path: root/post
2022-01-18common: remove bedbug debugger supportOvidiu Panait
Commit 98f705c9cefd ("powerpc: remove 4xx support") removed (in 2017) the last code that made use of bedbug debugger support. Since there aren't any boards left that define either CONFIG_CMD_BEDBUG or a real bedbug_init(), drop this feature from u-boot. Signed-off-by: Ovidiu Panait <ovidiu.panait@windriver.com> Reviewed-by: Thomas Huth <thuth@redhat.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2021-08-30global: Remove unused or unnecessary CONFIG symbols related to DDRTom Rini
These symbols are now either unused or were only used within the config file to determine other logic, which could be done in a way that doesn't further pollute the CONFIG namespace. Signed-off-by: Tom Rini <trini@konsulko.com>
2021-02-02common: Drop asm/global_data.h from common headerSimon Glass
Move this out of the common header and include it only where needed. In a number of cases this requires adding "struct udevice;" to avoid adding another large header or in other cases replacing / adding missing header files that had been pulled in, very indirectly. Finally, we have a few cases where we did not need to include <asm/global_data.h> at all, so remove that include. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2021-01-15common: board_r: Drop initr_post_backlog wrapperOvidiu Panait
Add a return value to post_output_backlog and use it directly in the post-relocation init sequence, rather than using a wrapper stub. Signed-off-by: Ovidiu Panait <ovidiu.panait@windriver.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-10-23post: remove redundant conditionHeinrich Schuchardt
(A && A == 0x20) is only true for (A == 0x20). Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-07-17treewide: convert bd_t to struct bd_info by coccinelleMasahiro Yamada
The Linux coding style guide (Documentation/process/coding-style.rst) clearly says: It's a **mistake** to use typedef for structures and pointers. Besides, using typedef for structures is annoying when you try to make headers self-contained. Let's say you have the following function declaration in a header: void foo(bd_t *bd); This is not self-contained since bd_t is not defined. To tell the compiler what 'bd_t' is, you need to include <asm/u-boot.h> #include <asm/u-boot.h> void foo(bd_t *bd); Then, the include direcective pulls in more bloat needlessly. If you use 'struct bd_info' instead, it is enough to put a forward declaration as follows: struct bd_info; void foo(struct bd_info *bd); Right, typedef'ing bd_t is a mistake. I used coccinelle to generate this commit. The semantic patch that makes this change is as follows: <smpl> @@ typedef bd_t; @@ -bd_t +struct bd_info </smpl> Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
2020-05-18common: Drop log.h from common headerSimon Glass
Move this header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop bootstage.h from common headerSimon Glass
Move this fairly uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-02-05dm: core: Create a new header file for 'compat' featuresSimon Glass
At present dm/device.h includes the linux-compatible features. This requires including linux/compat.h which in turn includes a lot of headers. One of these is malloc.h which we thus end up including in every file in U-Boot. Apart from the inefficiency of this, it is problematic for sandbox which needs to use the system malloc() in some files. Move the compatibility features into a separate header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-01-17common: Drop CONFIG_POST_STD/ALT_LISTSimon Glass
These CONFIG options are not used anymore. CONFIG_POST_ALT_LIST just causes CONFIG_POST_STD_LIST to be set and it causes tests.c to be compiled. So just make compiling tests.c unconditional. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-12-02common: Move enable/disable_interrupts out of common.hSimon Glass
Move these two functions into the irq_funcs.h header file. Also move interrupt_handler_t as this is used by the irq_install_handler() function. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02common: Move ARM cache operations out of common.hSimon Glass
These functions are CPU-related and do not use driver model. Move them to cpu_func.h Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02common: Move some cache and MMU functions out of common.hSimon Glass
