At this point in the conversion there should be no need to have logic to
disable some symbol during the SPL build as all symbols should have an
SPL counterpart.
The main real changes done here are that we now must make proper use of
CONFIG_IS_ENABLED(DM_SERIAL) rather than many of the odd tricks we
developed prior to CONFIG_IS_ENABLED() being available.
Perform a simple rename of CONFIG_BOARDDIR to CFG_BOARDDIR
This is not needed now that CONFIG_SYS_TARGET_NAME is correctly determined
when scanning Kconfig.
This reverts commit 25b8acee2ea11a9edc100c42a61f5d6187eb6167.
Suggested-by: Tom Rini <trini@konsulko.com>
Add support for VPL, a new phase of U-Boot. This runs after TPL. It is
responsible for selecting which SPL binary to run, based on a
verified-boot process.
At present if an optional Kconfig value needs to be used it must be
bracketed by #ifdef. For example, with this Kconfig setup:
config WIBBLE
bool "Support wibbles, the world needs more wibbles"
config WIBBLE_ADDR
hex "Address of the wibble"
depends on WIBBLE
then the following code must be used:
#ifdef CONFIG_WIBBLE
static void handle_wibble(void)
int val = CONFIG_WIBBLE_ADDR;
#endif
static void init_machine()
handle_wibble();
#endif
Add a new IF_ENABLED_INT() to help with this. So now it is possible to
write, without #ifdefs:
int val = IF_ENABLED_INT(CONFIG_WIBBLE, CONFIG_WIBBLE_ADDR);
if (IS_ENABLED(CONFIG_WIBBLE))
handle_wibble();
The value will be CONFIG_WIBBLE_ADDR if CONFIG_WIBBLE is defined and will
produce a build error if not.. This allows us to reduce the use of #ifdef
in the code, ensuring that the compiler still checks the code even if it
is not ultimately used for a particular build.
Add a CONFIG_IF_ENABLED_INT() version as well.
If an attempt is made to use a value that does not exist (i.e. when the
conditional is not enabled), an error about a non-existing function is
generated, e.g.:
common/bloblist.c:447: undefined reference to `invalid_use_of_IF_ENABLED_INT'
The two helpers macros CONFIG_IS_ENABLED and CONFIG_VAL are defined in
include/linux/kconfig.h but they are not real configurations; they can
be safely removed in the generated configuration file "u-boot.cfg".
This patch simplifies the comparison of this U-Boot configuration file.
Signed-off-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
On some distributions, as Debian GNU 11, this targets fails
with errors.
Signed-off-by: Angelo Dureghello <angelo.dureghello@timesys.com>
Since commit 4b0bcfa7c4ec (Kconfig: Migrate CONFIG_BOOTM_* options),
the config_defaults.h file has been void of any actual content - and
these days, "sane defaults for everyone" is achieved by appropriate
default values in Kconfig. Remove it, and thus make every translation
unit process one less header file.
Signed-off-by: Rasmus Villemoes <rasmus.villemoes@prevas.dk>
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
Allow to use define CONFIG_IS_ENABLED
in include/config_fallbacks.h
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
Our build system still parses ad-hoc CONFIG options in header files
and generates include/autoconf.mk so that Makefiles can reference
them. This gimmick was introduced in the pre-Kconfig days and will
be kept until Kconfig migration is completed.
The include/autoconf.mk is generated like follows:
[1] Preprocess include/common.h with -DDO_DEPS_ONLY and
retrieve macros into include/autoconf.mk.tmp
[2] Reformat include/autoconf.mk.dep into include/autoconf.mk
with tools/scripts/define2mk.sed script
[3] Remove include/autoconf.mk.tmp
Here, include/autoconf.mk.tmp is similar to u-boot.cfg, which is
also generated by preprocessing include/config.h with -DDO_DEPS_ONLY.
In other words, there is much overlap among include/autoconf.mk and
u-boot.cfg build rules.
