2003-06-27 | * Code cleanup:LABEL_2003_06_27_2340 | wdenk | |
- remove trailing white space, trailing empty lines, C++ comments, etc. - split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c) * Patches by Kenneth Johansson, 25 Jun 2003: - major rework of command structure (work done mostly by Michal Cendrowski and Joakim Kristiansen) | |||
2003-03-12 | * Patch by Josef Wagner, 12 Mar 2003: | wdenk | |
- 16/32 MB and 50/80 MHz support with auto-detection for IP860 - ETH05 and BEDBUG support for CU824 - added support for MicroSys CPC45 - new BOOTROM/FLASH0 and DOC base for PM826 * Patch by Robert Schwebel, 12 Mar 2003: Fix the chpart command on innokom board * Name cleanup: mv include/asm-i386/ppcboot-i386.h include/asm-i386/u-boot-i386.h s/PPCBoot/U-Boot/ in some files s/pImage/uImage/ in some files * Patch by Detlev Zundel, 15 Jan 2003: Fix '' command line quoting * Patch by The LEOX team, 19 Jan 2003: - add support for the ELPT860 board - add support for Dallas ds164x RTC |
