path: root/rtc/pcf8563.c
2007-11-25drivers/rtc : move rtc drivers to drivers/rtcJean-Christophe PLAGNIOL-VILLARD
2007-07-10cpu/ rtc/ include/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09rtc/: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04rtc/: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2004-03-23* Patches by Thomas Viehweger, 16 Mar 2004:wdenk
- show PCI clock frequency on MPC8260 systems - add FCC_PSMR_RMII flag for HiP7 processors - in do_jffs2_fsload(), take load address from load_addr if not set explicit, update load_addr otherwise - replaced printf by putc/puts when no formatting is needed (smaller code size, faster execution)
