path: root/scripts/Makefile.build
2020-04-24kbuild: cherry-pick kbuild changes from LinuxMasahiro Yamada
b42841b7bb62 kbuild: Get rid of KBUILD_STR 2aedcd098a94 kbuild: suppress annoying "... is up to date." message 9c8fa9bc08f6 kbuild: fix if_change and friends to consider argument order ebf003f0cfb3 kbuild: Consolidate header generation from ASM offset information 2982c953570b kbuild: remove redundant $(wildcard ...) for cmd_files calculation 8a78756eb545 kbuild: create object directories simpler and faster 4d4b5c2e3b6e treewide: remove explicit rules for *offsets.s 01d509a48b46 kbuild: remove unimportant comments from ./Kbuild Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
2020-04-10kconfig / kbuild: Re-sync with Linux 4.19Tom Rini
Align Kconfig and Kbuild logic to Linux 4.19 release with minimal impact on files outside of this scope. Our previous Kconfig sync was done by commit 5972ff077e0f ("kconfig / kbuild: re-sync with Linux 4.18"). In this particular re-sync in order to keep clang support working a number of related changes needed to be pulled in that had been missed previously. Not all of these changes we easily traceable and so have been omitted from the list below. The imported Linux commits are: [From prior to v4.18] 9f3f1fd29976 kbuild: Add __cc-option macro d7f14c66c273 kbuild: Enable Large File Support for hostprogs 6d79a7b424a5 kbuild: suppress warnings from 'getconf LFS_*' 24403874316a Shared library support 86a9df597cdd kbuild: fix linker feature test macros when cross compiling with Clang 0294e6f4a000 kbuild: simplify ld-option implementation [From v4.18 to v4.19] 96f14fe738b6 kbuild: Rename HOSTCFLAGS to KBUILD_HOSTCFLAGS 10844aebf448 kbuild: Rename HOSTCXXFLAGS to KBUILD_HOSTCXXFLAGS b90a368000ab kbuild: Rename HOSTLDFLAGS to KBUILD_HOSTLDFLAGS 8377bd2b9ee1 kbuild: Rename HOST_LOADLIBES to KBUILD_HOSTLDLIBS f92d19e0ef9b kbuild: Use HOST*FLAGS options from the command line 4ab3b80159d4 kconfig: check for pkg-config on make {menu,n,g,x}config 693359f7ac90 kconfig: rename SYMBOL_AUTO to SYMBOL_NO_WRITE f60b992e30ff kbuild: replace $(LDFLAGS) $(ldflags-y) with $(ld_flags) 2fb9279f2c3e kbuild: change ld_flags to contain LDFLAGS_$(@F) c931d34ea085 arm64: build with baremetal linker target instead of Linux when available 5accd7f3360e kconfig: handle format string before calling conf_message_callback() a2ff4040151a kconfig: rename file_write_dep and move it to confdata.c 0608182ad542 kconfig: split out useful helpers in confdata.c adc18acf42a1 kconfig: remove unneeded directory generation from local*config 79123b1389cc kconfig: create directories needed for syncconfig by itself 16952b77d8b5 kconfig: make syncconfig update .config regardless of sym_change_count d6c6ab93e17f kbuild: remove deprecated host-progs variable 56869d45e364 kconfig: fix the rule of mainmenu_stmt symbol c151272d1687 kconfig: remove unused sym_get_env_prop() function 1880861226c1 kconfig: remove P_ENV property type e3fd9b5384f3 scripts/dtc: consolidate include path options in Makefile 4bf6a9af0e91 kconfig: add build-only configurator targets f1575595d156 kconfig: error out when seeing recursive dependency 5e8c5299d315 kconfig: report recursive dependency involving 'imply' f498926c47aa kconfig: improve the recursive dependency report 98a4afbfafd2 kconfig: fix "Can't open ..." in parallel build 9a9ddcf47831 kconfig: suppress "configuration written to .config" for syncconfig 87a32e624037 kbuild: pass LDFLAGS to recordmcount.pl d503ac531a52 kbuild: rename LDFLAGS to KBUILD_LDFLAGS 217c3e019675 disable stringop truncation warnings for now bc8d2e20a3eb kconfig: remove a spurious self-assignment fd65465b7016 kconfig: do not require pkg-config on make {menu,n}config 5a4630aadb9a ftrace: Build with CPPFLAGS to get -Qunused-arguments Note that this adds new cleanup work to do in that we should adapt the shared library support we have to what is now upstream. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Masahiro Yamada <masahiroy@kernel.org>
2020-03-16kconfig / kbuild: re-sync with Linux 4.18Tom Rini
Align Kconfig and Kbuild logic to Linux 4.18 release with minimal impact on files outside of this scope. Our previous Kconfig sync was done by commit e91610da7c8a ("kconfig: re-sync with Linux 4.17-rc4"). A very small number of changes upstream since our sync with v4.17-rc4 that exist in the v4.18 release have already been applied here and have been omitted from the list in this commit (and are readily available in our own git history). The imported Linux commits are: [From prior to v4.17-rc4] 39a33ff80a25 kbuild: remove cc-option-align db547ef19064 Kbuild: don't add obj tree in additional includes b999596b963a Kbuild: don't add ../../ to include path [From v4.17 to v4.18] b3aa58d2e85d fixdep: suppress consecutive / from file paths in dependency list files 74656b682902 kbuild: disable new dtc graph and unit-address warnings 74d931716151 genksyms: remove symbol prefix support e6ecfb45072c kbuild: do not display CHK for filechk 0b669a5076fd kconfig: refactor Qt package checks for building qconf b464ef583dc7 kconfig: refactor GTK+ package checks for building gconf 1c5af5cf9308 kconfig: refactor ncurses package checks for building mconf and nconf 694c49a7c01c kconfig: drop localization support 96f60dfa5819 trace: Use -mcount-record for dynamic ftrace bb222ceeb327 kconfig: remove string expansion in file_lookup() 96d8e48da55a kconfig: remove string expansion for mainmenu after yyparse() 5b31a9746756 kconfig: remove sym_expand_string_value() 