path: root/post/lib_powerpc/rlwnm.c
2022-12-23post: Move CONFIG_SYS_POST to CFG_SYS_POSTTom Rini
Migrate the rest of the CONFIG_SYS_POST macros over to CFG_SYS_POST namespace. Signed-off-by: Tom Rini <trini@konsulko.com>
2022-12-05post: Migrate to KconfigTom Rini
We move the existing CONFIG_POST_* functionality over to CFG_POST and then introduce CONFIG_POST to Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-12-02common: Move enable/disable_interrupts out of common.hSimon Glass
Move these two functions into the irq_funcs.h header file. Also move interrupt_handler_t as this is used by the irq_install_handler() function. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2013-10-14Coding Style cleanup: replace leading SPACEs by TABsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini: Drop changes for PEP 4 following python tools] Signed-off-by: Tom Rini <trini@ti.com>
2011-07-26post: use ARRAY_SIZEMike Frysinger
We've got a handy dandy macro already for calculating the number of elements in an array, so use it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
