path: root/post
2008-02-07Add attribute POST_PREREL to ECC memory POSTLarry Johnson
Signed-off-by: Larry Johnson <lrj@acm.org>
2008-01-16ppc4xx: Refactor ECC POST for AMCC Denali coreLarry Johnson
The ECC POST reported intermittent failures running after power-up on the Korat PPC440EPx board. Even when the test passed, the debugging output occasionally reported additional unexpected ECC errors. This refactoring has three main objectives: (1) minimize the code executed with ECC enabled during the tests, (2) add more checking of the results so any unexpected ECC errors would cause the test to fail, and (3) use synchronization (only) where required by the processor. Signed-off-by: Larry Johnson <lrj@acm.org>
2008-01-14ppc_4xx: Fix post spr.c for PPC405Niklaus Giger
post/cpu/ppc4xx/spr.c contained a few checks for registers only present for PPC440 and derivates processor. Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
2008-01-09POST: Execute SPR test after relocationStefan Roese
On LWMON5 we now use d-cache as init-ram and stack. The SPR POST test uses self modifying code and this doesn't work with stack in d-cache, since I can't move the code from d-cache to i-cache. We move the SPR test to be executed a little later, after relocation. Then stack is located in SDRAM and this self-modifying code is no problem anymore. Signed-off-by: Stefan Roese <sr@denx.de>
2007-12-27Cosmetic changes to ECC POST for AMCC Denali coreLarry Johnson
2007-12-27ppc4xx: Fix compilation problem in 405 cache POST testStefan Roese
2007-12-27ppc4xx: Fix problem in 44x cache POST routineStefan Roese
As repoted by Larry Johnson, running "diag run cache" caused a crash in U-Boot. This problem was introduced by a patch that removed the TLB entry for the cache test after the test has completed. Since this TLB was only setup once, a 2nd attempt to run this cache test failed with a crash. Now this TLB entry is created every time the routine is called. Signed-off-by: Stefan Roese <sr@denx.de>
2007-12-27ppc4xx: Fix lwmon5 compilation problemStefan Roese
Now that the 440EPx ECC test is not board specific anymore remove this Makefile. Signed-off-by: Stefan Roese <sr@denx.de>
2007-12-27Fix/enhance ECC POST for 440EPx/GRxLarry Johnson
This patch allows the ECC POST to be used for different boards with the PPC440 Denali SDRAM controller. Modifications include skipping the test if ECC is not enabled (as for non-ECC DIMMs) and adding synchronization to prevent timing errors. Signed-off-by: Larry Johnson <lrj@acm.org>
2007-12-27PPC4xx: Move/rename ECC POST for 440EPx/GRxLarry Johnson
2007-12-27ppc4xx: use correct io accessors for 4xx ethernet POSTMatthias Fuchs
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2007-10-31ppc4xx: Enable CPU POST test for 4xx with dcache enabledStefan Roese
Now with caches enabled (i- and d-cache) on 44x, we need a chance to disable the cache for the CPU POST tests, since these tests consist of self modifying code. This is done via the new change_tlb() function. Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Change 4xx POST ethernet test to handle cached memory tooStefan Roese
This patch enables the 4xx EMAC POST driver to work too, when dcache is enabled. Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Remove temporary TLB entry in POST cache test only for 440Stefan Roese
2007-10-31ppc4xx: Remove compiler warning from previous commitStefan Roese
2007-10-31ppc4xx: Remove temporary TLB entry in POST cache testStefan Roese
2007-10-31ppc4xx: Fix POST ethernet test for HaleakalaStefan Roese