137c0118a900 kconfig: make default prompt of mainmenu less specific e298f3b49def kconfig: add built-in function support 2fd5b09c201e kconfig: add 'shell' built-in function 9de071536c87 kconfig: begin PARAM state only when seeing a command keyword 9ced3bddec08 kconfig: support user-defined function and recursively expanded variable 1175c02506ff kconfig: support simply expanded variable ed2a22f277c6 kconfig: support append assignment operator 82bc8bd82e5c kconfig: expand lefthand side of assignment statement 1d6272e6fe43 kconfig: add 'info', 'warning-if', and 'error-if' built-in functions a702a6176e2f kconfig: add 'filename' and 'lineno' built-in variables 915f64901eb3 kconfig: error out if a recursive variable references itself 2bece88f89fa kconfig: test: add Kconfig macro language tests 21c54b774744 kconfig: show compiler version text in the top comment 59f7b5847b0c kbuild: $(CHECK) doesnt need NOSTDINC_FLAGS twice 145167650b96 kbuild: add endianness flag to CHEKCFLAGS 1f2f01b122d7 kbuild: add machine size to CHECKFLAGS d6a0c8a1326b kconfig: Add testconfig into make help output bb6d83dde191 kbuild: Move last word of nconfig help to the previous line 8593080c0fcf kconfig: fix localmodconfig ed7d40bc67b8 tracing: Fix SKIP_STACK_VALIDATION=1 build due to bad merge with -mrecord-mcount b2d00d7c61c8 kconfig: fix line numbers for if-entries in menu tree ecd53ac2f2c6 kconfig: handle P_SYMBOL in print_symbol() 73d1c580f92b kconfig: loop boundary condition fix 48f6e3cf5bc6 kbuild: do not drop -I without parameter bd412d81b7ea kbuild: .PHONY is not a variable, but PHONY is 6916162c7308 kbuild: remove duplicated comments about PHONY Cc: Masahiro Yamada <masahiroy@kernel.org> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Masahiro Yamada <masahiroy@kernel.org>
2019-12-06lib: crypto: add pkcs7 message parserAKASHI Takahiro
Imported from linux kernel v5.3: pkcs7.asn1 without changes pkcs7.h with changes marked as __UBOOT__ pkcs7_parser.h without changes pkcs7_parser.c with changes marked as __UBOOT__ Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
2019-12-06Makefile: add build script for asn1 parsersAKASHI Takahiro
This rule will be used to build x509 and pkcs7 parsers. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
2019-12-06cmd: add asn1_compilerAKASHI Takahiro
Imported from linux kernel v5.3: asn1.h without changes asn1_ber_bytecode.h without changes asn1_decoder.h without changes asn1_compiler.c without changes This host command will be used to create a ASN1 parser, for example, for pkcs7 messages or x509 certificates. More specifically, it will generate *byte code* which will be interpreted by asn1 decoder library. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-01-15kbuild: add .SECONDARY special target to scripts/Kbuild.includeMasahiro Yamada
Based on the following Linux commits: - 54a702f70589 ("kbuild: mark $(targets) as .SECONDARY and remove .PRECIOUS markers") - 8e9b61b293d9 ("kbuild: move .SECONDARY special target to Kbuild.include") GNU Make automatically deletes intermediate files that are updated in a chain of pattern rules. Example 1) %.dtb.o <- %.dtb.S <- %.dtb <- %.dts Example 2) %.o <- %.c <- %.c_shipped A couple of makefiles mark such targets as .PRECIOUS to prevent Make from deleting them, but the correct way is to use .SECONDARY. .SECONDARY Prerequisites of this special target are treated as intermediate files but are never automatically deleted. .PRECIOUS When make is interrupted during execution, it may delete the target file it is updating if the file was modified since make started. If you mark the file as precious, make will never delete the file if interrupted. Both can avoid deletion of intermediate files, but the difference is the behavior when Make is interrupted; .SECONDARY deletes the target, but .PRECIOUS does not. The use of .PRECIOUS is relatively rare since we do not want to keep partially constructed (possibly corrupted) targets. .SECONDARY with no prerequisites causes all targets to be treated as secondary. This agrees the policy of Kbuild. scripts/Kbuild.include seems a suitable place to add it because it is included from almost all sub-makes. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-05-31kconfig: re-sync with Linux 4.17-rc4Eugeniu Rosca
Align Kconfig to Linux 4.17-rc4 with minimal impact on non-kconfig files. Previous Kconfig sync was done by commit bf7ab1e70fd762 ("kconfig: re-sync with Linux 4.10") and it achieved almost perfect alignment with a few (intended) exceptions, caused by below U-boot commits: [A] v2015.04 5f9eb2207500 ("kbuild: remove scripts/multiconfig.sh") [B] v2015.07 20c20826efab ("Kconfig: Enable usage of escape char '\' in string values") [C] v2016.01 da58dec86616 ("Various Makefiles: Add SPDX-License-Identifier tags") [D] v2016.03 5b8031ccb4ed ("Add more SPDX-License-Identifier tags") [E] v2016.03 192bc6948b02 ("Fix GCC format-security errors and convert sprintfs.") Here is the list of Kconfig commits which followed the v4.10 alignment: [F] v2018.01 0931ed3c0d0f ("kconfig/symbol.c: use correct pointer type argument for sizeof") [G] v2018.03 1414e09b4f25 ("kconfig: revert change that was not needed for -Wformat-security") [H] v2018.05 83d290c56fab ("SPDX: Convert all of our single license tags to Linux Kernel style") Commit [F] was subsequently applied to Linux kernel as commit [I] with the same patch id, so it won't contribute to further misalignment. [I] v4.15-rc1 88127dae6ed9 ("kconfig/symbol.c: use correct pointer type argument for