path: root/post/cpu
2010-12-17ppc4xx/POST: Change ethernet test loop count to a default of 10Stefan Roese
This patch changes the PPC4xx ethernet POST loop test count from currently 192 (256 - 64) to a default of 10. While doing this the max frame size is increased. Each loop run uses a different frame size, starting with a max of 1514 bytes, down to 64. The default loop count of 10 can be overriden using CONFIG_SYS_POST_ETH_LOOPS in the board config header. The TEST_NUM loop has been removed as it was never used. The main reason for this change is to reduce the boot time on boards using this POST test, like the lwmon5 board. This change reduces the boot time by about 600ms on the lwmon5 board. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Wolfgang Denk <wd@denx.de>
2010-11-28ppc4xx/POST: Handle cached SDRAM correctly in Denali (440EPx) ECC POSTStefan Roese
This patch fixes a problem in the Denali (440EPx) SDRAM ECC POST test. When cache is enabled in the SDRAM area, the values written to SDRAM need to be flushed from cache to SDRAM using the dcfb instruction. Without this patch the POST ECC test failed. Now its working again on platforms with cache enabled in SDRAM. Signed-off-by: Stefan Roese <sr@denx.de>
2010-10-04ppc4xx: Use common ns16550 functions in 4xx UART POST driverStefan Roese
This patch changes the PPC4xx POST UART driver to use the common NS16550 functions for receiving and sending. Additionally the local function for SoC divisor setup are removed. Instead the functions from arch/powerpc/cpu/ppc4xx/4xx_uart.c are used. This removes code duplication. Also the common CONFIG_SYS_NS16550_COMx defines are now used to describe the POST UART's. And a compile breakage is fixed, introduced by a git merge of the ppc4xx/next branch into master. Now "ppc4xx.h" is moved to "asm/ppc4xx.h". Fixed as well with this patch. Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-28Merge branch 'next' of /home/wd/git/u-boot/nextWolfgang Denk
Conflicts: include/ppc4xx.h Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-23ppc4xx: Move ppc4xx headers to powerpc include directoryStefan Roese
This patch moves some ppc4xx related headers from the common include directory (include/) to the powerpc specific one (arch/powerpc/include/asm/). This way to common include directory is not so cluttered with files. Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-23ppc4xx: POST UART: Use in/out_8() io-accessor functionsStefan Roese
This patch fixes a problem in the PPC4xx POST UART driver. This driver incorrectly used the in/out8() io-accessor functions. This could lead to problems since these functions don't guarantee execution ordering. This patch now replaces these functions with the correct ones. Additionally the driver is converted to using the NS16550 struct instead of macros for the register offsets. And some common code is factored out for better maintainability. Signed-off-by: Stefan Roese <sr@denx.de>
2010-05-06POST: Added ECC memory test for mpc83xx.Michael Zaidman
Signed-off-by: Michael Zaidman <michael.zaidman@gmail.com> Fixed minor coding style issue. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2009-10-07ppc_4xx: Apply new HW register namesNiklaus Giger
Modify all existing *.c files to use the new register names as seen in the AMCC manuals. Signed-off-by: Niklaus Giger <niklaus.giger@member.fsf.org> Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-11ppc4xx: Big cleanup of PPC4xx definesStefan Roese
This patch cleans up multiple issues of the 4xx register (mostly DCR, SDR, CPR, etc) definitions: - Change lower case defines to upper case (plb4_acr -> PLB4_ACR) - Change the defines to better match the names from the user's manuals (e.g. cprpllc -> CPR0_PLLC) - Removal of some unused defines Please test this patch intensive on your PPC4xx platform. Even though I tried not to break anything and tested successfully on multiple 4xx AMCC platforms, testing on custom platforms is recommended. Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-24ppc4xx: Replace 4xx lowercase SPR referencesMatthias Fuchs
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-03-28mpc8xx/ether.c: fix warning: unused variable 'bd'Wolfgang Denk
Also minor coding style cleanup. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-03-20cpu/: get mac address from environmentMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. The cpus that get converted here: at91rm9200 mpc512x mpc5xxx mpc8260 mpc8xx ppc4xx Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com> CC: John Rigby <jrigby@freescale.com> CC: Stefan Roese <sr@denx.de>
2008-08-06Fix merge problemsStefan Roese
2008-06-06ppc4xx: Fix misspelled CONFIG_440SPE/440EPX/GRX config optionsStefan Roese
We use upper case letters for the AMCC processor defines (like CONFIG_440SPE) in U-Boot. So the 440SPe is labeled CONFIG_440SPE and not CONFIG_440SPe. This patch fixes the last misspelled config options. Signed-off-by: Stefan Roese <sr@denx.de>
2008-05-20POST: OCM test added.Yuri Tikhonov
Added OCM test to POST layer. This version runs before all other tests but doesn't yet interrupt post sequence on failure. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-05-10post/cpu/ppc4xx/Makefile: line length cleanupWolfgang Denk
2008-04-29POST: fix Makefiles for mpc8xx, lwmon, and netta POSTs.Yuri Tikhonov
2008-04-28post: Fix building with O=Kumar Gala
