2007-07-04 | rtc/: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*). | Jon Loeliger | |
This is a compatibility step that allows both the older form and the new form to co-exist for a while until the older can be removed entirely. All transformations are of the form: Before: #if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) After: #if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT) Signed-off-by: Jon Loeliger <jdl@freescale.com> | |||
2002-08-21 | Initial revision | wdenk | |
