path: root/post
2016-07-16Various, unrelated tree-wide typo fixes.Robert P. J. Day
Fix a number of typos, including: * "compatble" -> "compatible" * "eanbeld" -> "enabled" * "envrionment" -> "environment" * "FTD" -> "FDT" (for "flattened device tree") * "ommitted" -> "omitted" * "overriden" -> "overridden" * "partiton" -> "partition" * "propogate" -> "propagate" * "resourse" -> "resource" * "rest in piece" -> "rest in peace" * "suport" -> "support" * "varible" -> "variable" Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2016-04-01post: Remove references to scrapped "netta" board.Robert P. J. Day
Given that README.scrapyard shows scrapping of netta boards: netta2 powerpc mpc8xx c51c1c9a 2014-07-07 netta powerpc mpc8xx c51c1c9a 2014-07-07 delete netta example from POST tests. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2016-04-01post: Delete unnecessary bitmask of POST_MANUAL from POST_ALWAYSRobert P. J. Day
Since POST_ALWAYS is defined as: #define POST_ALWAYS (POST_NORMAL | \ POST_SLOWTEST | \ POST_MANUAL | \ POST_POWERON ) there is no need to redundantly bitmask it with POST_MANUAL. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2016-04-01post: Remove reference to deleted "lwmon" board from MakefileRobert P. J. Day
POST support for sample lwmon board was removed in commit e5d3078622. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>B
2016-03-22Fix spelling of "transferred".Vagrant Cascadian
Signed-off-by: Vagrant Cascadian <vagrant@debian.org> Acked-by: Marek Vasut <marex@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-12-05mpc8xx: remove stale "lwmon" filesWolfgang Denk
Commit acc2372d "mpc8xx: remove lwmon board support" removed support for the MPC823 based "lwmon" board, but left some board specific POST files. This patch cleans up and removes the now unused files. Signed-off-by: Wolfgang Denk <wd@denx.de>
2015-05-05dm: rtc: Rename mktime() and reduce the number of parametersSimon Glass
Most callers unpack the structure and pass each member. It seems better to pass the whole structure instead, as with the C library. Also add an rtc_ prefix. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de>
2015-05-05dm: rtc: Rename to_tm() to rtc_to_tm() and add error codeSimon Glass
Rename this function so that it is clear that it is provided by the RTC. Also return an error when it cannot function as expected. This is unlikely to occur since it works for dates since 1752 and many RTCs do not support such old dates. Still it is better to be accurate. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de>
2015-04-18net: cosmetic: Fix var naming net <-> eth driversJoe Hershberger
Update the naming convention used in the network stack functions and variables that Ethernet drivers use to interact with it. This cleans up the temporary hacks that were added to this interface along with the DM support. This patch has a few remaining checkpatch.pl failures that would be out of the scope of this patch to fix (drivers that are in gross violation of checkpatch.pl). Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-05powerpc: mpc824x: remove MPC824X cpu supportMasahiro Yamada
All the MPC824X boards are still non-generic boards: A3000, CPC45, CU824, eXalion, MVBLUE, MUSENKI, Sandpoint824x, utx8245 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Josef Wagner <Wagner@Microsys.de> Cc: Torsten Demke <torsten.demke@fci.com> Cc: Jim Thompson <jim@musenki.com> Cc: Greg Allen <gallen@arlut.utexas.edu>
2014-10-25misc: use __weakJeroen Hofstee
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-07-07mpc8xx: remove fads board supportMasahiro Yamada
These boards are old enough and have no maintainers. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-07-07mpc8xx: remove RPXlite_dw, quantum board supportMasahiro Yamada
2014-04-18powerpc: remove RPXClassic, RPXlite boards supportMasahiro Yamada
Enough time has passed since these boards were moved to Orphan. Remove. - Remove board/RPXlite/* - Remove board/RPXClassic/* - Remove include/configs/RPXlite.h - Remove include/configs/RPXClassic.h - Clean-up defined(CONFIG_RPXCLASSIC) - Move the entry from boards.cfg to doc/README.scrapyard Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-04-18powerpc: remove MBX and MBX860T boards supportMasahiro Yamada
