path: root/post/post.c
2008-06-29Configure DSP POST; add watchdog reset to diag commandSascha Laue
Signed-off-by: Sascha Laue <sascha.laue@liebherr.com>
2008-05-20POST: add POST_STOP flagYuri Tikhonov
Don't run futher tests in case of a test fails that is marked as POST_STOP. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-04-22POST: preparations for moving CONFIG_POST to MakefilesYuri Tikhonov
Remove CONFIG_POST ifdefs from the post/ source files. Signed-off-by: Yuri Tikhonov <yur@emcraft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-03-18The patch introduces the CRITICAL feature of POST tests. If the testYuri Tikhonov
marked as POST_CRITICAL fails then the alternative, post_critical, boot-command is used. If this command is not defined then U-Boot enters into interactive mode. Signed-off-by: Dmitry Rakhchev <rda@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2007-07-13make show_boot_progress () weak.Heiko Schocher
2007-06-22Extend POST support for PPC440Igor Lisitsin
Added memory, CPU, UART, I2C and SPR POST tests for PPC440. Signed-off-by: Igor Lisitsin <igor@emcraft.com> --
2007-03-06Restructure POST directory to support of other CPUs, boards, etc.Wolfgang Denk
2004-02-23* Patches by Reinhard Meyer, 14 Feb 2004:wdenk
- update board/emk tree; use common flash driver - Corrected tested bits in machine check exception in cpu/mpc5xxx/traps.c [adapted for other PPC CPUs -- wd] - Added support for the M48T08 on the EVAL5200 board in rtc/mk48t59.c * Patch by Jon Diekema, 13 Feb 2004: Call show_boot_progress() whenever POST "FAILED" is printed. * Patch by Nishant Kamat, 13 Feb 2004: Add support for TI OMAP1610 H2 Board Fixes for cpu/arm926ejs/interrupt.c (based on Richard Woodruff's patch for arm925, 16 Oct 03) Fix for a timer bug in OMAP1610 Innovator Add support for CS0 (ROM)/CS3 (Flash) boot in OMAP1610 Innovator and H2 * Patches by Stephan Linz, 12 Feb 2004: - add support for NIOS timer with variable period preload counter value - prepare POST framework support for NIOS targets * Patch by Denis Peter, 11 Feb 2004: add POST support for the MIP405 board
2003-07-24* Implement new mechanism to export U-Boot's functions to standalonewdenk
applications: instead of using (PPC-specific) system calls we now use a jump table; please see doc/README.standalone for details * Patch by Dave Westwood, 24 Jul 2003: added support for Unity OS (a proprietary OS)
2003-07-15* Patches by Martin Krause, 14 Jul 2003:wdenk
- add I2C support for s3c2400 systems (trab board) - (re-) add "ping" to command table * Fix handling of "slow" POST routines
2003-07-14* Patches by Yuli Barcohen, 13 Jul 2003:wdenk
- Correct flash and JFFS2 support for MPC8260ADS - fix PVR values and clock generation for PowerQUICC II family (8270/8275/8280) * Patch by Bernhard Kuhn, 08 Jul 2003: - add support for M68K targets * Patch by Ken Chou, 3 Jul: - Fix PCI config table for A3000 - Fix iobase for natsemi.c (PCI_BASE_ADDRESS_0 is the IO base register for DP83815) * Allow to enable "slow" POST routines by key press on power-on * Fix temperature dependend switching of LCD backlight on LWMON * Tweak output format for LWMON
2003-04-27* LWMON extensions:wdenk
- Splashscreen support - modem support - sysmon support - temperature dependend enabling of LCD * Allow booting from old "PPCBoot" disk partitions * Add support for TQM8255 Board / MPC8255 CPU
2002-12-08* Improve log buffer code; use "loglevel" to decide which messageswdenk
to log on the console, too (like in Linux); get rid of "logstart"
2002-11-21* Added support for both PCMCIA slots (at the same time!) on MPC8xxLABEL_2002_11_22_0015wdenk
* Patch by Rod Boyce, 21 Nov 2002: fix PCMCIA on MBX8xx board * Patch by Pierre Aubert , 21 Nov 2002 Add CFG_CPM_POST_WORD_ADDR to make the offset of the bootmode word in DPRAM configurable
2002-11-05* Add support for log buffer which can be passed to Linux kernel'sLABEL_2002_11_05_1735wdenk
syslog mechanism; used especially for POST results. * Patch by Klaus Heydeck, 31 Oct 2002: Add initial support for kup4k board
2002-09-12Initial revisionwdenk
