path: root/onenand_ipl
2010-04-13Create CPUDIR variablePeter Tyser
The CPUDIR variable points to the location of a target's CPU directory. Currently, it is set to cpu/$CPU. However, using $CPUDIR will allow for more flexibility in the future. It lays the groundwork for reorganizing U-Boot's directory structure to support a layout such as: arch/$ARCH/cpu/$CPU/* (architecture with multiple CPU types) arch/$ARCH/cpu/* (architecture with one CPU type) Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-09-28Refactor OneNAND IPL codeKyungmin Park
Refactoring the OneNAND IPL code and some minor fixed: - Remove unnecessary header file - Fix wrong access at read interrupt - The recent OneNAND has 4KiB pagesize Also Board can override OneNAND IPL image Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2009-08-21Fix all linker scripts for older binutils versions (pre-2.16)Wolfgang Denk
Commit f62fb99941c6 fixed handling of all rodata sections by using a wildcard combined with calls to ld's builtin functions SORT_BY_ALIGNMENT() and SORT_BY_NAME(). Unfortunately these functions were only introduced with biunutils version 2.16, so the modification broke building with all tool chains using older binutils. This patch makes it work again. This is done by omitting the use of these functions for such old tool chains. This will result in slightly larger target binaries, as the rodata sections are no longer in optimal order alignment-wise which reauls in unused gaps, but the effect was found to be insignificant - especially compared to the fact that you cannot build U-Boot at all in the current state. As ld seems to have no support for conditionals we run the linker script through the C preprocessor which can be easily used to remove the unwanted function calls. Note that the C preprocessor must be run with the "-ansi" (or a "-std=") option to make sure all the system-specific predefined macros outside the reserved namespace are suppressed. Otherise, cpp might for example substitute "powerpc" to "1", thus corrupting for example "OUTPUT_ARCH(powerpc)" etc. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Mike Frysinger <vapier@gentoo.org>
2009-06-21ARM1136: Introduce CONFIG_PRELOADER macro.Magnus Lilja
Currently CONFIG_ONENAND_IPL is used in a number of #ifdef's in start.S. In preparation for adding support for NAND SPL the macro CONFIG_PRELOADER is introducted and replaces the CONFIG_ONENAND_IPL in start.S. Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
2009-06-10apollon: Fix a OBJCFLAGS typoShinya Kuribayashi
Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2009-04-03Fix OneNAND ipl to read CONFIG_SYS_MONITOR_LENapgmoorthy
Currently OneNAND initial program loader (ipl) reads only block 0 ie 128KB. However, u-boot image for apollon board is 195KB making the board unbootable with OneNAND. Fix ipl to read CONFIG_SYS_MONITOR_LEN. CONFIG_SYS_MONITOR_LEN macro holds the U-Boot image size. Signed-off-by: Rohit Hagargundgi <h.rohit@samsung.com> Signed-off-by: Gangheyamoorthy <moorthy.apg@samsung.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-03-23Reduce OneNAND IPL common codeKyungmin Park
OneNAND IPL has common codes for RAM init, load data, and jump to 2nd bootloader, but it's common code used about 300~400 bytes. So board specific codes, such as lowlevel_init, can't has enough code. It make a difficult to implement OneNAND IPL. his patch make this common code as small as possible. and give lowlevel_init can have more codes. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-06Fix merge problemsStefan Roese
2008-03-26Add Flex-OneNAND booting supportKyungmin Park
Flex-OneNAND is a monolithic integrated circuit with a NAND Flash array using a NOR Flash interface. This on-chip integration enables system designers to reduce external system logic and use high-density NAND Flash in applications that would otherwise have to use more NOR components. Flex-OneNAND enables users to configure to partition it into SLC and MLC areas in more flexible way. While MLC area of Flex-OneNAND can be used to store data that require low reliability and high density, SLC area of Flex-OneNAND to store data that need high reliability and high performance. Flex-OneNAND can let users take advantage of storing these two different types of data into one chip, which is making Flex-OneNAND more cost- and space-effective. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2008-02-14Coding style cleanup; update CHANGELOG.Wolfgang Denk
2008-02-14OneNAND Initial Program Loader (IPL) supportKyungmin Park
This patch enables the OneNAND boot within U-Boot. Before this work, we used another OneNAND IPL called X-Loader based on open source. With this work, we can build the oneboot.bin image without other program. The build sequence is simple. First, it compiles the u-boot.bin Second, it compiles OneNAND IPL Finally, it becomes the oneboot.bin from OneNAND IPL and u-boot.bin The mechanism is similar with NAND boot except it boots from itself. Another thing is that you can only use the OneNAND IPL only to work other bootloader such as RedBoot and so on. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
