path: root/scripts/build-whitelist.sh
2017-09-01sunxi: Fix CONFIG_SUNXI_GMAC referencesDave Prue
SUNXI_GMAC was still used to configure the code where as the same has been renamed and moved to Kconfig in below commit "sunxi: Move SUNXI_GMAC to Kconfig" (sha1: 4d43d065db3262f9a9918ba72457bf36dfb8e0bb) Signed-off-by: Dave Prue <dave@prue.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jagan@openedev.com> Reviewed-by: Mark Kettenis <kettenis@openbsd.org> Tested-by: Mark Kettenis <kettenis@openbsd.org> [Tweek commit message, config_whitelist.txt, build-whitelist.sh] Signed-off-by: Jagan Teki <jagan@openedev.com>
2017-06-29scripts: config_whitelist: Handle lines with leading spaces/tabsBin Meng
Some Kconfig options are defined in a line with leading spaces/tabs. Update build-whitelist/check-config scripts to handle such cases. Generate a new config_whitelist.txt with new scripts. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2016-10-07build-whitelist: do not add new options to whitelist when updateMasahiro Yamada
If somebody adds references to new CONFIG options in source files, they will be added in the whitelist when we sync it. (For example, if we run scripts/build-whitelist.sh against commit 42f75050667b, new options CONFIG_SPL_DFU_SUPPORT and CONFIG_USB_XHCI_UNIPHIER will appear in the list.) In order to make steady progress of Kconfig migration, we want to only decrease whitelist options, but never increase. So, when we update the whitelist, we should create a temporary list, then take the intersection of the temporary one and the current one. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-16Kconfig: Add a whitelist of ad-hoc CONFIG optionsSimon Glass
Add a list of ad-hoc CONFIG options that don't use Kconfig. This can be used to check that new ones are not being added. Signed-off-by: Simon Glass <sjg@chromium.org>