So, the idea is to split the build rule of include/autoconf.mk
into two stages. The first preprocesses headers into u-boot.cfg.
The second parses the u-boot.cfg into include/autoconf.mk. The
build rules of u-boot.cfg in Makefile and spl/Makefile will be gone.
I do not remember why I wrote the code like this, but let's make it
a bit more readable.
A general best practice for SPDX is that Makefiles should have an
identifier, add these as everything else is currently covered.
The symbolic link to SoC/CPU specific header directory is created
during the build, while it is only necessary for ARM, AVR32, SPARC,
x86, and some CPUs of PowerPC. For the other architectures, it just
results in a broken symbolic link.
Introduce CONFIG_CREATE_ARCH_SYMLINK to not create unneeded symbolic
links.
When moving configs, it is important to know what was defined in the
config header even if it duplicates the configs coming from Kconfig.
This is specifically needed for the case where a config is set to
default 'y' in the Kconfig. This would previously cause the actual value
from the include config to be filtered out, and moveconfig.py would
think that it was 'n'... This means that the value that should be 'y'
is now (in every defconfig) set to 'not set'.
tools/moveconfig.py now defines KCONFIG_IGNORE_DUPLICATES to prevent the
filtering from happening and selecting wrong values for the defconfig.
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com>
When Kconfig for U-boot was examined, one of the biggest issues was
how to support multiple images (Normal, SPL, TPL). There were
actually two options, "single .config" and "multiple .config".
After some discussions and thought experiments, I chose the latter,
i.e. to create ".config", "spl/.config", "tpl/.config" for Normal,
SPL, TPL, respectively.
It is true that the "multiple .config" strategy provided us the
maximum flexibility and helped to avoid duplicating CONFIGs among
Normal, SPL, TPL, but I have noticed some fatal problems:
[1] It is impossible to share CONFIG options across the images.
If you change the configuration of Main image, you often have to
adjust some SPL configurations correspondingly. Currently, we
cannot handle the dependencies between them. It means one of the
biggest advantages of Kconfig is lost.
[2] It is too painful to change both ".config" and "spl/.config".
Sunxi guys started to work around this problem by creating a new
configuration target. Commit cbdd9a9737cc (sunxi: kconfig: Add
%_felconfig rule to enable FEL build of sunxi platforms.) added
"make *_felconfig" to enable CONFIG_SPL_FEL on both images.
Changing the configuration of multiple images in one command is a
generic demand. The current implementation cannot propose any
good solution about this.
[3] Kconfig files are getting ugly and difficult to understand.
Commit b724bd7d6349 (dm: Kconfig: Move CONFIG_SYS_MALLOC_F_LEN to
Kconfig) has sprinkled "if !SPL_BUILD" over the Kconfig files.
[4] The build system got more complicated than it should be.
To adjust Linux-originated Kconfig to U-Boot, the helper script
"scripts/multiconfig.sh" was introduced. Writing a complicated
text processor is a shell script sometimes caused problems.
Now I believe the "single .config" will serve us better. With it,
all the problems above would go away. Instead, we will have to add
some CONFIG_SPL_* (and CONFIG_TPL_*) options such as CONFIG_SPL_DM,
but we will not have much. Anyway, this is what we do now in
scripts/Makefile.spl.
I admit my mistake with my apology and this commit switches to the
single .config configuration.
It is not so difficult to do that:
- Remove unnecessary processings from scripts/multiconfig.sh
This file will remain for a while to support the current defconfig
format. It will be removed after more cleanups are done.
- Adjust some makefiles and Kconfigs
- Add some entries to include/config_uncmd_spl.h and the new file
scripts/Makefile.uncmd_spl. Some CONFIG options that are not
supported on SPL must be disabled because one .config is shared
between SPL and U-Boot proper going forward. I know this is not
a beautiful solution and I think we can do better, but let's see
how much we will have to describe them.
- update doc/README.kconfig
More cleaning up patches will follow this.
