path: root/post/cpu/ppc4xx/cache.c
2008-04-22POST: preparations for moving CONFIG_POST to MakefilesYuri Tikhonov
Remove CONFIG_POST ifdefs from the post/ source files. Signed-off-by: Yuri Tikhonov <yur@emcraft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-03-15ppc4xx: program_tlb now uses 64bit physical addessStefan Roese
This patch changes the physical addess parameter from 32bit to 64bit. This is needed for 36bit 4xx platforms to access areas located beyond the 4GB border, like SoC peripherals (EBC etc.). Signed-off-by: Stefan Roese <sr@denx.de>
2007-12-27ppc4xx: Fix compilation problem in 405 cache POST testStefan Roese
2007-12-27ppc4xx: Fix problem in 44x cache POST routineStefan Roese
As repoted by Larry Johnson, running "diag run cache" caused a crash in U-Boot. This problem was introduced by a patch that removed the TLB entry for the cache test after the test has completed. Since this TLB was only setup once, a 2nd attempt to run this cache test failed with a crash. Now this TLB entry is created every time the routine is called. Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Remove temporary TLB entry in POST cache test only for 440Stefan Roese
2007-10-31ppc4xx: Remove compiler warning from previous commitStefan Roese
2007-10-31ppc4xx: Remove temporary TLB entry in POST cache testStefan Roese
2007-08-14POST: Add ppc405 support to cache and UART POSTStefan Roese
2007-07-05Merged POST framework with the current TOT.Sergei Poselenov
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
