These calls should not be made directly any more, since bootstage
will call the show_boot_...() functions as needed.
Rather than the caller negating our progress numbers to indicate an
error has occurred, which seems hacky, add a function to indicate this.
commit f31a911fe (arm, post: add missing post_time_ms for arm)
enables get_ticks and get_tbclk for all arm based boards,
but kirkwood has currently no implementation for this. So
undefine this for kirkwood boards.
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
cc: Heiko Schocher <hs@denx.de>
cc: Prafulla Wadaskar <prafulla@marvell.com>
cc: Valentin Longchamp <valentin.longchamp@keymile.com>
Signed-off-by: Christian Riesch <christian.riesch@omicron.at>
Cc: Tom Rini <trini@ti.com>
Fix:
post.c: In function 'post_log':
post.c:425:7: warning: variable 'i' set but not used
[-Wunused-but-set-variable]
Make checkpatch-clean..
Acked-by: Marek Vasut <marek.vasut@gmail.com>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Some boards have the environment variables defined in a slow EEPROM. post_run
accesses these environment variables to define which tests have to be run (in
post_get_flags). This is very slow before the code relocation on some boards
with a slow I2C EEPROM for environement variables.
This patch adds a config option to skip the fetching of the test flags in the
environment variables. The test flags assigned to the tests then only are the
ones statically defined for the test in post/tests.c.
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
The current post_log_word in global data is currently split into 2x
16 bits: half for the test start, half for the test success.
Since we alredy have more than 16 POST tests defined and more could
be defined, this may result in an overflow and the post_output_backlog
would not work for the tests defined further of these 16 positions.
An additional field is added to global data so that we can now support up
to 32 (depending of architecture) tests. The post_log_word is only used
to record the start of the test and the new field post_log_res for the
test success (or failure). The post_output_backlog is for this change
also adapted.
The post.c code is missing braces around the pass case, and as a
result, the diagnostic function will post both fail and pass for
a failed test. The reason for this bug is probably the incorrect
indentation used, so when reading the code it seems like there
are proper braces.
Indent the code to the correct depth and put proper braces around
the "else" branch of the "if" statement.
Signed-off-by: James Kosin <jkosin@intcomgrp.com>
We've got a handy dandy macro already for calculating the number of
elements in an array, so use it.
Now that we have the generic GPIO layer, we can easily provide a common
implementation for the post_hotkeys_pressed() function based on it.
By now, the majority of architectures have working relocation
support, so the few remaining architectures have become exceptions.
To make this more obvious, we make working relocation now the default
case, and flag the remaining cases with CONFIG_NEEDS_MANUAL_RELOC.
Tested-by: Heiko Schocher <hs@denx.de>
Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
While running from flash, i. e. before relocation, we have only a
limited C runtime environment without writable data segment. In this
phase, some configurations (for example with environment in EEPROM)
must not use the normal getenv(), but a special function. This
function had been called getenv_r(), with the idea that the "_r"
suffix would mean the same as in the _r_eentrant versions of some of
the C library functions (for example getdate vs. getdate_r, getgrent
vs. getgrent_r, etc.).
Unfortunately this was a misleading name, as in U-Boot the "_r"
generally means "running from RAM", i. e. _after_ relocation.
To avoid confusion, rename into getenv_f() [as "running from flash"]
Acked-by: Detlev Zundel <dzu@denx.de>
Add POST progress API implemented as weak calls before and after
each call to the POST test callback in the post_run_single routine
of the post.c file.
Signed-off-by: Michael Zaidman <michael.zaidman@gmail.com>
This patch introduces a weak default function for post_hotkey_pressed(),
returning 0, for boards without hotkey support. The long-running tests
won't be started on those boards. This default function was implemented
in many board directories. By implementing this weak default we can
remove all those duplicate versions.
Boards with hotkey support, can override this weak default function
by defining one in their board specific code.
Add #ifdefs where necessary to not perform relocation fixups. This
allows boards/architectures which support relocation to trim a decent
chunk of code.