Enough time has passed since these boards were moved to Orphan. Remove. - Remove board/mbx8xx/* - Remove include/configs/{MBX.h,MBX860T.h} - Clean-up if defined(CONFIG_MBX) - Move the entries from boards.cfg to doc/README.scrapyard Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-04kbuild: post: fix dependency tracking correctlyMasahiro Yamada
$(call if_changed,...) must take FORCE as a prerequite. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-02-19kbuild: use Linux Kernel build scriptsMasahiro Yamada
Now we are ready to switch over to real Kbuild. This commit disables temporary scripts: scripts/{Makefile.build.tmp, Makefile.host.tmp} and enables real Kbuild scripts: scripts/{Makefile.build,Makefile.host,Makefile.lib}. This switch is triggered by the line in scripts/Kbuild.include -build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build.tmp obj +build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build obj We need to adjust some build scripts for U-Boot. But smaller amount of modification is preferable. Additionally, we need to fix compiler flags which are locally added or removed. In Kbuild, it is not allowed to change CFLAGS locally. Instead, ccflags-y, asflags-y, cppflags-y, CFLAGS_$(basetarget).o, CFLAGS_REMOVE_$(basetarget).o are prepared for that purpose. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-02-19kbuild: change out-of-tree buildMasahiro Yamada
This commit changes the working directory where the build process occurs. Before this commit, build process occurred under the source tree for both in-tree and out-of-tree build. That's why we needed to add $(obj) prefix to all generated files in makefiles like follows: $(obj)u-boot.bin: $(obj)u-boot Here, $(obj) is empty for in-tree build, whereas it points to the output directory for out-of-tree build. And our old build system changes the current working directory with "make -C <sub-dir>" syntax when descending into the sub-directories. On the other hand, Kbuild uses a different idea to handle out-of-tree build and directory descending. The build process of Kbuild always occurs under the output tree. When "O=dir/to/store/output/files" is given, the build system changes the current working directory to that directory and restarts the make. Kbuild uses "make -f $(srctree)/scripts/Makefile.build obj=<sub-dir>" syntax for descending into sub-directories. (We can write it like "make $(obj)=<sub-dir>" with a shorthand.) This means the current working directory is always the top of the output directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-02-19Makfile: move suffix rules to Makefile.buildMasahiro Yamada
This commit moves suffix rules from config.mk to scripts/Makefile.build, which will allow us to switch smoothly to real Kbuild. Note1: post/lib_powerpc/fpu/Makefile has its own rule to compile C sources. We need to tweak it to keep the same behavior. Note2: There are two file2 with the same name: arch/arm/lib/crt0.S and eamples/api/crt0.S. To keep the same build behavior, examples/api/Makefile also has to be treaked. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-12-16Makefile: Select objects by CONFIG_ rather than $(ARCH) or $(CPU)Masahiro Yamada
Convert like follows: CPU mpc83xx -> CONFIG_MPC83xx CPU mpc85xx -> CONFIG_MPC85xx CPU mpc86xx -> CONFIG_MPC86xx CPU mpc5xxx -> CONFIG_MPC5xxx CPU mpc8xx -> CONFIG_8xx CPU mpc8260 -> CONFIG_8260 CPU ppc4xx -> CONFIG_4xx CPU x86 -> CONFIG_X86 ARCH x86 -> CONFIG_X86 ARCH powerpc -> CONFIG_PPC Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-12-13post: descend only when CONFIG_HAS_POST is definedMasahiro Yamada
All objects under post/ directory are enabled by CONFIG_HAS_POST. (post/tests.o is enabled by CONFIG_POST_STD_LIST. But CONFIG_POST_STD_LIST depends on CONFIG_HAS_POST.) We can move CONFIG_HAS_POST switch to the top Makefile. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-25post: remove unnecessary include path settingsMasahiro Yamada
