path: root/post
2008-06-03lwmon5: add memory-pattern-test to FPGA POST.Sascha Laue
2008-05-21Merge branch 'lwmon5' of /home/wd/git/u-boot/projectsWolfgang Denk
2008-05-20POST: mark OCM test as POST_STOPYuri Tikhonov
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
2008-05-20POST: add POST_STOP flagYuri Tikhonov
Don't run futher tests in case of a test fails that is marked as POST_STOP. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-05-20POST: OCM test added.Yuri Tikhonov
Added OCM test to POST layer. This version runs before all other tests but doesn't yet interrupt post sequence on failure. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-05-20POST: typo fixYuri Tikhonov
2008-05-10post/cpu/ppc4xx/Makefile: line length cleanupWolfgang Denk
2008-05-04Prepare for v1.3.3-rc3v1.3.3-rc3Wolfgang Denk
Update ChNAGELOG, minor white space cleanup. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-30lwmon5: fix offset error in sysmon0 POSTSascha Laue
Signed-off-by: Sascha Laue <sascha.laue@liebherr.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-30lwmon5: fix manual merge error in POSTSascha Laue
2008-04-29post/board/lwmon5/sysmon.c: fix manual merge error.Wolfgang Denk
2008-04-29POST: fix Makefiles for mpc8xx, lwmon, and netta POSTs.Yuri Tikhonov
2008-04-28lwmon5: update dsPIC POST spezificationSascha Laue
The specification for the lwmon5 board dsPIC POST got changed. Also add defines for the temperatures and voltages. Signed-off-by: Sascha Laue <sascha.laue@liebherr.com>
2008-04-28Fix watchdog POST for lwmon5Sascha Laue
If the hardware watchdog detects a voltage error, the watchdog sets GPIO62 to low. The watchdog POST has to detect this low level. Signed-off-by: Sascha Laue <leglas0@legpc180.leg.liebherr.i> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-28post: Fix building with O=Kumar Gala
2008-04-26post/Makefile: make sure to use the correct flagsWolfgang Denk
ARFLAGS was not set, which caused "ppc_8xx-ar: creating libgenpost.a" messages to be printed. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-26Coding Style cleanup, update CHANGELOGWolfgang Denk
2008-04-25Merge branch 'master' of /home/wd/git/u-boot/lwmon5Wolfgang Denk
Conflicts: common/cmd_bootm.c common/cmd_log.c include/common.h post/board/lwmon5/Makefile post/board/lwmon5/dsp.c post/board/lwmon5/dspic.c post/board/lwmon5/fpga.c post/board/lwmon5/gdc.c post/board/lwmon5/sysmon.c post/board/lwmon5/watchdog.c Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-22POST: move CONFIG_POST to MakefilesYuri Tikhonov
Introduce the new logical option CONFIG_HAS_POST which is set when the platform has CONFIG_POST set. Use CONFIG_HAS_POST in the post/ Makefiles to determine should the POST libs be compiled for the selected target platform, or not. To avoid breaking u-boot linking process, the empty post/libpost.a file is created for platforms which do not have POSTs. Signed-off-by: Yuri Tikhonov <yur@emcraft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-22POST: preparations for moving CONFIG_POST to MakefilesYuri Tikhonov
Remove CONFIG_POST ifdefs from the post/ source files. Signed-off-by: Yuri Tikhonov <yur@emcraft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-13Fix watchdog POST for lwmon5Sascha Laue
2008-03-26Coding Style cleanyp; update CHANGELOGWolfgang Denk
2008-03-25lwmon5 SYSMON POST: fix handling of negative temperaturesYuri Tikhonov
Fix errors in the LWMON5 Sysmon POST for negative temperatures. Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-03-22Merge branch 'master' of /home/wd/git/u-boot/workWolfgang Denk
2008-03-22LWMON5: fix dsPIC POSTYuri Tikhonov
Add test for DPIC_SYS_ERROR_REG to be zero in the LWMON5 dsPIC POST. Signed-off-by: Yuri Tikhonov <yur@emcraft.com> ---
2008-03-20lwmon5 POST: remove unreachable codeWolfgang Denk
plus some coding style cleanup Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-03-20LWMON5: POST RTC fixYuri Tikhonov
Modify the RTC API to provide one a status for the time reported by the rtc_get() function: 0 - a reliable time is guaranteed, < 0 - a reliable time isn't guaranteed (power fault, clock issues, and so on). The RTC chip drivers are responsible for providing this info if the corresponding chip supports such functionality. If not - always report that the time is reliable. The POST RTC test was modified to detect the RTC faults utilizing this new rtc_get() feature. Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-03-18lwmon5: Fix register test logic to match the specific GDC h/w.Yuri Tikhonov
Signed-off-by: Dmitry Rakhchev <rda@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-03-18Fix backlight in the lwmon5 POST.Yuri Tikhonov