sizeof") Commit [G] is a Kconfig-specific revert of commit [E]. Commit [H] relocated and reformatted the license doing no functional change. In summary, the only functional change that makes U-boot Kconfig diverge from Linux Kconfig is commit [B]. After a brief analysis, the purpose of [B] seems to be placing "\n" literals in string symbols like CONFIG_AUTOBOOT_PROMPT="autoboot in %d seconds\n" in order to pass them directly to printf and expect correct output at runtime. Currently, Linux doesn't seem to have this requirement, so for the moment [B] looks like a U-boot specific feature/fix. From point of view of further Kconfig alignment and backporting efforts, it is highly desired that commits like [B] are propagated to Linux and any Kconfig fixes/features are contributed to Linux kernel first. This specific Kconfig re-sync just keeps [B] in place. Contrary to 4.10 Kconfig re-sync (which achieves zero non-kconfig changes), 4.17-rc4 re-sync does some amount of updates in Kbuild (striving to keep them at minimum), due to a number of reasons: * Kbuild is affected by the removal of Kconfig "*shipped" files and now requires flex and bison pre-installed on the host. * PYTHON{2,3} variables are defined in top-level Makefile as prerequisite for running the newly developed Kconfig unit tests. * silentoldconfig becomes an "internal implementation detail" deprecated for external use, being renamed to syncconfig. The exact non-kconfig files touched by this commit are: $ git show --format="" --stat -- ':!scripts/kconfig' .gitignore | 2 ++ Makefile | 9 +++++++-- scripts/Makefile.build | 11 +++++++++++ scripts/Makefile.lib | 41 ++++++++++++----------------------------- The imported Linux commits touching the above files are: c054be10ffdbd5 ("remove gperf left-overs from build system") 73a4f6dbe70a1b ("kbuild: add LEX and YACC variables") 033dba2ec06c47 ("kbuild: prepare to remove C files pre-generated by flex and bison") eea199b445f64c ("kbuild: remove unnecessary LEX_PREFIX and YACC_PREFIX") e71de5ee08dcb0 ("kbuild: remove remaining use of undefined YACC_PREFIX") d59fbbd09d5d6b ("kbuild: replace hardcoded bison in cmd_bison_h with $(YACC)") 911a91c39cabcb H ("kconfig: rename silentoldconfig to syncconfig") 59889300274569 (".gitignore: move *.lex.c *.tab.[ch] patterns to the top-level .gitignore") 9a8dfb394c0467 ("kbuild: clean up *.lex.c and *.tab.[ch] patterns from top-level Makefile") 833e622459432e H ("genksyms: generate lexer and parser during build instead of shipping") b23d1a241f4eb4 H ("kbuild: add %.lex.c and %.tab.[ch] to 'targets' automatically") e9781b52d4e0e3 H ("kbuild: add PYTHON2 and PYTHON3 variables") The commits marked with 'H' are assessed as "hard" (build will fail) prerequisites and the rest of them are assessed as "soft" prerequisites for the re-sync. In spite of relatively high number of non-H commits, they belong to this Kconfig update topic-wise and decrease the number of cherry pick conflicts for many commits in this series. Additional effort can be put in eliminating the soft prerequisites, if really needed. The commits which contributed to this Kconfig re-sync are listed below. Whenever a conflict resolution has been performed (mostly by hand, but sometimes automatically by git), it is revealed by the '!' sign in the second column, which means a patch id mismatch between Linux and U-boot commits: 9be3213b14d44f ("gconfig: remove misleading parentheses around a condition") ff85a1a80e0034 ("kconfig: Check for libncurses before menuconfig") ad8181060788c8 ("kconfig: fix sparse warnings in nconfig") cb77f0d623ff33 ! ("scripts: Switch to more portable Perl shebang") bb3290d91695bb ! ("Remove gperf usage from toolchain") c054be10ffdbd5 ("remove gperf left-overs from build system") b24413180f5600 ! ("License cleanup: add SPDX GPL-2.0 license identifier to files with no license") 9059a3493efea6 ! ("kconfig: fix relational operators for bool and tristate symbols") 2c37e08464a850 ("kconfig: Warn if choice default is not in choice") 33ca1a24866373 ("kconfig: Document the 'menu' struct") 52aede4ba5efd1 ("kconfig: Document the 'symbol' struct") c873443430ebd1 ("kconfig: Sync zconf.y with zconf.tab.c_shipped") 9a826842ff2fbd ("kconfig: Rename menu_check_dep() to rewrite_m()") fa8cedaef814ce ("kconfig: Clarify expression rewriting") f77850d3fe0c96 ("kconfig: Clean up modules handling and fix crash") e3b03bf29d6b99 ("kconfig: display recursive dependency resolution hint just once") 73a4f6dbe70a1b ! ("kbuild: add LEX and YACC variables") 033dba2ec06c47 ! ("kbuild: prepare to remove C files pre-generated by flex and bison") 29c833061c1d8c ("kconfig: generate lexer and parser during build instead of shipping") 26e47a3c11a25c ("kconfig: Don't leak symbol names during parsing") 24161a6711c945 ("kconfig: Don't leak 'source' filenames during parsing") bc28fe1d5ede88 ("kconfig: Don't leak 'option' arguments during parsing") 0724a7c32a54e3 ("kconfig: Don't leak main menus during parsing") ae7440ef0c8013 ("kconfig: Fix automatic menu creation mem leak") 5b1374b3b3c2fc ("kconfig: Fix expr_free() E_NOT leak") 7cf33f88e29410 ("kconfig: Fix choice symbol expression leak") 05cccce580456d ("kconfig: Document automatic submenu creation code") 0735f7e5def2ab ("kconfig: Document important expression functions") df60f4b92d3d0b ("kconfig: Remove menu_end_entry()") b92d804a51796b ("kconfig: drop 'boolean' keyword") 6479f327dea60d ("kconfig: Warn if there is more than one help text") 52e58a3caeba5d ("kconfig: make input_mode static") 5a3dc717b3c785 ("kconfig: make xfgets() really static") 84dd95d4f87a0d ("kconfig: make conf_unsaved a local variable of conf_read()") 765f4cdef6f80d ("kconfig: use default 'yy' prefix for lexer and parser") eea199b445f64c ("kbuild: remove unnecessary LEX_PREFIX and YACC_PREFIX") e71de5ee08dcb0 ("kbuild: remove remaining use of undefined YACC_PREFIX") d59fbbd09d5d6b ! ("kbuild: replace hardcoded bison in cmd_bison_h with $(YACC)") 3e41ba05b6d60c ("kconfig: Document SYMBOL_OPTIONAL logic") d3465af60f4471 ("kconfig: Clarify choice dependency propagation") 9d1a9e8bc18bea ("kconfig: Document 'if' flattening logic") b53688014e3325 ("kconfig: Clarify menu and 'if' dependency propagation") d0fd0428ecf04b ("kconfig: fix make xconfig when gettext is missing") 312ee68752faaa ("kconfig: announce removal of oldnoconfig if used") 1ccb27143360bd ("kconfig: make "Selected by:" and "Implied by:" readable") cedd55d49dee94 ! ("kconfig: Remove silentoldconfig from help and docs; fix kconfig/conf's help") 1b9eda2e4892cb ("kconfig: Warn if help text is blank") cb67ab2cd2b8ab ("kconfig: do not write choice values when their dependency becomes n") 4f208f392103e8 ("kconfig: show '?' prompt even if no help text is available") cd58a91def2acc ("kconfig: remove 'config*' pattern from .gitignnore") d2a04648a5dbc3 ("kconfig: remove check_stdin()") f3ff6fb5db68bc ("kconfig: echo stdin to stdout if either is redirected") 9e3e10c725360b ("kconfig: send error messages to stderr") d717f24d8c6808 ("kconfig: add xrealloc() helper") 523ca58b7db2e3 ("kconfig: remove const qualifier from sym_expand_string_value()") cd81fc82b93fa4 ("kconfig: add xstrdup() helper") f4bc1eefc1608e ("kconfig: set SYMBOL_AUTO to the symbol marked with defconfig_list") bf0bbdcf100322 ("kconfig: Don't leak choice names during parsing") 1a90ce36c6eff6 ("kconfig: Update ncurses package names for menuconfig") 5ae6fcc4bb82bd ("kconfig: fix line number in recursive inclusion error message") 07a422bb213adb ! ("kbuild: restore autoksyms.h touch to the top Makefile") 9a47ceec543bfb ("kconfig: clean-up reverse dependency help implementation") d9119b5925a03b ("kconfig: Print reverse dependencies in groups") f467c5640c29ad ("kconfig: only write '# CONFIG_FOO is not set' for visible symbols") 59a80b5e892dde ("kconfig: do not call check_conf() for olddefconfig") 4bb3a5b085cd6f ("kconfig: remove unneeded input_mode test in conf()") 99f0b6578bab44 ("kconfig: remove redundant input_mode test for check_conf() loop") 2aad9b89621386 ("kconfig: hide irrelevant sub-menus for oldconfig") 81d2bc2273052e ("kconfig: invoke oldconfig instead of silentoldconfig from local*config") 911a91c39cabcb ! ("kconfig: rename silentoldconfig to syncconfig") 2a61625835c7c8 ! ("kconfig: remove redundant streamline_config.pl prerequisite") 022a4bf6b59dfd ("kconfig: tests: add framework for Kconfig unit testing") 1903c511905984 ("kconfig: tests: add basic choice tests") 49ac3c0c3aa3b7 ("kconfig: tests: test automatic submenu creation") b76960c0f6b25d ("kconfig: tests: test if new symbols in choice are asked") 930c429a656fdb ("kconfig: tests: check unneeded "is not set" with unmet dependency") ee236610653ede ("kconfig: tests: check visibility of tristate choice values in y choice") beaaddb625400e ("kconfig: tests: test defconfig when two choices interact") 3e4888c2e3d77d ("kconfig: tests: test randconfig for choice in choice") 29c434f367ea7b ("kconfig: tests: test if recursive dependencies are detected") e2c75e7667c737 ("kconfig: tests: test if recursive inclusion is detected") f622f827958162 ("kconfig: warn unmet direct dependency of tristate symbols selected by y") f8f69dc0b4e070 ("kconfig: make unmet dependency warnings readable") 26561514cc9def ("kconfig: do not include both curses.h and ncurses.h for nconfig") 32a94b8b0c3e5a ("kconfig: remove duplicated file name and lineno of recursive inclusion") 379a8eb8eb1a55 ("kconfig: detect recursive inclusion earlier") 18492685e479fd ("kconfig: use yylineno option instead of manual lineno increments") 59889300274569 ! (".gitignore: move *.lex.c *.tab.[ch] patterns to the top-level .gitignore") 9a8dfb394c0467 ! ("kbuild: clean up *.lex.c and *.tab.[ch] patterns from top-level Makefile") 833e622459432e ! ("genksyms: generate lexer and parser during build instead of shipping") b23d1a241f4eb4 ! ("kbuild: add %.lex.c and %.tab.[ch] to 'targets' automatically") 17baab68d337a0 ("kconfig: extend output of 'listnewconfig'") e9781b52d4e0e3 ! ("kbuild: add PYTHON2 and PYTHON3 variables") The current Kconfig update generates below build-time warnings: YACC scripts/dtc/dtc-parser.tab.h scripts/dtc/dtc-parser.y: warning: 3 shift/reduce conflicts [-Wconflicts-sr] YACC scripts/dtc/dtc-parser.tab.c scripts/dtc/dtc-parser.y: warning: 3 shift/reduce conflicts [-Wconflicts-sr] This seems to happen because the Kbuild updates apparently didn't make room for both "*shipped"-based builds and flex/bison-based builds. A similar problem has been reported for genksyms parser in v4.17-rc1 commit 833e622459432e ("genksyms: generate lexer and parser during build instead of shipping"). I have figured out empirically that the warnings are healed after updating the in-tree U-boot DTC to upstream v1.4.6-9, same as done by Linux v4.17-rc1 commit 9130ba88464032 ("scripts/dtc: Update to upstream version v1.4.6-9-gaadd0b65c987"). Whether fixing the DTC-related yacc warnings should be done together with the Kconfig re-sync, I would like to hear from community. My testing was limited to: - make defconfig all - make ARCH=arm