path: root/post/lib_powerpc
2013-11-01post: convert makefiles to Kbuild styleMasahiro Yamada
This commit also deletes post/rules.mk, which in not necessary any more. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-10-14Coding Style cleanup: replace leading SPACEs by TABsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini: Drop changes for PEP 4 following python tools] Signed-off-by: Tom Rini <trini@ti.com>
2011-12-23post/lib_powerpc/multi.c: fix stack overflow errorWolfgang Denk
The code and comment disagreed: the comment claimed that r6...r31 were copied, and consequently the arrays for "src" and "dst" were declared with 26 entries, but the actual code ("lmw r5,0(r3)" and "stmw r5,0(r4)") copied _27_ words (r5 through r31), which resulted in false "POST cpu Error at multi test" messages. Fix the comment and the array sizes. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Kim Phillips <kim.phillips@freescale.com> Cc: Andy Fleming <afleming@gmail.com> Acked-by: Anatolij Gustschin <agust@denx.de> Tested-by: Anatolij Gustschin <agust@denx.de>
2011-12-23post/lib_powerpc/multi.c: code cleanupWolfgang Denk
Clean up and document the code: - get rid of unneeded code block - add comment which code is generated Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Kim Phillips <kim.phillips@freescale.com> Cc: Andy Fleming <afleming@gmail.com> Acked-by: Anatolij Gustschin <agust@denx.de>
2011-12-23post/lib_powerpc/multi.c: make checkpatch cleanWolfgang Denk
2011-12-23PPC: fix "Warning: FOO uses hard float, BAR uses soft float".Wolfgang Denk
It appears that with recent versions of GCC the explicit "-mhard-float" command line option takes precedence over the ``asm(".gnu_attribute 4, 2");'' in the source file, so this no longer helps to avoid the warnings we get when linking code that uses FP instructions with other code that was built using soft-float. We can remove the ".gnu_attribute" (which appears to carry no other information, at least so far) from the object files, but we also have to make sure we don't pull in the __gcc_qsub() and __gcc_qmul() functions from the standard libgcc, as these would again "infect" our linking. We copy this code from: gcc-4.2.2/gcc/config/rs6000/darwin-ldouble.c This old version was chosen because it was still available under a compatible license (GCC v2+). The file was stripped down to the needed parts, and reformatted so it passes checkpatch with only one warning (do not add new typedefs). Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Stefan Roese <sr@denx.de> Cc: Andy Fleming <afleming@gmail.com> Cc: Kim Phillips <kim.phillips@freescale.com> Tested-by: Stefan Roese <sr@denx.de> Tested-by: Anatolij Gustschin <agust@denx.de>
2011-11-1620001122-1.c: Fix GCC 4.6 build warningStefan Roese
Fix: 20001122-1.c: In function 'fpu_post_test_math1': 20001122-1.c:37:22: warning: variable 'p' set but not used [-Wunused-but-set-variable] Signed-off-by: Stefan Roese <sr@denx.de>
2011-07-26post: use ARRAY_SIZEMike Frysinger
We've got a handy dandy macro already for calculating the number of elements in an array, so use it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-01-25powerpc: Fix FPU post related link warningsKumar Gala
If we built POST on PPC's that didn't enable CONFIG_SYS_POST_FPU we'd get the following warning with newer toolchains: powerpc-linux-gnu-ld: Warning: lib_powerpc/fpu/libpostpowerpcfpu.o uses hard float, libpost.o uses soft float We actually worked around this sometime ago with the following commit: commit ce82ff05388b5ddafdf6082ef0776cce72c40b1c Author: Yuri Tikhonov <yur@emcraft.com> Date: Sat Dec 20 14:54:21 2008 +0300 FPU POST: fix warnings when building with 2.18 binutils However, this only took into effect if CONFIG_SYS_POST_FPU was enabled. We can simply move the GNU_FPOST_ATTR out of the CONFIG_SYS_POST_FPU ifdef block to address the issue. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
