path: root/post/cpu
2007-08-10POST: Add ppc4xx UART POST support without external uart clock (lwmon5)Yuri Tikhonov
The patch adds support for UART POST on ppc44x-based boards with no external serial clocks installed. Signed-off-by: Yuri Tikhonov <yur@emcraft.com> Acked-by: Stefan Roese <sr@denx.de>
2007-07-31ppc4xx: Update 440EPx lwmon5 board supportStefan Roese
- Clear ECC status regs after ECC POST test - Set dcbz for ECC generation with caches enabled as default - Code cleanup Signed-off-by: Stefan Roese <sr@denx.de>
2007-07-10Coding style cleanup; update CHANGELOG.Wolfgang Denk
2007-07-05Merged POST framework with the current TOT.Sergei Poselenov
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
2007-06-22Extend POST support for PPC440Igor Lisitsin
Added memory, CPU, UART, I2C and SPR POST tests for PPC440. Signed-off-by: Igor Lisitsin <igor@emcraft.com> --
2007-03-19Remove obsoleted POST files.Wolfgang Denk
2007-03-06Restructure POST directory to support of other CPUs, boards, etc.Wolfgang Denk
2002-09-12Initial revisionwdenk
2002-08-27Initial revisionwdenk
