path: root/rtc/ds174x.c
2007-07-10cpu/ rtc/ include/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09rtc/: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04rtc/: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