These functions belong in cpu_func.h. Another option would be cache.h but that code uses driver model and we have not moved these cache functions to use driver model. Since they are CPU-related it seems reasonable to put them here. Move them over. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02arm: powerpc: Tidy up code style for cache functionsSimon Glass
Remove the unwanted space before the bracket. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02common: Move get_ticks() function out of common.hSimon Glass
This function belongs in time.h so move it over and add a comment. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-08-11env: Move env_get_f() to env.hSimon Glass
Move this function over to the new header file. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2019-01-15kbuild: add .SECONDARY special target to scripts/Kbuild.includeMasahiro Yamada
Based on the following Linux commits: - 54a702f70589 ("kbuild: mark $(targets) as .SECONDARY and remove .PRECIOUS markers") - 8e9b61b293d9 ("kbuild: move .SECONDARY special target to Kbuild.include") GNU Make automatically deletes intermediate files that are updated in a chain of pattern rules. Example 1) %.dtb.o <- %.dtb.S <- %.dtb <- %.dts Example 2) %.o <- %.c <- %.c_shipped A couple of makefiles mark such targets as .PRECIOUS to prevent Make from deleting them, but the correct way is to use .SECONDARY. .SECONDARY Prerequisites of this special target are treated as intermediate files but are never automatically deleted. .PRECIOUS When make is interrupted during execution, it may delete the target file it is updating if the file was modified since make started. If you mark the file as precious, make will never delete the file if interrupted. Both can avoid deletion of intermediate files, but the difference is the behavior when Make is interrupted; .SECONDARY deletes the target, but .PRECIOUS does not. The use of .PRECIOUS is relatively rare since we do not want to keep partially constructed (possibly corrupted) targets. .SECONDARY with no prerequisites causes all targets to be treated as secondary. This agrees the policy of Kbuild. scripts/Kbuild.include seems a suitable place to add it because it is included from almost all sub-makes. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-12-07Drop the log bufferSimon Glass
This does not appear to be used by any boards. Before introducing a new log system, remove this old one. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-07-03powerpc: remove 4xx supportHeiko Schocher
There was for long time no activity in the 4xx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 4xx, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-23post: Fix unused variable warning on lwmon5Tom Rini
The variable syndrome_codes is only used when DEBUG is define, add #if guards around it in the same style as the rest of the file. Cc: Stefan Roese <sr@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Stefan Roese <sr@denx.de>
2017-06-16powerpc, 5xxx, 512x: remove support for mpc5xxx and mpc512xHeiko Schocher
There was for long time no activity in the mpx5xxx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in mpc5xxx, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-12powerpc, 8260: remove support for mpc8260Heiko Schocher
There was for long time no activity in the 8260 area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 8260, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-12powerpc, 8xx: remove support for 8xxHeiko Schocher
There was for long time no activity in the 8xx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 8xx, so remove it (with a heavy heart, knowing that I remove here the root of U-Boot). Signed-off-by: Heiko Schocher <hs@denx.de>
2017-04-05Blackfin: RemoveTom Rini
The architecture is currently unmaintained, remove. Cc: Benjamin Matthews <mben12@gmail.com> Cc: Chong Huang <chuang@ucrobotics.com> Cc: Dimitar Penev <dpn@switchfin.org> Cc: Haitao Zhang <hzhang@ucrobotics.com> Cc: I-SYST Micromodule <support@i-syst.com> Cc: M.Hasewinkel (MHA) <info@ssv-embedded.de> Cc: Marek Vasut <marex@denx.de> Cc: Martin Strubel <strubel@section5.ch> Cc: Peter Meerwald <devel@bct-electronic.com> Cc: Sonic Zhang <sonic.adi@gmail.com> Cc: Valentin Yakovenkov <yakovenkov@niistt.ru> Cc: Wojtek Skulski <info@skutek.com> Cc: Wojtek Skulski <skulski@pas.rochester.edu> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-25powerpc: Drop CONFIG_SYS_ALLOC_DPRAMSimon Glass
