path: root/rtc
2006-05-03Write RTC seconds first to maintain settings integrity perWolfgang Denk
Maxim/Dallas DS1306 data sheet. Patch by Alan J. Luse, 02 May 2006
2006-04-16Some code cleanupWolfgang Denk
2006-03-14Add support for DS1374 RTC chip.Marian Balakowicz
2006-03-12Coding Style cleanupWolfgang Denk
2006-03-12Add missing Blackfin files.Wolfgang Denk
2006-03-12Add ADI Blackfin supportWolfgang Denk
- add support for Analog Devices Blackfin BF533 CPU - add support for the ADI BF533 Stamp uClinux board - add support for the ADI BF533 EZKit board Patches by Richard Klingler, June 11th 2005:
2006-03-11Some code cleanup for GCC 4.xWolfgang Denk
2005-12-04Fix data overflow (typo?) in rtc/ds1302.cWolfgang Denk
2005-04-03Minor cleanupwdenk
2005-03-17* Fix RTC configuration for PPChameleon boardwdenk
* Cleanup, fix typo in include/configs/TQM5200.h
2004-10-10Code Cleanupwdenk
Patch by Gary Jennejohn, 04 Oct 2004: - fix I2C on at91rm9200 - add support for Ricoh RS5C372A RTC
2004-06-09* Patch by Tom Armistead, 04 Jun 2004:wdenk
Add support for MAX6900 RTC * Patches by Ladislav Michl, 03 Jun 2004: - fix cfi_flash.c on LE systems - let 'make mrproper' delete u-boot.img as well - turn printf into debug in cfi_flash.c
2004-03-23* Patches by Thomas Viehweger, 16 Mar 2004:wdenk
- show PCI clock frequency on MPC8260 systems - add FCC_PSMR_RMII flag for HiP7 processors - in do_jffs2_fsload(), take load address from load_addr if not set explicit, update load_addr otherwise - replaced printf by putc/puts when no formatting is needed (smaller code size, faster execution)
2004-03-14* Patch by Philippe Robin, 09 Mar 2004:wdenk
Added ARM Integrator AP, CP and Versatile PB926EJ-S Reference Platform support. * Patch by Masami Komiya, 08 Mar 2004: Don't overwrite server IP address or boot file name when the boot server does not return values * Patch by listmember@orkun.us, 5 Mar 2004: Removed compile time restriction on CFG_I2C_SPEED for DS1338 RTC
2004-02-23* Patches by Reinhard Meyer, 14 Feb 2004:wdenk
- update board/emk tree; use common flash driver - Corrected tested bits in machine check exception in cpu/mpc5xxx/traps.c [adapted for other PPC CPUs -- wd] - Added support for the M48T08 on the EVAL5200 board in rtc/mk48t59.c * Patch by Jon Diekema, 13 Feb 2004: Call show_boot_progress() whenever POST "FAILED" is printed. * Patch by Nishant Kamat, 13 Feb 2004: Add support for TI OMAP1610 H2 Board Fixes for cpu/arm926ejs/interrupt.c (based on Richard Woodruff's patch for arm925, 16 Oct 03) Fix for a timer bug in OMAP1610 Innovator Add support for CS0 (ROM)/CS3 (Flash) boot in OMAP1610 Innovator and H2 * Patches by Stephan Linz, 12 Feb 2004: - add support for NIOS timer with variable period preload counter value - prepare POST framework support for NIOS targets * Patch by Denis Peter, 11 Feb 2004: add POST support for the MIP405 board
2004-02-23* CVS add missing fileswdenk
* Cleanup compiler warnings * Fix problem with side effects in macros in include/usb.h * Patch by David Benson, 13 Nov 2003: bug 841358 - fix TFTP download size limit * Fixing bug 850768: improper flush_cache() in load_serial() * Fixing bug 834943: MPC8540 - missing volatile declarations * Patch by Stephen Williams, 09 Feb 2004: Add support for Xilinx SystemACE chip: - New files common/cmd_ace.c and include/systemace.h - Hook systemace support into cmd_fat and the partition manager * Patch by Travis Sawyer, 09 Feb 2004: Add bi_opbfreq & bi_iic_fast to 440GX bd_info as needed for Linux
2004-02-12Last minute fixes / cleanup.U-Boot-1_0_2wdenk
2004-02-10* Patch by Jian Zhang, 3 Feb 2004:wdenk
