path: root/post/board
2008-06-03lwmon5: add memory-pattern-test to FPGA POST.Sascha Laue
2008-05-04Prepare for v1.3.3-rc3v1.3.3-rc3Wolfgang Denk
Update ChNAGELOG, minor white space cleanup. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-30lwmon5: fix offset error in sysmon0 POSTSascha Laue
Signed-off-by: Sascha Laue <sascha.laue@liebherr.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-30lwmon5: fix manual merge error in POSTSascha Laue
2008-04-29post/board/lwmon5/sysmon.c: fix manual merge error.Wolfgang Denk
2008-04-29POST: fix Makefiles for mpc8xx, lwmon, and netta POSTs.Yuri Tikhonov
Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-04-28lwmon5: update dsPIC POST spezificationSascha Laue
The specification for the lwmon5 board dsPIC POST got changed. Also add defines for the temperatures and voltages. Signed-off-by: Sascha Laue <sascha.laue@liebherr.com>
2008-04-28Fix watchdog POST for lwmon5Sascha Laue
If the hardware watchdog detects a voltage error, the watchdog sets GPIO62 to low. The watchdog POST has to detect this low level. Signed-off-by: Sascha Laue <leglas0@legpc180.leg.liebherr.i> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-28post: Fix building with O=Kumar Gala
2008-04-26Coding Style cleanup, update CHANGELOGWolfgang Denk
2008-04-25Merge branch 'master' of /home/wd/git/u-boot/lwmon5Wolfgang Denk
Conflicts: common/cmd_bootm.c common/cmd_log.c include/common.h post/board/lwmon5/Makefile post/board/lwmon5/dsp.c post/board/lwmon5/dspic.c post/board/lwmon5/fpga.c post/board/lwmon5/gdc.c post/board/lwmon5/sysmon.c post/board/lwmon5/watchdog.c Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-22POST: move CONFIG_POST to MakefilesYuri Tikhonov
Introduce the new logical option CONFIG_HAS_POST which is set when the platform has CONFIG_POST set. Use CONFIG_HAS_POST in the post/ Makefiles to determine should the POST libs be compiled for the selected target platform, or not. To avoid breaking u-boot linking process, the empty post/libpost.a file is created for platforms which do not have POSTs. Signed-off-by: Yuri Tikhonov <yur@emcraft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-22POST: preparations for moving CONFIG_POST to MakefilesYuri Tikhonov
Remove CONFIG_POST ifdefs from the post/ source files. Signed-off-by: Yuri Tikhonov <yur@emcraft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-13Fix watchdog POST for lwmon5Sascha Laue
2008-03-26Coding Style cleanyp; update CHANGELOGWolfgang Denk
2008-03-25lwmon5 SYSMON POST: fix handling of negative temperaturesYuri Tikhonov
Fix errors in the LWMON5 Sysmon POST for negative temperatures. Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-03-22Merge branch 'master' of /home/wd/git/u-boot/workWolfgang Denk
2008-03-22LWMON5: fix dsPIC POSTYuri Tikhonov
Add test for DPIC_SYS_ERROR_REG to be zero in the LWMON5 dsPIC POST. Signed-off-by: Yuri Tikhonov <yur@emcraft.com> ---
2008-03-20lwmon5 POST: remove unreachable codeWolfgang Denk
plus some coding style cleanup Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-03-18lwmon5: Fix register test logic to match the specific GDC h/w.Yuri Tikhonov
Signed-off-by: Dmitry Rakhchev <rda@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-03-18Fix backlight in the lwmon5 POST.Yuri Tikhonov
Backlight was switched on even when temperature was too low. Signed-off-by: Dmitry Rakhchev <rda@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-03-18Some fixes to dspic, fpga, and gdc post tests for lwmon5. Disable external ↵Yuri Tikhonov
watch-dog for now. Signed-off-by: Dmitry Rakhchev <rda@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-03-18The patch adds new POST tests for the Lwmon5 board. These are:Yuri Tikhonov
* External Watchdog test; * dsPIC tests; * FPGA test; * GDC test; * Sysmon tests. Signed-off-by: Dmitry Rakhchev <rda@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
Backlight was switcehd on even when temperature was too low. Signed-off-by: Dmitry Rakhchev <rda@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-03-18Some fixes to dspic, fpga, and gdc post tests for lwmon5.Yuri Tikhonov
Disable external watch-dog for now. Signed-off-by: Dmitry Rakhchev <rda@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-03-18The patch adds new POST tests for the Lwmon5 board.Yuri Tikhonov
These are: * External Watchdog test; * dsPIC tests; * FPGA test; * GDC test; * Sysmon tests. Signed-off-by: Dmitry Rakhchev <rda@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2007-12-27ppc4xx: Fix lwmon5 compilation problemStefan Roese
Now that the 440EPx ECC test is not board specific anymore remove this Makefile. Signed-off-by: Stefan Roese <sr@denx.de>
2007-12-27PPC4xx: Move/rename ECC POST for 440EPx/GRxLarry Johnson
Signed-off-by: Larry Johnson <lrj@acm.org>
2007-07-31ppc4xx: Update 440EPx lwmon5 board supportStefan Roese
- Clear ECC status regs after ECC POST test - Set dcbz for ECC generation with caches enabled as default - Code cleanup Signed-off-by: Stefan Roese <sr@denx.de>
2007-07-20POST: Add ECC POST for the lwmon5 boardPavel Kolesnikov
This patch adds ECC Post test for the Lwmon5 board based on PPC440EPx to U-Boot. Signed-off-by: Pavel Kolesnikov <concord@emcraft.com> Acked-by: Yuri Tikhonov <yur@emcraft.com> Acked-by: Stefan Roese <sr@denx.de>
2007-03-06Restructure POST directory to support of other CPUs, boards, etc.Wolfgang Denk
