path: root/rules.mk
2011-09-07Makefile : fix generation of cpu related asm-offsets.hStefano Babic
commit 0edf8b5b2fa0d210ebc4d6da0fd1aceeb7e44e47 breaks building on a different directory with the O= parameter. The patch wil fix this issue, generating always asm-offsets.h before the other targets. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Matthias Weisser <weisserm@arcor.de> CC: Wolfgang Denk <wd@denx.de>
2011-07-28rules.mk: replace GNU specific \w with POSIX equivalantJeroen Hofstee
If sed does not support the GNU \w regex extension, build attempts lead to circular dependency warnings and finally build failure (crc32.c not found). Build output before and after the patch on FreeBSD is at: http://lists.denx.de/pipermail/u-boot/2011-June/095235.html Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2011-07-14build: Add targets for auto gen of asm-offsets.h and use it in imx35Matthias Weisser
asm-offsets.h should be auto generated. This patch adds two rules to rules.mk which makes this possible and removes the rules on imx35. Signed-off-by: Matthias Weisser <weisserm@arcor.de> Acked-by: Stefano Babic <sbabic@denx.de>
2010-10-06rules.mk: make sure we always create a .depend fileWolfgang Denk
There are some cases where "make depend" would always run when entering a directory. This happened when both the $(SRCS) and $(HOSTSRCS) lists were empty (which is for example typical for the examples/api/ directory). Avoid this by making sure that a ".depend" file gets always created, even if empty. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2009-12-02makefiles: fixes for building build toolsScott Wood
Currently, some of the tools instead set CC to be HOSTCC in order to re-use some pattern rules -- but this fails when the user overrides CC on the make command line. Also, the HOSTCFLAGS in tools/Makefile are currently not being used because config.mk overwrites them. This patch adds static pattern rules for files that have been requested to be built with the native compiler using $(HOSTSRCS) and $(HOSTOBJS), and converts the tools to use them. It restores easylogo to using the host compiler, which was broken by commit 38d299c2db81bd889c601b5dfc12c4e83ef83333 (if this was an intentional change, please let me know -- but it seems to be a build tool). It restores -pedantic and the special flags for darwin and cygwin that were requested in tools/makefile (but keeps the flags added by config.mk) -- hopefully someone can test this on those platforms. It no longer conditionalizes -pedantic on not being darwin; it wasn't clear that that was intentional, and unless there's a real problem it's just inviting people to contribute non-pedantic patches to those files (I'm not a fan of -pedantic personally, but if it's on for one platform it should be on for all). HOST_LDFLAGS is renamed HOSTLDFLAGS for consistency with the previous HOST_CFLAGS to HOSTCFLAGS rename. A new HOSTCFLAGS_NOPED is made available for those files which currently cannot be built with -pedantic, and replaces the old FIT_CFLAGS. imls now uses the cross compiler properly, rather than by trying to reconstruct CC using the typoed $(CROSS_COMPILER). envcrc.c is now dependency-processed unconditionally -- previously it would be built without being on (HOST)SRCS if CONFIG_ENV_IS_EMBEDDED was not selected. Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-07-23unify HOST_CFLAGS and HOSTCFLAGSMike Frysinger
The top build system sets up HOSTCFLAGS a bit and exports it, but other places use HOST_CFLAGS instead. Unify the two as HOSTCFLAGS so that the values stay in sync. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