This is not defined anywhere in U-Boot. Drop this dead code. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-12-04post: cosmetic: fix typoNiko Mauno
Change 'date' to 'data'. Signed-off-by: Tomas Melin <tomas.melin@vaisala.com>
2016-07-16Various, unrelated tree-wide typo fixes.Robert P. J. Day
Fix a number of typos, including: * "compatble" -> "compatible" * "eanbeld" -> "enabled" * "envrionment" -> "environment" * "FTD" -> "FDT" (for "flattened device tree") * "ommitted" -> "omitted" * "overriden" -> "overridden" * "partiton" -> "partition" * "propogate" -> "propagate" * "resourse" -> "resource" * "rest in piece" -> "rest in peace" * "suport" -> "support" * "varible" -> "variable" Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2016-04-01post: Remove references to scrapped "netta" board.Robert P. J. Day
Given that README.scrapyard shows scrapping of netta boards: netta2 powerpc mpc8xx c51c1c9a 2014-07-07 netta powerpc mpc8xx c51c1c9a 2014-07-07 delete netta example from POST tests. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2016-04-01post: Delete unnecessary bitmask of POST_MANUAL from POST_ALWAYSRobert P. J. Day
Since POST_ALWAYS is defined as: #define POST_ALWAYS (POST_NORMAL | \ POST_SLOWTEST | \ POST_MANUAL | \ POST_POWERON ) there is no need to redundantly bitmask it with POST_MANUAL. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2016-04-01post: Remove reference to deleted "lwmon" board from MakefileRobert P. J. Day
POST support for sample lwmon board was removed in commit e5d3078622. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>B
2016-03-22Fix spelling of "transferred".Vagrant Cascadian
Signed-off-by: Vagrant Cascadian <vagrant@debian.org> Acked-by: Marek Vasut <marex@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-12-05mpc8xx: remove stale "lwmon" filesWolfgang Denk
Commit acc2372d "mpc8xx: remove lwmon board support" removed support for the MPC823 based "lwmon" board, but left some board specific POST files. This patch cleans up and removes the now unused files. Signed-off-by: Wolfgang Denk <wd@denx.de>
2015-05-05dm: rtc: Rename mktime() and reduce the number of parametersSimon Glass
Most callers unpack the structure and pass each member. It seems better to pass the whole structure instead, as with the C library. Also add an rtc_ prefix. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de>
2015-05-05dm: rtc: Rename to_tm() to rtc_to_tm() and add error codeSimon Glass
Rename this function so that it is clear that it is provided by the RTC. Also return an error when it cannot function as expected. This is unlikely to occur since it works for dates since 1752 and many RTCs do not support such old dates. Still it is better to be accurate. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de>
2015-04-18net: cosmetic: Fix var naming net <-> eth driversJoe Hershberger
Update the naming convention used in the network stack functions and variables that Ethernet drivers use to interact with it. This cleans up the temporary hacks that were added to this interface along with the DM support. This patch has a few remaining checkpatch.pl failures that would be out of the scope of this patch to fix (drivers that are in gross violation of checkpatch.pl). Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-05powerpc: mpc824x: remove MPC824X cpu supportMasahiro Yamada
All the MPC824X boards are still non-generic boards: A3000, CPC45, CU824, eXalion, MVBLUE, MUSENKI, Sandpoint824x, utx8245 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Josef Wagner <Wagner@Microsys.de> Cc: Torsten Demke <torsten.demke@fci.com> Cc: Jim Thompson <jim@musenki.com> Cc: Greg Allen <gallen@arlut.utexas.edu>
2014-10-25misc: use __weakJeroen Hofstee
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-07-07mpc8xx: remove fads board supportMasahiro Yamada
These boards are old enough and have no maintainers. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-07-07mpc8xx: remove RPXlite_dw, quantum board supportMasahiro Yamada
2014-04-18powerpc: remove RPXClassic, RPXlite boards supportMasahiro Yamada