CROSS_COMPILE=aarch64-linux-gnu- r8a7795_ulcb_defconfig all - comparing .config before and after the re-sync - running the newly imported Kconfig unit tests as seen below: $ make testconfig Tested-by: Petr Vorel <petr.vorel@gmail.com> ============================= test session starts ============================= scripts/kconfig/tests/auto_submenu/__init__.py::test PASSED [ 7%] scripts/kconfig/tests/choice/__init__.py::test_oldask0 PASSED [ 14%] scripts/kconfig/tests/choice/__init__.py::test_oldask1 PASSED [ 21%] scripts/kconfig/tests/choice/__init__.py::test_allyes PASSED [ 28%] scripts/kconfig/tests/choice/__init__.py::test_allmod PASSED [ 35%] scripts/kconfig/tests/choice/__init__.py::test_allno PASSED [ 42%] scripts/kconfig/tests/choice/__init__.py::test_alldef PASSED [ 50%] scripts/kconfig/tests/choice_value_with_m_dep/__init__.py::test PASSED [ 57%] scripts/kconfig/tests/err_recursive_inc/__init__.py::test PASSED [ 64%] scripts/kconfig/tests/inter_choice/__init__.py::test PASSED [ 71%] scripts/kconfig/tests/new_choice_with_dep/__init__.py::test PASSED [ 78%] scripts/kconfig/tests/no_write_if_dep_unmet/__init__.py::test PASSED [ 85%] scripts/kconfig/tests/rand_nested_choice/__init__.py::test PASSED [ 92%] scripts/kconfig/tests/warn_recursive_dep/__init__.py::test PASSED [100%] ========================== 14 passed in 0.34 seconds ========================== Signed-off-by: Eugeniu Rosca <erosca@de.adit-jv.com> Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com> Tested-by: Petr Vorel <petr.vorel@gmail.com>
2016-01-19scripts/Makefile* Add SPDX-License-Identifier tagTom Rini
A general best practice for SPDX is that Makefiles should have an identifier, add these as everything else is currently covered. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-07-27kbuild: sync with Linux 4.1Masahiro Yamada
Update some build scripts to match Linux 4.1. Commit-based syncing was done so as not to break U-Boot specific changes. The previous big sync was from Linux 3.18-rc1 by commit 176d09827725 (kbuild: sync misc scripts with Linux 3.18-rc1). The commits imported from Linux (some with adjustments) are: [1] commit 9fb5e5372208973984a23ee6f5f025c05d364633 Author: Robert Richter <rrichter@cavium.com> dts, kbuild: Factor out dtbs install rules to Makefile.dtbinst [2] commit 371fdc77af44f4cb32475fd499e1d912ccc30890 Author: Masahiro Yamada <yamada.m@jp.panasonic.com> kbuild: collect shorthands into scripts/Kbuild.include [3] commit a29b82326ed4eb5567b03c85b52c6891578d5a03 Author: Michal Marek <mmarek@suse.cz> kbuild: Remove duplicate $(cmd) definition in Makefile.clean [4] commit 1846dfbde3e8a53f3673dcb1c1b79fd9b3f8d40d Author: Masahiro Yamada <yamada.m@jp.panasonic.com> kbuild: remove redundant -rR flag of hdr-inst [5] commit 34948e0bbf98640fc1821751b01d2f0cd17d84d5 Author: Michal Marek <mmarek@suse.cz> kbuild: Drop support for clean-rule [6] commit a16c5f99a28c9945165c46da27fff8e6f26f8736 Author: Michal Marek <mmarek@suse.cz> kbuild: Fix removal of the debian/ directory [7] commit d0d38cd9e853db11e0242b3df4c9c3c4a663fbb4 Author: Masahiro Yamada <yamada.m@jp.panasonic.com> kbuild: use mixed-targets when two or more config targets are given [8] commit dd33c03b18b3f2db791eb6a17c37d2de66e4de18 Author: Masahiro Yamada <yamada.m@jp.panasonic.com> kbuild: fix cc-ifversion macro [9] commit 665d92e38f65d70796aad2b8e49e42e80815d4a4 Author: Masahiro Yamada <yamada.m@jp.panasonic.com> kbuild: do not add $(call ...) to invoke cc-version or cc-fullversion [10] commit 6dcb4e5edf39e3b65a75ca76f087b2fdbee8a808 Author: Masahiro Yamada <yamada.m@jp.panasonic.com> kbuild: allow cc-ifversion to have the argument for false condition [11] commit c0a80c0c27e5e65b180a25e6c4c2f7ef9e386cd3 Author: Heiko Carstens <heiko.carstens@de.ibm.com> ftrace: allow architectures to specify ftrace compile options [12] commit 0b24becc810dc3be6e3f94103a866f214c282394 Author: Andrey Ryabinin <a.ryabinin@samsung.com> kasan: add kernel address sanitizer infrastructure [13] commit 4218affdf57f938c04e3a916a9685ee27079f377 Author: Masahiro Yamada <yamada.m@jp.panasonic.com> kbuild: remove warning about "make depend" [14] commit 77479b38e2f58890eb221a0418357502a5b41cd6 Author: Nathan Rossi <nathan.rossi@xilinx.com> kbuild: Create directory for target DTB Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Robert Richter <rrichter@cavium.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Signed-off-by: Nathan Rossi <nathan.rossi@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-02-24kconfig: switch to single .config configurationMasahiro Yamada
When Kconfig for U-boot was examined, one of the biggest issues was how to support multiple images (Normal, SPL, TPL). There were actually two options, "single .config" and "multiple .config". After some discussions and thought experiments, I chose the latter, i.e. to create ".config", "spl/.config", "tpl/.config" for Normal, SPL, TPL, respectively. It is true that the "multiple .config" strategy provided us the maximum flexibility and helped to avoid duplicating CONFIGs among Normal, SPL, TPL, but I have noticed some fatal problems: [1] It is impossible to share CONFIG options across the images. If you change the configuration of Main image, you often have to adjust some SPL configurations correspondingly. Currently, we cannot handle the dependencies between them. It means one of the biggest advantages of Kconfig is lost. [2] It is too painful to change both ".config" and "spl/.config". Sunxi guys started to work around this problem