Note that this patch doesn't add #ifdefs to architecture-specific code
which does not support relocation.
So far the console API uses the following naming convention:
======Extract======
typedef struct device_t;
int device_register (device_t * dev);
int devices_init (void);
int device_deregister(char *devname);
struct list_head* device_get_list(void);
device_t* device_get_by_name(char* name);
device_t* device_clone(device_t *dev);
which is too generic and confusing.
Instead of using device_XX and device_t we change this
into stdio_XX and stdio_dev
This will also allow to add later a generic device mechanism in order
to have support for multiple devices and driver instances.
Edited commit message.
Signed-off-by: Sascha Laue <sascha.laue@liebherr.com>
Don't run futher tests in case of a test fails that is marked as
POST_STOP.
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
Remove CONFIG_POST ifdefs from the post/ source files.
marked as POST_CRITICAL fails then the alternative, post_critical,
boot-command is used. If this command is not defined then U-Boot
enters into interactive mode.
Signed-off-by: Dmitry Rakhchev <rda@emcraft.com>
Added memory, CPU, UART, I2C and SPR POST tests for PPC440.
Signed-off-by: Igor Lisitsin <igor@emcraft.com>
- update board/emk tree; use common flash driver
- Corrected tested bits in machine check exception in cpu/mpc5xxx/traps.c
[adapted for other PPC CPUs -- wd]
- Added support for the M48T08 on the EVAL5200 board in rtc/mk48t59.c
* Patch by Jon Diekema, 13 Feb 2004:
Call show_boot_progress() whenever POST "FAILED" is printed.
* Patch by Nishant Kamat, 13 Feb 2004:
Add support for TI OMAP1610 H2 Board
Fixes for cpu/arm926ejs/interrupt.c
(based on Richard Woodruff's patch for arm925, 16 Oct 03)
Fix for a timer bug in OMAP1610 Innovator
Add support for CS0 (ROM)/CS3 (Flash) boot in OMAP1610 Innovator and H2
* Patches by Stephan Linz, 12 Feb 2004:
- add support for NIOS timer with variable period preload counter value
- prepare POST framework support for NIOS targets
* Patch by Denis Peter, 11 Feb 2004:
add POST support for the MIP405 board
- Added Motorola CPU 8540/8560 support (cpu/85xx)
- Added Motorola MPC8540ADS board support (board/mpc8540ads)
- Added Motorola MPC8560ADS board support (board/mpc8560ads)
* Minor code cleanup
applications: instead of using (PPC-specific) system calls we now
use a jump table; please see doc/README.standalone for details
* Patch by Dave Westwood, 24 Jul 2003:
added support for Unity OS (a proprietary OS)
- add I2C support for s3c2400 systems (trab board)
- (re-) add "ping" to command table
* Fix handling of "slow" POST routines
- Correct flash and JFFS2 support for MPC8260ADS
- fix PVR values and clock generation for PowerQUICC II family
(8270/8275/8280)
* Patch by Bernhard Kuhn, 08 Jul 2003:
- add support for M68K targets
* Patch by Ken Chou, 3 Jul:
- Fix PCI config table for A3000
- Fix iobase for natsemi.c
(PCI_BASE_ADDRESS_0 is the IO base register for DP83815)
* Allow to enable "slow" POST routines by key press on power-on
* Fix temperature dependend switching of LCD backlight on LWMON
* Tweak output format for LWMON
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
- Splashscreen support
- modem support
- sysmon support
- temperature dependend enabling of LCD
* Allow booting from old "PPCBoot" disk partitions
* Add support for TQM8255 Board / MPC8255 CPU
to log on the console, too (like in Linux); get rid of "logstart"
* Patch by Rod Boyce, 21 Nov 2002:
fix PCMCIA on MBX8xx board
* Patch by Pierre Aubert , 21 Nov 2002
Add CFG_CPM_POST_WORD_ADDR to make the offset of the
bootmode word in DPRAM configurable
syslog mechanism; used especially for POST results.
* Patch by Klaus Heydeck, 31 Oct 2002:
Add initial support for kup4k board
