path: root/post/tests.c
2008-04-22POST: preparations for moving CONFIG_POST to MakefilesYuri Tikhonov
Remove CONFIG_POST ifdefs from the post/ source files. Signed-off-by: Yuri Tikhonov <yur@emcraft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-03-18The patch adds new POST tests for the Lwmon5 board.Yuri Tikhonov
These are: * External Watchdog test; * dsPIC tests; * FPGA test; * GDC test; * Sysmon tests. Signed-off-by: Dmitry Rakhchev <rda@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-03-18Enable CODEC POST with CFG_POST_CODEC rather than with CFG_POST_DSP.Yuri Tikhonov
2008-02-07Add attribute POST_PREREL to ECC memory POSTLarry Johnson
Signed-off-by: Larry Johnson <lrj@acm.org>
2008-01-09POST: Execute SPR test after relocationStefan Roese
On LWMON5 we now use d-cache as init-ram and stack. The SPR POST test uses self modifying code and this doesn't work with stack in d-cache, since I can't move the code from d-cache to i-cache. We move the SPR test to be executed a little later, after relocation. Then stack is located in SDRAM and this self-modifying code is no problem anymore. Signed-off-by: Stefan Roese <sr@denx.de>
2007-07-20POST: Add ECC POST for the lwmon5 boardPavel Kolesnikov
This patch adds ECC Post test for the Lwmon5 board based on PPC440EPx to U-Boot. Signed-off-by: Pavel Kolesnikov <concord@emcraft.com> Acked-by: Yuri Tikhonov <yur@emcraft.com> Acked-by: Stefan Roese <sr@denx.de>
2007-06-22Extend POST support for PPC440Igor Lisitsin
Added memory, CPU, UART, I2C and SPR POST tests for PPC440. Signed-off-by: Igor Lisitsin <igor@emcraft.com> --
2004-06-07Patch by Pantelis Antoniou, 5 May 2004:wdenk
- Intracom board update. - Add Codec POST.
2004-04-15* Patches by Pantelis Antoniou, 30 Mar 2004:wdenk
- add support for the Epson 156x series of graphical displays (These displays are serial and not suitable for using a normal framebuffer console on them) - add infrastructure needed in order to POST any DSPs in a board
2003-07-14* Patches by Yuli Barcohen, 13 Jul 2003:wdenk
- Correct flash and JFFS2 support for MPC8260ADS - fix PVR values and clock generation for PowerQUICC II family (8270/8275/8280) * Patch by Bernhard Kuhn, 08 Jul 2003: - add support for M68K targets * Patch by Ken Chou, 3 Jul: - Fix PCI config table for A3000 - Fix iobase for natsemi.c (PCI_BASE_ADDRESS_0 is the IO base register for DP83815) * Allow to enable "slow" POST routines by key press on power-on * Fix temperature dependend switching of LCD backlight on LWMON * Tweak output format for LWMON
2003-04-27* LWMON extensions:wdenk
- Splashscreen support - modem support - sysmon support - temperature dependend enabling of LCD * Allow booting from old "PPCBoot" disk partitions * Add support for TQM8255 Board / MPC8255 CPU
2002-12-08* Improve log buffer code; use "loglevel" to decide which messageswdenk
to log on the console, too (like in Linux); get rid of "logstart"
2002-10-07Initial revisionwdenk