2013-11-01post: convert makefiles to Kbuild styleMasahiro Yamada
This commit also deletes post/rules.mk, which in not necessary any more. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-10-14Coding Style cleanup: replace leading SPACEs by TABsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini: Drop changes for PEP 4 following python tools] Signed-off-by: Tom Rini <trini@ti.com>
2013-09-20Cosmetic: Fix a number of typos, no functional changes.Robert P. J. Day
Fix various misspellings of things like "environment", "kernel", "default" and "volatile", and throw in a couple grammar fixes. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2013-05-01post: fix I2C POST failure for devices in CONFIG_SYS_POST_I2C_IGNORESAnatolij Gustschin
Devices in CONFIG_SYS_POST_I2C_IGNORES list may be absent and the rule is not to report I2C POST failure for devices in this list. Currently this doesn't work since probing for these devices isn't done and thus they are not marked as successfully probed. Ignore optional devices when checking for devices that didn't respond. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2012-10-28PPC: remove dead boards (AMX860, c2mon, ETX094, IAD210, LANTEC, SCM)Wolfgang Denk
These boards have long reached EOL, and there has been no indication of any active users of such hardware for years. Get rid of the dead weight. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Wolfgang Grandegger <wg@denx.de>
2012-10-15serial: Remove CONFIG_SERIAL_MULTI from remaining sourcesMarek Vasut
Remove the parts depending either on disabled CONFIG_SERIAL_MULTI or ifdefs around CONFIG_SERIAL_MULTI parts since CONFIG_SERIAL_MULTI is now enabled by default. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de>
2012-03-30post: remove #warning for kirkwood CPUsValentin Longchamp
Since commit 96f5c4b the needed functions (get_ticks() and get_tbclk() ) are defined for kirkwood CPUs as well. This warning is then not relevant anymore. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Holger Brunck <holger.brunck@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com> cc: Albert Aribaud <albert.u.boot@aribaud.net>
2012-03-18bootstage: Replace show_boot_progress/error() with bootstage_...()Simon Glass
These calls should not be made directly any more, since bootstage will call the show_boot_...() functions as needed. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-18bootstage: Convert progress numbers 20-41 to enumsSimon Glass
2012-03-18bootstage: Use show_boot_error() for -ve progress numbersSimon Glass
Rather than the caller negating our progress numbers to indicate an error has occurred, which seems hacky, add a function to indicate this. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-03-12Revert "post/Makefile: Only build FP post tests if enabled via ↵Wolfgang Denk
CONFIG_SYS_POST_FPU" This reverts commit 3e16abe0e468c568b30acb7d8583e3dbed6f177b. The logic of this patch is broken - testing for CONFIG_SYS_POST_FPU in the Makefile cannot work, as this is only a bit that may (or may not) be set in the CONFIG_POST variable. The patch cases build errors on a number of boards, so we revert it. Signed-off-by: Wolfgang Denk <wd@denx.de>
2012-02-12post: add blackfin to the post_time_ms listMike Frysinger
2012-01-13post/Makefile: Only build FP post tests if enabled via CONFIG_SYS_POST_FPUKumar Gala
2011-12-23post/lib_powerpc/multi.c: fix stack overflow errorWolfgang Denk
The code and comment disagreed: the comment claimed that r6...r31 were copied, and consequently the arrays for "src" and "dst" were declared with 26 entries, but the actual code ("lmw r5,0(r3)" and "stmw r5,0(r4)") copied _27_ words (r5 through r31), which resulted in false "POST cpu Error at multi test" messages. Fix the comment and the array sizes. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Kim Phillips <kim.phillips@freescale.com> Cc: Andy Fleming <afleming@gmail.com> Acked-by: Anatolij Gustschin <agust@denx.de> Tested-by: Anatolij Gustschin <agust@denx.de>
2011-12-23post/lib_powerpc/multi.c: code cleanupWolfgang Denk