Backlight was switched on even when temperature was too low. Signed-off-by: Dmitry Rakhchev <rda@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-03-18Some fixes to dspic, fpga, and gdc post tests for lwmon5. Disable external ↵Yuri Tikhonov
watch-dog for now. Signed-off-by: Dmitry Rakhchev <rda@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-03-18The patch introduces the CRITICAL feature of POST tests. If the test marked ↵Yuri Tikhonov
as POST_CRITICAL fails then the alternative, post_critical, boot-command is used. If this command is not defined then U-Boot enters into interactive mode. Signed-off-by: Dmitry Rakhchev <rda@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-03-18The patch adds new POST tests for the Lwmon5 board. These are:Yuri Tikhonov
* External Watchdog test; * dsPIC tests; * FPGA test; * GDC test; * Sysmon tests. Signed-off-by: Dmitry Rakhchev <rda@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-03-18Enable CODEC POST with CFG_POST_CODEC rather than with CFG_POST_DSP.Yuri Tikhonov
Backlight was switcehd on even when temperature was too low. Signed-off-by: Dmitry Rakhchev <rda@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-03-18Some fixes to dspic, fpga, and gdc post tests for lwmon5.Yuri Tikhonov
Disable external watch-dog for now. Signed-off-by: Dmitry Rakhchev <rda@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-03-18The patch introduces the CRITICAL feature of POST tests. If the testYuri Tikhonov
marked as POST_CRITICAL fails then the alternative, post_critical, boot-command is used. If this command is not defined then U-Boot enters into interactive mode. Signed-off-by: Dmitry Rakhchev <rda@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-03-18The patch adds new POST tests for the Lwmon5 board.Yuri Tikhonov
These are: * External Watchdog test; * dsPIC tests; * FPGA test; * GDC test; * Sysmon tests. Signed-off-by: Dmitry Rakhchev <rda@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-03-15ppc4xx: program_tlb now uses 64bit physical addessStefan Roese
This patch changes the physical addess parameter from 32bit to 64bit. This is needed for 36bit 4xx platforms to access areas located beyond the 4GB border, like SoC peripherals (EBC etc.). Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-02Fix warnings while compilation of post/drivers/memory.cAnatolij Gustschin
Fix warnings while compilation with new gcc in eldk-4.2 Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-03-02POST: Disable cache while SPR POSTAnatolij Gustschin
Currently (since commit b2e2142c) u-boot crashes on sequoia board while SPR test if CONFIG_4xx_DCACHE is enabled. This patch disables the cache while SPR test. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-02-21Fix CPU POST test failureYuri Tikhonov
The CPU POST test code (run from cpu_post_exec_31()) doesn't follow the ABI carefully, at least the CR3, CR4, and CR5 fields of CR are clobbered by it. The gcc-4.2 with its more aggressive optimization exposes this fact. This patch just saves the CR value before running the test code, so allowing it to do anything it wants with CR. Signed-off-by: Dmitry Rakhchev <rda@emcraft.com> Acked-by: Yuri Tikhonov <yur@emcraft.com> --
2008-02-07Add attribute POST_PREREL to ECC memory POSTLarry Johnson
Signed-off-by: Larry Johnson <lrj@acm.org>
2008-01-16ppc4xx: Refactor ECC POST for AMCC Denali coreLarry Johnson
The ECC POST reported intermittent failures running after power-up on the Korat PPC440EPx board. Even when the test passed, the debugging output occasionally reported additional unexpected ECC errors. This refactoring has three main objectives: (1) minimize the code executed with ECC enabled during the tests, (2) add more checking of the results so any unexpected ECC errors would cause the test to fail, and (3) use synchronization (only) where required by the processor. Signed-off-by: Larry Johnson <lrj@acm.org>
2008-01-14ppc_4xx: Fix post spr.c for PPC405Niklaus Giger
post/cpu/ppc4xx/spr.c contained a few checks for registers only present for PPC440 and derivates processor. Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
2008-01-09POST: Execute SPR test after relocationStefan Roese
On LWMON5 we now use d-cache as init-ram and stack. The SPR POST test uses self modifying code and this doesn't work with stack in d-cache, since I can't move the code from d-cache to i-cache. We move the SPR test to be executed a little later, after relocation. Then stack is located in SDRAM and this self-modifying code is no problem anymore. Signed-off-by: Stefan Roese <sr@denx.de>
2007-12-27Cosmetic changes to ECC POST for AMCC Denali coreLarry Johnson
2007-12-27ppc4xx: Fix compilation problem in 405 cache POST testStefan Roese