Enough time has passed since these boards were moved to Orphan. Remove. - Remove board/RPXlite/* - Remove board/RPXClassic/* - Remove include/configs/RPXlite.h - Remove include/configs/RPXClassic.h - Clean-up defined(CONFIG_RPXCLASSIC) - Move the entry from boards.cfg to doc/README.scrapyard Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-04-18powerpc: remove MBX and MBX860T boards supportMasahiro Yamada
Enough time has passed since these boards were moved to Orphan. Remove. - Remove board/mbx8xx/* - Remove include/configs/{MBX.h,MBX860T.h} - Clean-up if defined(CONFIG_MBX) - Move the entries from boards.cfg to doc/README.scrapyard Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-04kbuild: post: fix dependency tracking correctlyMasahiro Yamada
$(call if_changed,...) must take FORCE as a prerequite. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-02-19kbuild: use Linux Kernel build scriptsMasahiro Yamada
Now we are ready to switch over to real Kbuild. This commit disables temporary scripts: scripts/{Makefile.build.tmp, Makefile.host.tmp} and enables real Kbuild scripts: scripts/{Makefile.build,Makefile.host,Makefile.lib}. This switch is triggered by the line in scripts/Kbuild.include -build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build.tmp obj +build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build obj We need to adjust some build scripts for U-Boot. But smaller amount of modification is preferable. Additionally, we need to fix compiler flags which are locally added or removed. In Kbuild, it is not allowed to change CFLAGS locally. Instead, ccflags-y, asflags-y, cppflags-y, CFLAGS_$(basetarget).o, CFLAGS_REMOVE_$(basetarget).o are prepared for that purpose. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-02-19kbuild: change out-of-tree buildMasahiro Yamada
This commit changes the working directory where the build process occurs. Before this commit, build process occurred under the source tree for both in-tree and out-of-tree build. That's why we needed to add $(obj) prefix to all generated files in makefiles like follows: $(obj)u-boot.bin: $(obj)u-boot Here, $(obj) is empty for in-tree build, whereas it points to the output directory for out-of-tree build. And our old build system changes the current working directory with "make -C <sub-dir>" syntax when descending into the sub-directories. On the other hand, Kbuild uses a different idea to handle out-of-tree build and directory descending. The build process of Kbuild always occurs under the output tree. When "O=dir/to/store/output/files" is given, the build system changes the current working directory to that directory and restarts the make. Kbuild uses "make -f $(srctree)/scripts/Makefile.build obj=<sub-dir>" syntax for descending into sub-directories. (We can write it like "make $(obj)=<sub-dir>" with a shorthand.) This means the current working directory is always the top of the output directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-02-19Makfile: move suffix rules to Makefile.buildMasahiro Yamada
This commit moves suffix rules from config.mk to scripts/Makefile.build, which will allow us to switch smoothly to real Kbuild. Note1: post/lib_powerpc/fpu/Makefile has its own rule to compile C sources. We need to tweak it to keep the same behavior. Note2: There are two file2 with the same name: arch/arm/lib/crt0.S and eamples/api/crt0.S. To keep the same build behavior, examples/api/Makefile also has to be treaked. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-12-16Makefile: Select objects by CONFIG_ rather than $(ARCH) or $(CPU)Masahiro Yamada
Convert like follows: CPU mpc83xx -> CONFIG_MPC83xx CPU mpc85xx -> CONFIG_MPC85xx CPU mpc86xx -> CONFIG_MPC86xx CPU mpc5xxx -> CONFIG_MPC5xxx CPU mpc8xx -> CONFIG_8xx CPU mpc8260 -> CONFIG_8260 CPU ppc4xx -> CONFIG_4xx CPU x86 -> CONFIG_X86 ARCH x86 -> CONFIG_X86 ARCH powerpc -> CONFIG_PPC Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-12-13post: descend only when CONFIG_HAS_POST is definedMasahiro Yamada
All objects under post/ directory are enabled by CONFIG_HAS_POST. (post/tests.o is enabled by CONFIG_POST_STD_LIST. But CONFIG_POST_STD_LIST depends on CONFIG_HAS_POST.) We can move CONFIG_HAS_POST switch to the top Makefile. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
