path: root/onenand_ipl/onenand_boot.c
2012-09-18IPL: Remove remains of OneNAND IPLMarek Vasut
After removing the Apollon board, remove the OneNAND IPL too. There are no users for it any more. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Minkyu Kang <promsoft@gmail.com> Cc: Tom Rini <trini@ti.com> Acked-by: Minkyu Kang <mk7.kang@samsung.com>
2009-09-28Refactor OneNAND IPL codeKyungmin Park
Refactoring the OneNAND IPL code and some minor fixed: - Remove unnecessary header file - Fix wrong access at read interrupt - The recent OneNAND has 4KiB pagesize Also Board can override OneNAND IPL image Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2009-04-03Fix OneNAND ipl to read CONFIG_SYS_MONITOR_LENapgmoorthy
Currently OneNAND initial program loader (ipl) reads only block 0 ie 128KB. However, u-boot image for apollon board is 195KB making the board unbootable with OneNAND. Fix ipl to read CONFIG_SYS_MONITOR_LEN. CONFIG_SYS_MONITOR_LEN macro holds the U-Boot image size. Signed-off-by: Rohit Hagargundgi <h.rohit@samsung.com> Signed-off-by: Gangheyamoorthy <moorthy.apg@samsung.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-03-23Reduce OneNAND IPL common codeKyungmin Park
OneNAND IPL has common codes for RAM init, load data, and jump to 2nd bootloader, but it's common code used about 300~400 bytes. So board specific codes, such as lowlevel_init, can't has enough code. It make a difficult to implement OneNAND IPL. his patch make this common code as small as possible. and give lowlevel_init can have more codes. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-03-26Add Flex-OneNAND booting supportKyungmin Park
Flex-OneNAND is a monolithic integrated circuit with a NAND Flash array using a NOR Flash interface. This on-chip integration enables system designers to reduce external system logic and use high-density NAND Flash in applications that would otherwise have to use more NOR components. Flex-OneNAND enables users to configure to partition it into SLC and MLC areas in more flexible way. While MLC area of Flex-OneNAND can be used to store data that require low reliability and high density, SLC area of Flex-OneNAND to store data that need high reliability and high performance. Flex-OneNAND can let users take advantage of storing these two different types of data into one chip, which is making Flex-OneNAND more cost- and space-effective. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2008-02-14OneNAND Initial Program Loader (IPL) supportKyungmin Park
This patch enables the OneNAND boot within U-Boot. Before this work, we used another OneNAND IPL called X-Loader based on open source. With this work, we can build the oneboot.bin image without other program. The build sequence is simple. First, it compiles the u-boot.bin Second, it compiles OneNAND IPL Finally, it becomes the oneboot.bin from OneNAND IPL and u-boot.bin The mechanism is similar with NAND boot except it boots from itself. Another thing is that you can only use the OneNAND IPL only to work other bootloader such as RedBoot and so on. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