Clean up and document the code: - get rid of unneeded code block - add comment which code is generated Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Kim Phillips <kim.phillips@freescale.com> Cc: Andy Fleming <afleming@gmail.com> Acked-by: Anatolij Gustschin <agust@denx.de>
2011-12-23post/lib_powerpc/multi.c: make checkpatch cleanWolfgang Denk
2011-12-23PPC: fix "Warning: FOO uses hard float, BAR uses soft float".Wolfgang Denk
It appears that with recent versions of GCC the explicit "-mhard-float" command line option takes precedence over the ``asm(".gnu_attribute 4, 2");'' in the source file, so this no longer helps to avoid the warnings we get when linking code that uses FP instructions with other code that was built using soft-float. We can remove the ".gnu_attribute" (which appears to carry no other information, at least so far) from the object files, but we also have to make sure we don't pull in the __gcc_qsub() and __gcc_qmul() functions from the standard libgcc, as these would again "infect" our linking. We copy this code from: gcc-4.2.2/gcc/config/rs6000/darwin-ldouble.c This old version was chosen because it was still available under a compatible license (GCC v2+). The file was stripped down to the needed parts, and reformatted so it passes checkpatch with only one warning (do not add new typedefs). Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Stefan Roese <sr@denx.de> Cc: Andy Fleming <afleming@gmail.com> Cc: Kim Phillips <kim.phillips@freescale.com> Tested-by: Stefan Roese <sr@denx.de> Tested-by: Anatolij Gustschin <agust@denx.de>
2011-12-11post: fix compile issue for post tests on kirkwoodHolger Brunck
commit f31a911fe (arm, post: add missing post_time_ms for arm) enables get_ticks and get_tbclk for all arm based boards, but kirkwood has currently no implementation for this. So undefine this for kirkwood boards. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> cc: Heiko Schocher <hs@denx.de> cc: Prafulla Wadaskar <prafulla@marvell.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com>
2011-12-10post/post.c: Use lldiv for 64-bit divisionsChristian Riesch
Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Tom Rini <trini@ti.com> Cc: Heiko Schocher <hs@denx.de> Cc: Wolfgang Denk <wd@denx.de>
2011-12-02post/board/lwmon5/gdc.c: Fix GCC 4.6 build warningWolfgang Denk
Fix: gdc.c: In function 'gdc_test_reg_one': gdc.c:66:6: warning: variable 'ret' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2011-11-1620001122-1.c: Fix GCC 4.6 build warningStefan Roese
Fix: 20001122-1.c: In function 'fpu_post_test_math1': 20001122-1.c:37:22: warning: variable 'p' set but not used [-Wunused-but-set-variable] Signed-off-by: Stefan Roese <sr@denx.de>
2011-11-03post/post.c: fix GCC 4.6 build warningsWolfgang Denk
Fix: post.c: In function 'post_log': post.c:425:7: warning: variable 'i' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-11-03post/post.c: CodingStyle cleanupWolfgang Denk
Make checkpatch-clean.. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2011-10-27arm, post: add missing post_time_ms for armHeiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-10-27cosmetic, post: Codingstyle cleanupHeiko Schocher
2011-10-23arm, post, memory: fix bug if sdram base != 0x00000000Heiko Schocher
commit 8d3fcb5e60b6c8e1d530dbc2e2e33ec6a44670da breaks post memory support for sdram base != 0x00000000. Fix this. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Valentin Longchamp <valentin.longchamp@keymile.com> Cc: Holger Brunck <holger.brunck@keymile.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-05POST: add new memory regions testValentin Longchamp
This test is similar to the actual POST memory test but quicker and far less complete. It checks the address and data lines and then only tests some regularly placed sub regions of the RAM. This can be useful when we want to test the RAM but we do not have enough time to run the full memory test. The POST memory test code was rearranged in order to avoid code duplication between the two tests but the memory test functionnality remains the same. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Ackey-by: Mike Frysinger <vapier@gentoo.org>