- Changed the incorrect FAT12BUFSIZE - data_begin in fsdata can be negative. Changed it to be short. * Code cleanup
2004-02-09Patches by Stephan Linz, 30 Jan 2004:wdenk
1: - board/altera/common/flash.c:flash_erase(): o allow interrupts befor get_timer() call o check-up each erased sector and avoid unexpected timeouts - board/altera/dk1c20/dk1s10.c:board_early_init_f(): o enclose sevenseg_set() in cpp condition - remove the ASMI configuration for DK1S10_standard_32 (never present) - fix some typed in mistakes in the NIOS documentation 2: - split DK1C20 configuration into several header files: o two new files for each NIOS CPU description o U-Boot related part is remaining in DK1C20.h 3: - split DK1S10 configuration into several header files: o two new files for each NIOS CPU description o U-Boot related part is remaining in DK1S10.h 4: - Add support for the Microtronix Linux Development Kit NIOS CPU configuration at the Altera Nios Development Kit, Stratix Edition (DK-1S10) 5: - Add documentation for the Altera Nios Development Kit, Stratix Edition (DK-1S10) 6: - Add support for the Nios Serial Peripharel Interface (SPI) (master only) 7: - Add support for the common U-Boot SPI framework at RTC driver DS1306
2004-01-18Fix typo in Makefile;wdenk
fix problem with PARTNUM detection
2004-01-16[Strange. I _did_ check these in before. Seems SF restored an oldwdenk
version of the repository???] * Patch by Reinhard Meyer, 09 Jan 2004: - add RTC support for MPC5200 based boards (requires RTC_XTAL) * Add support for IDE LED on BMS2003 board (exclusive with status LED!) * Add support for PS/2 keyboard (used with PS/2 multiplexor on BMS2003 board) * Patches by Reinhard Meyer, 4 Jan 2004 + 7 Jan 2004: Add common files for "emk" boards
2003-09-13* Patch by David Müller, 13 Sep 2003:LABEL_2003_09_13_2100wdenk
various changes to VCMA9 board specific files * Add I2C support for MGT5100 / MPC5200
2003-06-26* Patches by Robert Schwebel, 26 Jun 2003:U-Boot-0_4_0wdenk
- logdl - csb226 - innokom * Patch by Pantelis Antoniou, 25 Jun 2003: update NetVia with V2 board support
2003-06-19* Patches by David Müller, 12 Jun 2003:wdenk
- rewrite of the S3C24X0 register definitions stuff - "driver" for the built-in S3C24X0 RTC * Patches by Yuli Barcohen, 12 Jun 2003: - Add MII support and Ethernet PHY initialization for MPC8260ADS board - Fix incorrect SIUMCR initialisation caused by wrong Hard Reset configuration word supplied by FPGA on some MPC8260ADS boards * Patch by Pantelis Antoniou, 10 Jun 2003: Unify status LED interface
2003-06-18Add support for DS12887 RTC; add RTC support for ATC boardwdenk
2003-05-20* Patch by David Updegraff, 22 Apr 2003:LABEL_2003_05_20_1630wdenk
update for CrayL1 board * Patch by Pantelis Antoniou, 21 Apr 2003: add boot support for ARTOS (a proprietary OS) * Patch by Steven Scholz, 11 Apr 2003: Add support for RTC DS1338 * Patch by Rod Boyce, 24 Jan 2003: Fix counting of extended partitions in diskboot command
2003-03-06* Patches by David Müller, 31 Jan 2003:LABEL_2003_03_06_2255wdenk
- minimal setup for CardBus bridges - add EEPROM read/write support in the CS8900 driver - add support for the builtin I2C controller in the Samsung s3c24x0 chips - add support for MPL's VCMA9 (Samsung s3c2410 based) board * Patch by Steven Scholz, 04 Feb 2003: add support for RTC DS1307 * Patch by Reinhard Meyer, 5 Feb 2003: fix PLPRCR/SCCR init sequence on 8xx to allow for changes of EBDF by software * Patch by Vladimir Gurevich, 07 Feb 2003: "API-compatibility patch" for 4xx I2C driver
2002-10-26Initial revisionwdenk
2002-09-17Initial revisionwdenk
2002-08-21Initial revisionwdenk