by creating a new configuration target. Commit cbdd9a9737cc (sunxi: kconfig: Add %_felconfig rule to enable FEL build of sunxi platforms.) added "make *_felconfig" to enable CONFIG_SPL_FEL on both images. Changing the configuration of multiple images in one command is a generic demand. The current implementation cannot propose any good solution about this. [3] Kconfig files are getting ugly and difficult to understand. Commit b724bd7d6349 (dm: Kconfig: Move CONFIG_SYS_MALLOC_F_LEN to Kconfig) has sprinkled "if !SPL_BUILD" over the Kconfig files. [4] The build system got more complicated than it should be. To adjust Linux-originated Kconfig to U-Boot, the helper script "scripts/multiconfig.sh" was introduced. Writing a complicated text processor is a shell script sometimes caused problems. Now I believe the "single .config" will serve us better. With it, all the problems above would go away. Instead, we will have to add some CONFIG_SPL_* (and CONFIG_TPL_*) options such as CONFIG_SPL_DM, but we will not have much. Anyway, this is what we do now in scripts/Makefile.spl. I admit my mistake with my apology and this commit switches to the single .config configuration. It is not so difficult to do that: - Remove unnecessary processings from scripts/multiconfig.sh This file will remain for a while to support the current defconfig format. It will be removed after more cleanups are done. - Adjust some makefiles and Kconfigs - Add some entries to include/config_uncmd_spl.h and the new file scripts/Makefile.uncmd_spl. Some CONFIG options that are not supported on SPL must be disabled because one .config is shared between SPL and U-Boot proper going forward. I know this is not a beautiful solution and I think we can do better, but let's see how much we will have to describe them. - update doc/README.kconfig More cleaning up patches will follow this. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-11-07kbuild: sync misc scripts with Linux 3.18-rc1Masahiro Yamada
This commit imports some updates in misc scripts from Linux 3.18-rc1. [1] commit cbb4d3e6510b99522719c5ef0 by Horia Geanta scripts/kernel-doc: handle object-like macros [2] commit 164f0d2efaaef83 by Michal Marek kbuild: Fix handling of backslashes in *.cmd files [3] commit 270a00963cd367214e by Randy Dunlap scripts/kernel-doc: recognize __meminit [4] commit a4954fd7724c0f55361eb5 by Masahiro Yamada kbuild: remove obj-n and lib-n handling [5] commit 5b2389b45d1a9c12b9f by Masahiro Yamada kbuild: simplify build, clean, modbuiltin shorthands Signed-off-by: Horia Geanta <horia.geanta@freescale.com> Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-07kbuild: improve multi-objs dependency and cleanupsMasahiro Yamada
Since Linux 3.18-rc1, Kbuild is able to handle multi-objs dependency correctly, which also allows us futher cleanups of some makefiles. This commit imports those commits: [1] commit c8589d1e9e01 by Masahiro Yamada kbuild: handle multi-objs dependency appropriately [2] commit 97e3226e6e98 by Masahiro Yamada kbuild: handle the dependency of multi-objs hostprogs appropriately [3] commit 022af62d0190 by Masahiro Yamada kbuild: refactor script/kconfig/Makefile [4] commit 221ecca6cafe by Masahiro Yamada kbuild: remove redundant clean-files from scripts/kconfig/Makefile Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-08-21kbuild: move extra gcc checks to scripts/Makefile.extrawarnMasahiro Yamada
This commit was imported from Linux Kernel: commit a86fe353 written by me. W=... provides extra gcc checks. Having such code in scripts/Makefile.build results in the same flags being added to KBUILD_CFLAGS multiple times becuase scripts/Makefile.build is invoked every time Kbuild descends into the subdirectories. Since the top Makefile is already too cluttered, this commit moves all of extra gcc check stuff to a new file scripts/Makefile.extrawarn, which is included from the top Makefile. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-07-30kconfig: switch to KconfigMasahiro Yamada
This commit enables Kconfig. Going forward, we use Kconfig for the board configuration. mkconfig will never be used. Nor will include/config.mk be generated. Kconfig must be adjusted for U-Boot because our situation is a little more complicated than Linux Kernel. We have to generate multiple boot images (Normal, SPL, TPL) from one source tree. Each image needs its own configuration input. Usage: Run "make <board>_defconfig" to do the board configuration. It will create the .config file and additionally spl/.config, tpl/.config if SPL, TPL is enabled, respectively. You can use "make config", "make menuconfig" etc. to create a new .config or modify the existing one. Use "make spl/config", "make spl/menuconfig" etc. for spl/.config and do likewise for tpl/.config file. The generic syntax of configuration targets for SPL, TPL is: <target_image>/<config_command> Here, <target_image> is either 'spl' or 'tpl' <config_command> is 'config', 'menuconfig', 'xconfig', etc. When the configuration is done, run "make". (Or "make <board>_defconfig all" will do the configuration and build in one time.) For futher information of how Kconfig works in U-Boot, please read the comment block of scripts/multiconfig.py. By the way, there is another item worth remarking here: coexistence of Kconfig and board herder files. Prior to Kconfig, we used C headers to define a set of configs. We expect a very long term to migrate from C headers to Kconfig. Two different infractructure must coexist in the interim. In our former configuration scheme, include/autoconf.mk was generated for use in makefiles. It is still generated under include/, spl/include/, tpl/include/ directory for the Normal, SPL, TPL image, respectively. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-06-20cosmetic: kbuild: clean-up coding style (sync with Linux 3.16-rc1)Masahiro Yamada
