path: root/post/drivers/Makefile
2013-12-13post: descend only when CONFIG_HAS_POST is definedMasahiro Yamada
All objects under post/ directory are enabled by CONFIG_HAS_POST. (post/tests.o is enabled by CONFIG_POST_STD_LIST. But CONFIG_POST_STD_LIST depends on CONFIG_HAS_POST.) We can move CONFIG_HAS_POST switch to the top Makefile. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-25post: remove unnecessary include path settingsMasahiro Yamada
2013-11-01post: convert makefiles to Kbuild styleMasahiro Yamada
This commit also deletes post/rules.mk, which in not necessary any more. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2011-07-26post: new nor flash testMike Frysinger
This adds a simple flash test to automatically verify erasing, writing, and reading of sectors. The code is based on existing Blackfin tests but generalized for everyone to use. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-04-22POST: move CONFIG_POST to MakefilesYuri Tikhonov
Introduce the new logical option CONFIG_HAS_POST which is set when the platform has CONFIG_POST set. Use CONFIG_HAS_POST in the post/ Makefiles to determine should the POST libs be compiled for the selected target platform, or not. To avoid breaking u-boot linking process, the empty post/libpost.a file is created for platforms which do not have POSTs. Signed-off-by: Yuri Tikhonov <yur@emcraft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-07-05Merged POST framework with the current TOT.Sergei Poselenov
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
2007-03-06Restructure POST directory to support of other CPUs, boards, etc.Wolfgang Denk
