a5062ab231 pylibfdt: Use environment to pass C flags and files 4e0e0d049757 pylibfdt: Allow pkg-config to be supplied in the environment 6afd7d9688f5 Correct typo: s/pylibgfdt/pylibfdt/ 756ffc4f52f6 Build pylibfdt as part of the normal build process 8cb3896358e9 Adjust libfdt.h to work with swig b40aa8359aff Mention pylibfdt in the documentation 12cfb740cc76 Add tests for pylibfdt 50f250701631 Add an initial Python library for libfdt cdbb2b6c7a3a checks: Warn on node name unit-addresses with '0x' or leading 0s 4c15d5da17cc checks: Add bus checks for simple-bus buses 33c3985226d3 checks: Add bus checks for PCI buses Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-23scripts/dtc: Update to upstream version v1.4.3Tom Rini
Using the update-dtc-source.sh script from Linux v4.14-rc1 import the portions of dtc that we require. We bring in update-dtc-source.sh and scripts/dtc/Makefile from Linux v4.14-rc1. Rework DTC_FLAGS handling to not require a test. Signed-off-by: Tom Rini <trini@konsulko.com>