In U-Boot, SoC-specific headers are placed in
arch/$(ARCH)/include/asm/arch-$(SOC) and a symbolic link to that
directory is created at the early stage of the build process.
Creating and removing a symbolic link during the build is not
preferred. In fact, Linux Kernel did away with include/asm-$(ARCH)
directories a long time time ago.
As for ARM, now it is possible to collect SoC sources into
arch/arm/mach-$(SOC). It is also reasonable to move SoC headers
into arch/arm/mach-$(SOC)/include/mach.
This commit prepares for that.
If the directory arch/$(ARCH)/mach-$(SOC)/include/mach exists,
a symbolic to that directory is created. Otherwise, a symbolic link
to arch/$(ARCH)/include/asm/arch-$(SOC) or arch-$(CPU) is created.
Since Linux 3.15, relative path feature and related fixes,
cleanups have been merged to the top Makefile.
The relative path feature looks stable enough, so let's import it
to U-Boot along with various cleanups.
Commits imported from Linux (some need adjustment) are:
[1] commit 7e1c04779efd by Michal Marek
kbuild: Use relative path for $(objtree)
[2] commit 890676c65d69 by Michal Marek
kbuild: Use relative path when building in the source tree
[3] commit 9da0763bdd82 by Michal Marek
kbuild: Use relative path when building in a subdir of the source tree
[4] commit c2e28dc975ea by Michal Marek
kbuild: Print the name of the build directory
[5] commit 066b7ed95580 by Michal Marek
kbuild: Do not print the build directory with make -s
[6] commit 3f1d9a6cec01 by Michal Marek
kbuild: make -s should be used with kernelrelease/kernelversion/image_name
[7] commit 7ff525712acf by Masahiro Yamada
kbuild: fake the "Entering directory ..." message more simply
[8] commit 745a254322c8 by Masahiro Yamada
kbuild: use $(Q) for sub-make target
[9] commit aa55c8e2f7a3 by Masahiro Yamada
kbuild: handle C=... and M=... after entering into build directory
[10] commit ab7474ea5361 by Borislav Petkov
Kbuild: Ignore GREP_OPTIONS env variable
To use relative path feature, tools/Makefile and scripts/Makefile.autoconf
must be tweaked.
Now config_cmd_defaults.h is empty so it can be deleted safely.
This commit enables Kconfig.
Going forward, we use Kconfig for the board configuration.
mkconfig will never be used. Nor will include/config.mk be generated.
Kconfig must be adjusted for U-Boot because our situation is
a little more complicated than Linux Kernel.
We have to generate multiple boot images (Normal, SPL, TPL)
from one source tree.
Each image needs its own configuration input.
Usage:
Run "make <board>_defconfig" to do the board configuration.
It will create the .config file and additionally spl/.config, tpl/.config
if SPL, TPL is enabled, respectively.
You can use "make config", "make menuconfig" etc. to create
a new .config or modify the existing one.
Use "make spl/config", "make spl/menuconfig" etc. for spl/.config
and do likewise for tpl/.config file.
The generic syntax of configuration targets for SPL, TPL is:
<target_image>/<config_command>
Here, <target_image> is either 'spl' or 'tpl'
<config_command> is 'config', 'menuconfig', 'xconfig', etc.
When the configuration is done, run "make".
(Or "make <board>_defconfig all" will do the configuration and build
in one time.)
For futher information of how Kconfig works in U-Boot,
please read the comment block of scripts/multiconfig.py.
By the way, there is another item worth remarking here:
coexistence of Kconfig and board herder files.
Prior to Kconfig, we used C headers to define a set of configs.
We expect a very long term to migrate from C headers to Kconfig.
Two different infractructure must coexist in the interim.
In our former configuration scheme, include/autoconf.mk was generated
for use in makefiles.
It is still generated under include/, spl/include/, tpl/include/ directory
for the Normal, SPL, TPL image, respectively.
