Set MCR0 RXCLKSRC to 1 to enable DQS loopback from pad to support
higher frequency.
Signed-off-by: Ye Li <ye.li@nxp.com>
Add support for AIY 2GB DDR size. Wrap support for
3GB DDR board with CONFIG_AIY_LPDDR4_3G because of
the limited ocram size.
Test: build and boot on 2GB AIY board.
Change-Id: I04da60cc0d0b22c6c32ff705bcab4095068ba6ea
Signed-off-by: Ji Luo <ji.luo@nxp.com>
Config the memory size of evk_imx8mm to 1GB.
Change-Id: I8f605a099b4f825c2ded6326c5209b52b5ba3925
mx7ulp EVK B will use two mipi dsi panels, the new panel RM68200_WXGA
supports WXGA resolution.
Open configs to enable dual bootloader feature for
imx8q Android Auto.
Test: Build and boot on imx8q.
Change-Id: I99da2ee6b87efd201e16df1046188ae86cab1466
camera sometime can't been open once run M4 image.
ISI-CH0 probe funtion is not called when meet issue.
The root cause is:
M4 image set assign resource SC_R_ISI_CH0 into m4 partition
when open camera in m4 side.
Uboot will call update_fdt_with_owned_resources to check the pd
in current dts node. it will call sc_rm_is_resource_owned to
check the pd whether in other partition, If yes, it will delete
the dts node. uboot delete isi_0 node whose pd is SC_R_ISI_CH0.
Change-Id: I4e2afbed2c55caad0a9f804fa8d85511c3bfea38
Signed-off-by: zhang sanshan <sanshan.zhang@nxp.com>
config 'CONFIG_FSL_CAAM_KB' was added to Kconfig and would
be selected for imx6/imx7/imx8m(if has caam), remove the
defination in header file to fix redefination errors.
Test: build pass for imx6dq, imx6sx, imx6sl and imx7ulp.
Change-Id: I5ccf1e9747613b66f20eacf15f126a80054b3441
Signed-off-by: Luo Ji <ji.luo@nxp.com>
Add a mipi dsi panel driver for RM67191 panel which is attached to mipi dsi
controller.
(cherry picked from commit 01e116ccd2e2705be3fb427da74cb19bab7ab4e0)
Update the mipi_dsi_northwest driver to implement mipi dsi bridge interfaces
and register it as a bridge controller. Users can call bridge common interfaces
to access the northwest driver, don't need to call its private driver functions.
We also add a kconfig entry for this driver, the name is changed to
CONFIG_IMX_NORTHWEST_MIPI_DSI
(cherry picked from commit a668cdb1ef5bcef4a574640f5c06ff07520254df)
We can get the bootimage SD/MMC offset at runtime according to the SOC type and
version. No need to use CONFIG_BOOTLOADER_OFFSET_33K and CONFIG_BOOTLOADER_OFFSET_32K
any longer, so remove them.
(cherry picked from commit 63af66f27c2c1b836c6dd48eb9901d622007e4a4)
Move common mfgtools config into this config files.
Signed-off-by: Frank Li <Frank.Li@nxp.com>
Porting the FSL android fastboot features from imx u-boot v2017.03 to
support all SoCs: imx6/imx7/imx7ulp/imx8/imx8m
Add fsl_fspi driver for flexspi controller. This driver supports:
1. DDR Quad output
2. Prefetch function for improve read performance.
3. Fast read and Quad read for one line read mode.
4. Read flash FSR register.
5. DM.
Signed-off-by: Han Xu <han.xu@nxp.com>
(cherry picked from commit ae4e80b7b0debd2ad868781aaeb28ca4f2d9a8aa)
- one lane pcie gen2 link is okay, the cfg space
of the rc/ep can be accessed.
rc cfg base 0x5f00_0000. ep cfg base 0x6000_0000
- limit to gen2 speed
- mask the wait of eq3 finish, because it is used
for gen3.
