path: root/rtc/m41t11.c
2007-11-25drivers/rtc : move rtc drivers to drivers/rtcJean-Christophe PLAGNIOL-VILLARD
2007-07-10cpu/ rtc/ include/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09rtc/: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04rtc/: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2005-03-17* Fix RTC configuration for PPChameleon boardwdenk
* Cleanup, fix typo in include/configs/TQM5200.h