Import the following trivial commits from Linux v3.16-rc1: bb66fc6 kbuild: trivial - use tabs for code indent where possible 7eb6e34 kbuild: trivial - remove trailing empty lines 3fbb43d kbuild: trivial - fix comment block indent 38385f8 kbuild: trivial - remove trailing spaces Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-04-18kbuild: sync with Linux Kernel v3.15-rc1Masahiro Yamada
This commit imports Kbuild-related updates from v3.14 to v3.15-rc1. - commit 3d3d6b8474204b6819688c9800774d52d370a538 kbuild: LLVMLinux: Adapt warnings for compilation with clang - commit 61163efae02040f66a95c8ed17f4407951ba58fa kbuild: LLVMLinux: Add Kbuild support for building kernel with Clang - commit 79192ca8ebd9a25c583aa46024a250fef1e7766f scripts: objdiff: detect object code changes between two commits - commit 1c9e70a55b088d97a59241744fe459409d0c3582 kbuild: create a build directory automatically for out-of-tree build - commit a03fcb50e816a69acffb13b5e56db75063aeba8a kbuild: remove redundant '.*.cmd' pattern from make distclean - commit 13338935f1574a2dcd1c891461b0dcc42f8cff42 kbuild: move "quote" to Kbuild.include to be consistent - commit bfdfaeae500a3b194b73b01e92a8034791a58b7f kbuild: specify build_docproc as a phony target - commit f4d4ffc03efc864645b990e1d579bbe1b8e358a4 kbuild: dtbs_install: new make target - commit 1e64ff42ea3d8d2fc8aa71f9717b3c1cb6c2f893 Kbuild, lto: Disable LTO for asm-offsets.c - commit ccbef1674a1579842c7dbdf554efca85d2cd245a Kbuild, lto: add ld-version and ld-ifversion macros - commit ae63b2d7bdd9bd66b88843be0daf8e37d8f0b574 scripts/tags.sh: Ignore *.mod.c - commit e36aaea28972c57a32a3ba5365e61633739719b9 kbuild: Fix silent builds with make-4 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-07kbuild: improve Kbuild speedMasahiro Yamada
Kbuild brought about many advantages for us but a significant performance regression was reported by Simon Glass. After some discussions and analysis, it turned out its main cause is in $(call cc-option,...). Historically, U-Boot parses all config.mk (arch/*/config.mk and board/*/config.mk) every time descending into subdirectories. That means cc-options are evaluated over and over again. $(call cc-option,...) is useful but costly. So we want to evaluate them only in ./Makefile and spl/Makefile and export compiler flags. This commit changes the build system as follows: - Modify scripts/Makefile.build to not include config.mk Instead, add $(PLATFORM_CPPFLAGS) to asflags-y, ccflags-y, cppflags-y. - Export many variables Going forward, Kbuild will not parse config.mk files when it descends into subdirectories. If we want to set variables in config.mk and use them in subdirectories, they must be exported. This is the list of variables to get exported: PLATFORM_CPPFLAGS CPUDIR BOARDDIR OBJCOPYFLAGS LDFLAGS LDFLAGS_FINAL (used in nand_spl/board/*/*/Makefile) CONFIG_STANDALONE_LOAD_ADDR (used in examples/standalone/Makefile) SYM_PREFIX (used in examples/standalone/Makefile) RELFLAGS (used in examples/standalone/Makefile) - Delete CPPFLAGS This variable has been replaced with PLATFORM_CPPFLAGS - Copy gcclibdir from example/standalone/Makefile to arch/sparc/config.mk The reference in CONFIG_STANDALONE_LOAD_ADDR must be resolved before it is exported. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reported-by: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> [on Sandbox] Tested-by: Stephen Warren <swarren@nvidia.com> [on Tegra]
2014-02-19kbuild: move include directives of board configuration filesMasahiro Yamada
This commit changes the location of include directives of board configuration files. The purpose of this change is: - Slim down $(TOPDIR)/config.mk - Prevent $(TOPDIR)/Makefile from including the same configuration file twice - Do not include include/config.mk multiple times because ARCH, CPU, BOARD, VENDOR, SOC are exported Before this commit: - include/autoconf.mk was included from $(TOPDIR)/Makefile and $(TOPDIR)/config.mk (This means $(TOPDIR)/Makefile included include/autoconf.mk twice) - include/{spl,tpl}-autoconf.mk was included from $(TOPDIR)/config.mk - include/config.mk was included from $(TOPDIR)/Makefile and $(TOPDIR)/config.mk (This means $(TOPDIR)/Makefile included include/config.mk twice) After this commit: - include/autoconf.mk is included from $(TOPDIR)/Makefile and $(TOPDIR)/scripts/Makefile.build - include/{spl,tpl}-autoconf.mk is included from $(TOPDIR)/spl/Makefile and $(TOPDIR)/scripts/Makefile.build - include/config.mk is included from $(TOPDIR)/config.mk and $(TOPDIR)/spl/Makefile Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: use Linux Kernel build scriptsMasahiro Yamada
Now we are ready to switch over to real Kbuild. This commit disables temporary scripts: scripts/{Makefile.build.tmp, Makefile.host.tmp} and enables real Kbuild scripts: scripts/{Makefile.build,Makefile.host,Makefile.lib}. This switch is triggered by the line in scripts/Kbuild.include -build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build.tmp obj +build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build obj We need to adjust some build scripts for U-Boot. But smaller amount of modification is preferable. Additionally, we need to fix compiler flags which are locally added or removed. In Kbuild, it is not allowed to change CFLAGS locally. Instead, ccflags-y, asflags-y, cppflags-y, CFLAGS_$(basetarget).o, CFLAGS_REMOVE_$(basetarget).o are prepared for that purpose. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-02-19kbuild: import more build scripts from Linux v3.13 tagMasahiro Yamada