The POST ethernet test needed to be changed to dynamically determine the count of ethernet devices. This code is cloned from the 4xx ethernet driver. Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31POST: Add 405EX support to 4xx UART POST testStefan Roese
2007-08-25POST: limit memory test area to not touch global data anymoreYuri Tikhonov
As experienced on lwmon5, on some boards the POST memory test can corrupt the global data buffer (bd). This patch fixes this issue by checking and limiting this area. Signed-off-by: Yuri Tikhonov <yur@emcraft.com> Signed-off-by: Stefan Roese <sr@denx.de>
2007-08-14POST: Fix merge problemStefan Roese
2007-08-14Merge with /home/stefan/git/u-boot/zeusStefan Roese
2007-08-14POST: Add option for external ethernet loopback testStefan Roese
When CFG_POST_ETHER_EXT_LOOPBACK is defined, the ethernet POST is not done using an internal loopback connection, but by assuming that an external loopback connector is plugged into the board. Signed-off-by: Stefan Roese <sr@denx.de>
2007-08-14POST: Add ppc405 support to cache and UART POSTStefan Roese
2007-08-10POST: Add ppc4xx UART POST support without external uart clock (lwmon5)Yuri Tikhonov
The patch adds support for UART POST on ppc44x-based boards with no external serial clocks installed. Signed-off-by: Yuri Tikhonov <yur@emcraft.com> Acked-by: Stefan Roese <sr@denx.de>
2007-07-31ppc4xx: Update 440EPx lwmon5 board supportStefan Roese
- Clear ECC status regs after ECC POST test - Set dcbz for ECC generation with caches enabled as default - Code cleanup Signed-off-by: Stefan Roese <sr@denx.de>
2007-07-20POST: Add ECC POST for the lwmon5 boardPavel Kolesnikov
This patch adds ECC Post test for the Lwmon5 board based on PPC440EPx to U-Boot. Signed-off-by: Pavel Kolesnikov <concord@emcraft.com> Acked-by: Yuri Tikhonov <yur@emcraft.com> Acked-by: Stefan Roese <sr@denx.de>
2007-07-13make show_boot_progress () weak.Heiko Schocher
2007-07-10Coding style cleanup; update CHANGELOG.Wolfgang Denk
2007-07-05Merged POST framework with the current TOT.Sergei Poselenov
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
2007-06-22Extend POST support for PPC440Igor Lisitsin
Added memory, CPU, UART, I2C and SPR POST tests for PPC440. Signed-off-by: Igor Lisitsin <igor@emcraft.com> --
2007-03-19Remove obsoleted POST files.Wolfgang Denk
2007-03-06Restructure POST directory to support of other CPUs, boards, etc.Wolfgang Denk
2005-07-28Fix sysmon POST problem: check I2C error codesWolfgang Denk
This fixes a problem of displaying bogus voltages when the voltages are so low that the I2C devices start failing while the rest of the system keeps running.
2005-06-05Fix watchdog reset problems on LWMON boardwdenk
2004-09-08* Patch by Detlev Zundel, 08 Sep 2004:LABEL_2004_09_09_0000wdenk
Update etags build target * Improve NetConsole support: add support for broadcast destination address and buffered input. * Cleanup compiler warnings for GCC 3.3.x and later * Fix problem in cmd_jffs2.c introduced by CFG_JFFS_SINGLE_PART patch
2004-08-01* Code cleanupwdenk
* Patch by Sascha Hauer, 28 Jun: - add generic support for Motorola i.MX architecture - add support for mx1ads, mx1fs2 and scb9328 boards * Patches by Marc Leeman, 23 Jul 2004: - Add define for the PCI/Memory Buffer Configuration Register - corrected comments in cpu/mpc824x/cpu_init.c * Add support for multiple serial interfaces (for example to allow modem dial-in / dial-out)
2004-06-07Patch by Pantelis Antoniou, 5 May 2004:wdenk
- Intracom board update. - Add Codec POST.