2008-04-22POST: move CONFIG_POST to MakefilesYuri Tikhonov
Introduce the new logical option CONFIG_HAS_POST which is set when the platform has CONFIG_POST set. Use CONFIG_HAS_POST in the post/ Makefiles to determine should the POST libs be compiled for the selected target platform, or not. To avoid breaking u-boot linking process, the empty post/libpost.a file is created for platforms which do not have POSTs. Signed-off-by: Yuri Tikhonov <yur@emcraft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-22POST: preparations for moving CONFIG_POST to MakefilesYuri Tikhonov
Remove CONFIG_POST ifdefs from the post/ source files. Signed-off-by: Yuri Tikhonov <yur@emcraft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-03-15ppc4xx: program_tlb now uses 64bit physical addessStefan Roese
This patch changes the physical addess parameter from 32bit to 64bit. This is needed for 36bit 4xx platforms to access areas located beyond the 4GB border, like SoC peripherals (EBC etc.). Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-02POST: Disable cache while SPR POSTAnatolij Gustschin
Currently (since commit b2e2142c) u-boot crashes on sequoia board while SPR test if CONFIG_4xx_DCACHE is enabled. This patch disables the cache while SPR test. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-01-16ppc4xx: Refactor ECC POST for AMCC Denali coreLarry Johnson
The ECC POST reported intermittent failures running after power-up on the Korat PPC440EPx board. Even when the test passed, the debugging output occasionally reported additional unexpected ECC errors. This refactoring has three main objectives: (1) minimize the code executed with ECC enabled during the tests, (2) add more checking of the results so any unexpected ECC errors would cause the test to fail, and (3) use synchronization (only) where required by the processor. Signed-off-by: Larry Johnson <lrj@acm.org>
2008-01-14ppc_4xx: Fix post spr.c for PPC405Niklaus Giger
post/cpu/ppc4xx/spr.c contained a few checks for registers only present for PPC440 and derivates processor. Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
2007-12-27Cosmetic changes to ECC POST for AMCC Denali coreLarry Johnson
2007-12-27ppc4xx: Fix compilation problem in 405 cache POST testStefan Roese
2007-12-27ppc4xx: Fix problem in 44x cache POST routineStefan Roese
As repoted by Larry Johnson, running "diag run cache" caused a crash in U-Boot. This problem was introduced by a patch that removed the TLB entry for the cache test after the test has completed. Since this TLB was only setup once, a 2nd attempt to run this cache test failed with a crash. Now this TLB entry is created every time the routine is called. Signed-off-by: Stefan Roese <sr@denx.de>
2007-12-27Fix/enhance ECC POST for 440EPx/GRxLarry Johnson
This patch allows the ECC POST to be used for different boards with the PPC440 Denali SDRAM controller. Modifications include skipping the test if ECC is not enabled (as for non-ECC DIMMs) and adding synchronization to prevent timing errors. Signed-off-by: Larry Johnson <lrj@acm.org>
2007-12-27PPC4xx: Move/rename ECC POST for 440EPx/GRxLarry Johnson
2007-12-27ppc4xx: use correct io accessors for 4xx ethernet POSTMatthias Fuchs
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2007-10-31ppc4xx: Change 4xx POST ethernet test to handle cached memory tooStefan Roese
This patch enables the 4xx EMAC POST driver to work too, when dcache is enabled. Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Remove temporary TLB entry in POST cache test only for 440Stefan Roese
2007-10-31ppc4xx: Remove compiler warning from previous commitStefan Roese
2007-10-31ppc4xx: Remove temporary TLB entry in POST cache testStefan Roese
2007-10-31ppc4xx: Fix POST ethernet test for HaleakalaStefan Roese
The POST ethernet test needed to be changed to dynamically determine the count of ethernet devices. This code is cloned from the 4xx ethernet driver. Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31POST: Add 405EX support to 4xx UART POST testStefan Roese
2007-08-14POST: Fix merge problemStefan Roese
2007-08-14Merge with /home/stefan/git/u-boot/zeusStefan Roese
2007-08-14POST: Add option for external ethernet loopback testStefan Roese
When CFG_POST_ETHER_EXT_LOOPBACK is defined, the ethernet POST is not done using an internal loopback connection, but by assuming that an external loopback connector is plugged into the board. Signed-off-by: Stefan Roese <sr@denx.de>
2007-08-14POST: Add ppc405 support to cache and UART POSTStefan Roese
2007-08-10POST: Add ppc4xx UART POST support without external uart clock (lwmon5)Yuri Tikhonov
The patch adds support for UART POST on ppc44x-based boards with no external serial clocks installed. Signed-off-by: Yuri Tikhonov <yur@emcraft.com> Acked-by: Stefan Roese <sr@denx.de>
2007-07-31ppc4xx: Update 440EPx lwmon5 board supportStefan Roese
- Clear ECC status regs after ECC POST test - Set dcbz for ECC generation with caches enabled as default - Code cleanup Signed-off-by: Stefan Roese <sr@denx.de>
2007-07-10Coding style cleanup; update CHANGELOG.Wolfgang Denk
2007-07-05Merged POST framework with the current TOT.Sergei Poselenov
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
2007-06-22Extend POST support for PPC440Igor Lisitsin
Added memory, CPU, UART, I2C and SPR POST tests for PPC440. Signed-off-by: Igor Lisitsin <igor@emcraft.com> --
2007-03-19Remove obsoleted POST files.Wolfgang Denk