This commit imports build scripts from Linux Kernel v3.13 as they are. I know they include some trailing spaces but I am intentionally keeping them untouched. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19Makefile: rename scripts/Makefile.build to scripts/Makefile.build.tmpMasahiro Yamada
Some build scripts including scripts/Makefile.build will be imported from Linux Kernel in the next commit. We need to adjust them for U-Boot in the following commits. To make it easier for reviewers to track the modification, this commit renames scripts/Makefile.build to scripts/Makefile.build.tmp beforehand. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: change out-of-tree buildMasahiro Yamada
This commit changes the working directory where the build process occurs. Before this commit, build process occurred under the source tree for both in-tree and out-of-tree build. That's why we needed to add $(obj) prefix to all generated files in makefiles like follows: $(obj)u-boot.bin: $(obj)u-boot Here, $(obj) is empty for in-tree build, whereas it points to the output directory for out-of-tree build. And our old build system changes the current working directory with "make -C <sub-dir>" syntax when descending into the sub-directories. On the other hand, Kbuild uses a different idea to handle out-of-tree build and directory descending. The build process of Kbuild always occurs under the output tree. When "O=dir/to/store/output/files" is given, the build system changes the current working directory to that directory and restarts the make. Kbuild uses "make -f $(srctree)/scripts/Makefile.build obj=<sub-dir>" syntax for descending into sub-directories. (We can write it like "make $(obj)=<sub-dir>" with a shorthand.) This means the current working directory is always the top of the output directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-02-19kbuild: Use Kbuild.includeMasahiro Yamada
This commit adjusts some files to use Kbuild.include. - Use cc-option defined in Kbuild.include (Delete cc-option in config.mk) - Use cc-version defined in (Delete cc-version in config.mk) - Move binutils-version and dtc-version to Kbuild.include by analogy to cc-version This commit also adds srctree (same as SRCTREE) to use Kbuild scripts. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19Makfile: move suffix rules to Makefile.buildMasahiro Yamada
This commit moves suffix rules from config.mk to scripts/Makefile.build, which will allow us to switch smoothly to real Kbuild. Note1: post/lib_powerpc/fpu/Makefile has its own rule to compile C sources. We need to tweak it to keep the same behavior. Note2: There are two file2 with the same name: arch/arm/lib/crt0.S and eamples/api/crt0.S. To keep the same build behavior, examples/api/Makefile also has to be treaked. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19examples: Use scripts/Makefile.buildMasahiro Yamada
2014-02-19Makefile.host.tmp: add a new script to refactor toolsMasahiro Yamada
This commit adds scripts/Makefile.host.tmp which will be used in the next commit to convert makefiles under tools/ directory to Kbuild style. Notice this script, scripts/Makefile.host.tmp is temporary. When switching over to real Kbuild, it will be replaced with scripts/Makefile.host of Linux Kernel. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-17Makefile: make directories by Makefile.buildMasahiro Yamada
2013-11-17Makefile: abolish COBJS, SOBJS, etc.Masahiro Yamada
The support for COBJS, COBJS-y, SOBJS, SOBJS-y, GLCOBJS, GLSOBJS from scripts/Makefile.build. Going forward we need to use Kbuild style consistently. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-10-31Makefile: support descending down to subdirectoriesMasahiro Yamada
This patch tweaks scripts/Makefile.build to allow the build system to descend into subdirectories like Kbuild. To use this feature, use "obj-y += foo/" syntax. Example: obj-$(CONFIG_FOO) += foo/ Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org>
2013-10-31Makefile: prepare for using Kbuild-style MakefileMasahiro Yamada
Every makefile in sub directories has common lines at the top and the bottom. This commit pushes the common parts into script/Makefile.build. Going forward sub-makefiles only need to describe this part: COBJS := ... COBJS += ... SOBJS := ... But using obj-y is preferable to prepare for switching to Kbuild. The conventional (non-Kbuild) Makefile style is still supported. This is achieved by greping the Makefile before entering into it. U-Boot conventional sub makefiles always include some other makefiles. So the build system searches a line beginning with "include" keyword in the makefile in order to distinguish which style it is. If the Makefile include a "include" line, we assume it is a conventional U-Boot style. Otherwise, it is treated as a Kbuild-style makefile. With this tweak, we can switch sub-makefiles from U-Boot style to Kbuild style little by little. obj-y := foo/ syntax (descending into the sub directory) is not supportd yet. It will be implemented in the upcomming commit. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@ti.com>