2004-04-15* Patches by Pantelis Antoniou, 30 Mar 2004:wdenk
- add support for the Epson 156x series of graphical displays (These displays are serial and not suitable for using a normal framebuffer console on them) - add infrastructure needed in order to POST any DSPs in a board
2004-03-17Patch by Pierre Aubert, 15 Mar 2004:wdenk
Fix buffer overflow in IDE identification
2004-02-23* Patches by Reinhard Meyer, 14 Feb 2004:wdenk
- update board/emk tree; use common flash driver - Corrected tested bits in machine check exception in cpu/mpc5xxx/traps.c [adapted for other PPC CPUs -- wd] - Added support for the M48T08 on the EVAL5200 board in rtc/mk48t59.c * Patch by Jon Diekema, 13 Feb 2004: Call show_boot_progress() whenever POST "FAILED" is printed. * Patch by Nishant Kamat, 13 Feb 2004: Add support for TI OMAP1610 H2 Board Fixes for cpu/arm926ejs/interrupt.c (based on Richard Woodruff's patch for arm925, 16 Oct 03) Fix for a timer bug in OMAP1610 Innovator Add support for CS0 (ROM)/CS3 (Flash) boot in OMAP1610 Innovator and H2 * Patches by Stephan Linz, 12 Feb 2004: - add support for NIOS timer with variable period preload counter value - prepare POST framework support for NIOS targets * Patch by Denis Peter, 11 Feb 2004: add POST support for the MIP405 board
2004-02-20Add Auto-MDIX support for INCA-IPLABEL_2004_02_20_2310wdenk
2003-09-10* Patches by Denis Peter, 9 Sep 2003:U-Boot-0_4_8wdenk
add FAT support for IDE, SCSI and USB * Patches by Gleb Natapov, 2 Sep 2003: - cleanup of POST code for unsupported architectures - MPC824x locks way0 of data cache for use as initial RAM; this patch unlocks it after relocation to RAM and invalidates the locked entries. * Patch by Gleb Natapov, 30 Aug 2003: new I2C driver for mpc107 bridge. Now works from flash. * Patch by Dave Ellis, 11 Aug 2003: - JFFS2: fix typo in common/cmd_jffs2.c - JFFS2: fix CFG_JFFS2_SORT_FRAGMENTS option - JFFS2: remove node version 0 warning - JFFS2: accept JFFS2 PADDING nodes - SXNI855T: add AM29LV800 support - SXNI855T: move environment from EEPROM to flash - SXNI855T: boot from JFFS2 in NOR or NAND flash * Patch by Bill Hargen, 11 Aug 2003: fixes for I2C on MPC8240 - fix i2c_write routine - fix iprobe command - eliminates use of global variables, plus dead code, cleanup.
2003-07-24* Implement new mechanism to export U-Boot's functions to standalonewdenk
applications: instead of using (PPC-specific) system calls we now use a jump table; please see doc/README.standalone for details * Patch by Dave Westwood, 24 Jul 2003: added support for Unity OS (a proprietary OS)
2003-07-17* Patch by Martin Krause, 17 Jul 2003:wdenk
add delay to get I2C working with "imm" command and s3c24x0_i2c.c * Patch by Richard Woodruff, 17 July 03: - Fixed bug in OMAP1510 baud rate divisor settings. * Patch by Nye Liu, 16 July 2003: MPC860FADS fixes: - add MPC86xADS support (uses MPC86xADS.h) - add 866P/T core support (also MPC859T/MPC859DSL/MPC852T) o PLPRCR changes o BRG changes (EXTAL/XTAL restricted to 10MHz) o don't trust gclk() software measurement by default, depend on CONFIG_8xx_GCLK_FREQ - add DRAM SIMM not installed detection - use more "correct" SDRAM initialization sequence - allow different SDRAM sizes (8xxADS has 8M) - default DER is 0 - remove unused MAMR defines from FADS860T.h (all done in fads.c) - rename MAMR/MBMR defines to be more consistent. Should eventually be merged into MxMR to better reflect the PowerQUICC datasheet. * Patch by Yuli Barcohen, 16 Jul 2003: support new Motorola PQ2FADS-ZU evaluation board which replaced MPC8260ADS and MPC8266ADS
