path: root/scripts/checkpatch.pl
2016-10-06Various, accumulated typos collected from around the tree.Robert P. J. Day
Fix various misspellings of: * deprecated * partition * preceding,preceded * preparation * its versus it's * export * existing * scenario * redundant * remaining * value * architecture Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Reviewed-by: Jagan Teki <jteki@openedev.com> Reviewed-by: Stefan Roese <sr@denx.de>
2016-01-04checkpatch: fix left brace warningHeiko Schocher
using checkpatch with Perl 5.22.0 generates a warning, this is fixed in linux through commit: commit 4e5d56bdf892e18832a6540b63ebf709966bce2a Author: Eddie Kovsky <ewk@edkovsky.org> Date: Wed Sep 9 15:37:52 2015 -0700 checkpatch: fix left brace warning Using checkpatch.pl with Perl 5.22.0 generates the following warning: Unescaped left brace in regex is deprecated, passed through in regex; This patch fixes the warnings by escaping occurrences of the left brace inside the regular expression. Adapt it for U-Boot. Signed-off-by: Heiko Schocher <hs@denx.de>
2014-09-25checkpatch: remove unnecessary + after {8,8}Joe Perches
Pick the following commit from Linux kernel: commit 66cb4ee0e52ca721f609fd5eec16187189ae5fda Author: Joe Perches <joe@perches.com> Date: Wed Sep 10 09:40:47 2014 +1000 checkpatch: remove unnecessary + after {8,8} There's a useless "+" use that needs to be removed as perl 5.20 emits a "Useless use of greediness modifier '+'" message each time it's hit. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@ti.com>
2014-03-04scripts: update checkpatch.pl to latest upstream versionTom Rini
Update to v3.14-rc4's version of checkpatch.pl. In doing so we drop the changes to top_of_kernel_tree() as we pass in --no-tree and drop our changes about MAINTAINERS as that's for reporting checkpatch.pl problems itself (and upstream has said they'll reword this section to be clearer). Signed-off-by: Tom Rini <trini@ti.com>
2014-02-26checkpatch.pl: Add warning for new __packed additionsTom Rini
While there are valid reasons to use __packed, often the answer is that you should be doing something else here instead. Signed-off-by: Tom Rini <trini@ti.com>
2013-12-13Makefile: Move some scripts imported from LinuxMasahiro Yamada
We have some scripts imported from Linux Kernel: setlocalversion, checkstack.pl, checkpatch.pl, cleanpatch They are located under tools/ directory in U-Boot now. But they were originally located under scripts/ directory in Linux Kernel. This commit moves them to the original location. It is true that binutils-version.sh and dtc-version.sh do not originate in Linux Kernel, but they should be moved by analogy to gcc-version.sh. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
