We've got a handy dandy macro already for calculating the number of
elements in an array, so use it.
Add weak functions to enable architecture depended preparation, address
advancing, cleaning up and error handling.
These weak functions provides the framwork to implemente arch/platform
dependent code for initializing/maintenance/restore the start address, size,
physical address as well as memory mapping before/between/after memory test.
arch_memory_failure_handle can also be implemented in case more care is needed
for arch/platform.
Signed-off-by: York Sun <yorksun@freescale.com>
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
Remove CONFIG_POST ifdefs from the post/ source files.
Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
Fix warnings while compilation with new gcc in eldk-4.2
As experienced on lwmon5, on some boards the POST memory test can
corrupt the global data buffer (bd). This patch fixes this issue
by checking and limiting this area.
