path: root/ppc_config.mk
2009-07-21Move architecture specific config.mk files into subdirsPeter Tyser
This cleans up U-Boot's toplevel directory a bit and makes the architecture 'config.mk' file naming and location similar to board and cpu 'config.mk' files Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-07-19push CROSS_COMPILE out to $(ARCH)_config.mkMike Frysinger
Each arch should handle setting a proper default CROSS_COMPILE value in their own config.mk file rather than having to maintain a large ugly list in the Makefile. By using conditional assignment, we don't have to worry about the variable already being set (env/cmdline/etc...). The common config.mk file takes care of exporting CROSS_COMPILE already, and while a few variables (toolchain ones) utilize CROSS_COMPILE before including the arch config.mk, they do so with deferred assignment. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-09-07config.mk: Move arch-specific condition to $(ARCH)_config.mkShinya Kuribayashi
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2002-11-10* Vince Husovsky, 7 Nov 2002:LABEL_2002_11_10_2310wdenk
Add "-n" to linker options to get rid of "Not enough room for program headers" problem * Patch by David Müller, 05 Nov 2002 Rename CONFIG_PLL_INPUT_FREQ to CONFIG_SYS_CLK_FREQ so we can use an already existing name * Patch by Pierre Aubert, 05 Nov 2002 Hardware related improvements in FDC boot code * Patch by Holger Schurig, 5 Nov 2002: Make the PXA really change it's frequency * Patch by Pierre Aubert, 05 Nov 2002 Add support for slave serial Spartan 2 FPGAs * Fix uninitialized memory (MAC address) in 8xx SCC/FEC ethernet drivers
2002-08-14Initial revisionwdenk