- use pcie_ctrla_init_rc() to do the initialization
of the pciea controller
- setup the common pcie codes in pcie_imx8x.c, separate
the different soc speicifed initialization codes into
their own pcie/board codes, move the macro definitions
into the new header file imx8_hsio.h.
- i.MX8QXP only have PCIe Control B. Enable PORT B at default.
i.MX8QM needs to set CONFIG_IMX_PCIEB to enable PORT B.
- Disable the LTSSM when link is down.
Signed-off-by: Richard Zhu <hongxing.zhu@nxp.com>
Signed-off-by: Shenwei Wang <shenwei.wang@nxp.com>
(cherry picked from commit 03141c2b955ce6034f06e701126aea1493dc2b4b)
Add the mipi dsi panel driver for device HX8363 from kernel. The panel
driver needs work with mipi_dsi_northwest driver.
(cherry picked from commit 0c6d0f4202bae7f61d38ecff1c9d255261f022f2)
(cherry picked from commit d65bbb0585a906072f01a2d72169be0b13b1d9b8)
Add the host driver base from kernel for MIPI DSI controller on i.MX7ULP.
The controller provides a DPI-2 interface for LCDIF video stream, and a APB interface
for packet transmission.
The driver provides APIs to register a MIPI panel device and its driver. The panel
driver can use the write packet function provided by the host driver to send control
packets to panel device via APB interface.
MIPI DSI has its PHY and dedicated PLL. The driver will setup them when enabling the DSI
host.
(cherry picked from commit e02115dd1c5d36ec06eabcb5a0b8e09aaf0f29a0)
(cherry picked from commit 1e984bba8cd961daa4c5bf994a6a90a72cc2f114)
Add emmc support which needs board rework.
Add I2C2.
Update DM PMIC settings and LDO bypass support.
Add BMODE support.
Add LVDS and LCD splash screen support
Add PCI power and reset GPIO and disable PCI at default.
Update QSPI settings for QSPI boot and M4 fastup.
Update environment settings
The i.MX6SL EVK needs this driver in android fastboot support. Add
this driver to u-boot.
To use the driver, user must define:
CONFIG_MXC_KPD Enable the driver
CONFIG_MXC_KEYMAPPING Key mapping matrix
CONFIG_MXC_KPD_COLMAX The column size of key mapping matrix
CONFIG_MXC_KPD_ROWMAX The row size of the key mapping matrix
(cherry picked from commit 5096e572667ff41217deb4ba9b1bd15e93fa6b59)
(cherry picked from commit e84160eaf5c057da45a227039c6f8a7911f43a82)
Add gis module, current gis is support vadc input.
Add power down function to lcdif driver.
Signed-off-by: Sandor Yu <R01008@freescale.com>
Signed-off-by: Ye.Li <B37916@freescale.com>
(cherry picked from commit a007b00dd8ef9f773dfdebef0b1deb0990281793)
(cherry picked from commit a31dcdafb0963381e7213c59f79a340ef27ec2e2)
(cherry picked from commit 02dfe2e4af5f51d39a51542fb0e81f93faf505bc)
(cherry picked from commit a8e94954d8ccc44c41d77a5e356d6a99b3d45649)
The following config symbols are only defined once and never referenced
anywhere else:
CONFIG_AT91SAM9263EK
CONFIG_AT91SAM9RLEK
CONFIG_BARIX_IPAM390
CONFIG_BOARD_H2200
CONFIG_EP9301
CONFIG_KZM_A9_GT
CONFIG_PICOSAM
CONFIG_PLATINUM_PICON
CONFIG_PLATINUM_TITANIUM
CONFIG_PM9261
CONFIG_PM9263
CONFIG_PM9G45
CONFIG_SIEMENS_DRACO
CONFIG_SIEMENS_PXM2
CONFIG_SIEMENS_RUT
CONFIG_SMDKC100
CONFIG_SMDKV310
CONFIG_STM32F4DISCOVERY
Most of them are config symbols named after the respective boards which
seems to have been a standard practice at some point.
anywhere else:
CONFIG_ARM926EJS
CONFIG_CPUAT91
CONFIG_EXYNOS5800
CONFIG_SYS_CORTEX_R4
Most of them are config symbols named after the respective SoCs which
anywhere else:
CONFIG_DBAU1X00
CONFIG_PB1X00
Tidy up CONFIG_SYS_BOOTCOUNT_SINGLEWORD from the whitelist as there's
no remaining uses of it left.
