path: root/post/Makefile
2017-07-03powerpc: remove 4xx supportHeiko Schocher
There was for long time no activity in the 4xx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 4xx, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-12powerpc, 8xx: remove support for 8xxHeiko Schocher
There was for long time no activity in the 8xx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 8xx, so remove it (with a heavy heart, knowing that I remove here the root of U-Boot). Signed-off-by: Heiko Schocher <hs@denx.de>
2016-04-01post: Remove references to scrapped "netta" board.Robert P. J. Day
Given that README.scrapyard shows scrapping of netta boards: netta2 powerpc mpc8xx c51c1c9a 2014-07-07 netta powerpc mpc8xx c51c1c9a 2014-07-07 delete netta example from POST tests. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2016-04-01post: Remove reference to deleted "lwmon" board from MakefileRobert P. J. Day
POST support for sample lwmon board was removed in commit e5d3078622. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>B
2013-12-16Makefile: Select objects by CONFIG_ rather than $(ARCH) or $(CPU)Masahiro Yamada
Convert like follows: CPU mpc83xx -> CONFIG_MPC83xx CPU mpc85xx -> CONFIG_MPC85xx CPU mpc86xx -> CONFIG_MPC86xx CPU mpc5xxx -> CONFIG_MPC5xxx CPU mpc8xx -> CONFIG_8xx CPU mpc8260 -> CONFIG_8260 CPU ppc4xx -> CONFIG_4xx CPU x86 -> CONFIG_X86 ARCH x86 -> CONFIG_X86 ARCH powerpc -> CONFIG_PPC Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-12-13post: descend only when CONFIG_HAS_POST is definedMasahiro Yamada
All objects under post/ directory are enabled by CONFIG_HAS_POST. (post/tests.o is enabled by CONFIG_POST_STD_LIST. But CONFIG_POST_STD_LIST depends on CONFIG_HAS_POST.) We can move CONFIG_HAS_POST switch to the top Makefile. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-01post: convert makefiles to Kbuild styleMasahiro Yamada
This commit also deletes post/rules.mk, which in not necessary any more. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2012-03-12Revert "post/Makefile: Only build FP post tests if enabled via ↵Wolfgang Denk
CONFIG_SYS_POST_FPU" This reverts commit 3e16abe0e468c568b30acb7d8583e3dbed6f177b. The logic of this patch is broken - testing for CONFIG_SYS_POST_FPU in the Makefile cannot work, as this is only a bit that may (or may not) be set in the CONFIG_POST variable. The patch cases build errors on a number of boards, so we revert it. Signed-off-by: Wolfgang Denk <wd@denx.de>
2012-01-13post/Makefile: Only build FP post tests if enabled via CONFIG_SYS_POST_FPUKumar Gala
2010-09-21POST cleanup.Michael Zaidman
- Revives POST for blackfin arch; - Removes redundant code: arch/blackfin/lib/post.c arch/powerpc/cpu/ppc4xx/commproc.c arch/powerpc/cpu/mpc512x/common.c - fixes up the post_word_{load|store} usage. Signed-off-by: Michael Zaidman <michael.zaidman@gmail.com> Acked-by: Detlev Zundel <dzu@denx.de> Tested-by: Anatolij Gustschin <agust@denx.de> List of the maintainers of the affected by patch boards: Cc: Stephan Linz <linz@li-pro.net> Cc: Denis Peter <d.peter@mpl.ch> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Stefan Roese <sr@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Niklaus Giger <niklaus.giger@netstal.com> Cc: Larry Johnson <lrj@acm.org> Cc: Feng Kan <fkan@amcc.com>
2008-12-16post/Makefile: fix dependency problem with parallel buildsWolfgang Denk
Parallel builds (using "make -jN") would occasionally fail with error messages like ppc_4xxFP-objdump: string.o: File format not recognized or post/libpost.a(cpu.o): In function `cpu_post_test': /home/wd/git/u-boot/work/post/lib_ppc/cpu.c:130: undefined reference to `cpu_post_test_string' or similar. We now make sure to run the 'postdeps" step before attempting to build the specific POST libraries. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-12-15POST Make: fix the sub-dir dependencies missing.Yuri Tikhonov
Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-04-28post: Fix building with O=Kumar Gala
2008-04-26post/Makefile: make sure to use the correct flagsWolfgang Denk
ARFLAGS was not set, which caused "ppc_8xx-ar: creating libgenpost.a" messages to be printed. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-22POST: move CONFIG_POST to MakefilesYuri Tikhonov
Introduce the new logical option CONFIG_HAS_POST which is set when the platform has CONFIG_POST set. Use CONFIG_HAS_POST in the post/ Makefiles to determine should the POST libs be compiled for the selected target platform, or not. To avoid breaking u-boot linking process, the empty post/libpost.a file is created for platforms which do not have POSTs. Signed-off-by: Yuri Tikhonov <yur@emcraft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-03-06Restructure POST directory to support of other CPUs, boards, etc.Wolfgang Denk
2004-06-07Patch by Pantelis Antoniou, 5 May 2004:wdenk
- Intracom board update. - Add Codec POST.
2004-04-15* Patches by Pantelis Antoniou, 30 Mar 2004:wdenk
- add support for the Epson 156x series of graphical displays (These displays are serial and not suitable for using a normal framebuffer console on them) - add infrastructure needed in order to POST any DSPs in a board
2003-04-27* LWMON extensions:wdenk
- Splashscreen support - modem support - sysmon support - temperature dependend enabling of LCD * Allow booting from old "PPCBoot" disk partitions * Add support for TQM8255 Board / MPC8255 CPU
2002-08-27Initial revisionwdenk
