path: root/scripts/checkpatch.pl
2018-04-10checkpatch.pl: update from Linux kernel v4.16Heinrich Schuchardt
Update scripts/checkpatch.pl from upstream. One of the many corrections is not creating an error for cover-letters. Reintroduce U-Boot's 5c761ce58666b3a1695697498598f8bf3484a0c7 checkpatch.pl: Add warning for new __packed additions Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2017-10-29checkpatch: Support wide stringsHeinrich Schuchardt
Allow prefixing typical strings with L for wide strings Patch originally by Joe Perches https://lkml.org/lkml/2017/10/17/1117 Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2017-09-15checkpatch.pl: Add warning for new __packed additionsHeinrich Schuchardt
While there are valid reasons to use __packed, often the answer is that you should be doing something else here instead. This reintroduces the changes of f503cc49a570 (Add warning for new __packed additions) Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2017-09-14checkpatch: update from Linux v4.13-rc6Heinrich Schuchardt
Checkpatch produces the following warning: Unescaped left brace in regex is deprecated here (and will be fatal in Perl 5.30), passed through in regex; marked by <-- HERE in m/^(\+.*(?:do|\))){ <-- HERE / at scripts/checkpatch.pl line 3348. The curent checkpatch of the Linux kernel corrects this bug and many others. It provides improved colored output. So replace checkpatch by the current Linux version. Add an empty file scripts/const_structs.checkpatch. We can later fill it according to our needs. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2017-02-08checkpatch: Port spelling to checkpatchDan Murphy
Pick commit 66b47b4a9dad0 checkpatch: look for common misspellings from the Linux kernel for spelling check from Kees Cook In addition pulled in additional changes commit ebfd7d6237531 checkpatch: add optional --codespell dictionary to find more typos from the Linux kernel for codespell from Joe Perches commit f1a63678554f8 checkpatch: remove local from codespell path from the Linux kernel for dictionary path from Maxim Uvarov Signed-off-by: Dan Murphy <dmurphy@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-06Various, accumulated typos collected from around the tree.Robert P. J. Day
Fix various misspellings of: * deprecated * partition * preceding,preceded * preparation * its versus it's * export * existing * scenario * redundant * remaining * value * architecture Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Reviewed-by: Jagan Teki <jteki@openedev.com> Reviewed-by: Stefan Roese <sr@denx.de>
2016-01-04checkpatch: fix left brace warningHeiko Schocher
using checkpatch with Perl 5.22.0 generates a warning, this is fixed in linux through commit: commit 4e5d56bdf892e18832a6540b63ebf709966bce2a Author: Eddie Kovsky <ewk@edkovsky.org> Date: Wed Sep 9 15:37:52 2015 -0700 checkpatch: fix left brace warning Using checkpatch.pl with Perl 5.22.0 generates the following warning: Unescaped left brace in regex is deprecated, passed through in regex; This patch fixes the warnings by escaping occurrences of the left brace inside the regular expression. Adapt it for U-Boot. Signed-off-by: Heiko Schocher <hs@denx.de>
2014-09-25checkpatch: remove unnecessary + after {8,8}Joe Perches
Pick the following commit from Linux kernel: commit 66cb4ee0e52ca721f609fd5eec16187189ae5fda Author: Joe Perches <joe@perches.com> Date: Wed Sep 10 09:40:47 2014 +1000 checkpatch: remove unnecessary + after {8,8} There's a useless "+" use that needs to be removed as perl 5.20 emits a "Useless use of greediness modifier '+'" message each time it's hit. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@ti.com>
2014-03-04scripts: update checkpatch.pl to latest upstream versionTom Rini
Update to v3.14-rc4's version of checkpatch.pl. In doing so we drop the changes to top_of_kernel_tree() as we pass in --no-tree and drop our changes about MAINTAINERS as that's for reporting checkpatch.pl problems itself (and upstream has said they'll reword this section to be clearer). Signed-off-by: Tom Rini <trini@ti.com>
2014-02-26checkpatch.pl: Add warning for new __packed additionsTom Rini
While there are valid reasons to use __packed, often the answer is that you should be doing something else here instead. Signed-off-by: Tom Rini <trini@ti.com>
2013-12-13Makefile: Move some scripts imported from LinuxMasahiro Yamada
We have some scripts imported from Linux Kernel: setlocalversion, checkstack.pl, checkpatch.pl, cleanpatch They are located under tools/ directory in U-Boot now. But they were originally located under scripts/ directory in Linux Kernel. This commit moves them to the original location. It is true that binutils-version.sh and dtc-version.sh do not originate in Linux Kernel, but they should be moved by analogy to gcc-version.sh. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