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Convert CONFIG_BOOTCOUNT_ALEN to Kconfig
CONFIG_BOOTCOUNT_I2C
Reviewed-by: Lukasz Majewski <lukma@denx.de>
CONFIG_BOOTCOUNT_RAM
CONFIG_BOOTCOUNT_ENV
CONFIG_BOOTCOUNT_AM33XX
Reviewed-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
CONFIG_BOOTCOUNT was only used in mx53ppd, merge it with
CONFIG_BOOTCOUNT_LIMIT
Reviewed-by: Ian Ray <ian.ray@ge.com>
CONFIG_BOOTP_BOOTPATH
CONFIG_BOOTP_DNS
CONFIG_BOOTP_GATEWAY
CONFIG_BOOTP_HOSTNAME
CONFIG_BOOTP_PXE
CONFIG_BOOTP_SUBNETMASK
CONFIG_CMDLINE_EDITING
CONFIG_AUTO_COMPLETE
CONFIG_SYS_LONGHELP
CONFIG_SUPPORT_RAW_INITRD
CONFIG_ENV_VARS_UBOOT_CONFIG
[trini: Re-run the migration]
U-Boot pulled in several core makefiles from Linux. The following
are not used in U-Boot:
- CONFIG_DEBUG_SECTION_MISMATCH
- CONFIG_FTRACE_MCOUNT_RECORD
- CONFIG_GCOV_KERNEL
- CONFIG_GCOV_PROFILE_ALL
- CONFIG_KASAN
- CONFIG_MODVERSIONS
We can remove the unused code if we like. (although it will get the
scripts out of sync)
CONFIG_BOOM and CONFIG_HIS_DRIVER are just mentioned in the comment
block of scripts/basic/fixdep.c
CONFIG_SHELL is not configuration, but a variable for internal-use.
It is just a historical misnomer in Kbuild.
ll_temac driver was used by Xilinx Microblaze big endian and
Xilinx ppc405/ppc440 SoCs.
ppc support was removed by: "powerpc: remove 4xx support"
(sha1: 98f705c9cefdfdba62c069821bbba10273a0a8ed)
and Microblaze BE is not tested for a long time that's why this driver
can be removed because none is going to updated it to DM anyway.
Migrate the option CONFIG_SPL_FRAMEWORK and make this gate most of the
current set of options we have in Kconfig. We will need to have some
options available for SPL and !SPL_FRAMEWORK so this is important. In a
few cases we re-order existing options so that we have less escapes from
the SPL_FRAMEWORK guard.
The option CONFIG_SPL_MMC_MINIMAL is unused in code, drop it.
Convert the CONFIG_UPDATE_TFTP and related symbols to Kconfig.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
config_fallbacks.h had some logic to automatically select
LIB_RAND if RANDOM_UUID or CMD_UUID were set if LIB_HW_RAND wasn't
already selected. By migrating LIB_HW_RAND to Kconfig, we can
remove this check from config_fallbacks.h and put it into Kconfig
[trini: Turn into a choice, add NET_RANDOM_ETHADDR]
CONFIG_APBH_DMA
CONFIG_APBH_DMA_BURST
CONFIG_APBH_DMA_BURST8
Reviewed-by: Stefan Agner <stefan.agner@toradex.com>
[trini: Add in MMC as well]
The motivation for moving MX28 selection to Kconfig is to be able
to better handle NAND MXS selection through Kconfig.
This selection method also aligns with the way other i.MX SoCs are
selected in U-Boot.
The motivation for moving MX23 selection to Kconfig is to be able
selected in U-Boot.
CONFIG_MXC_GPIO
