path: root/nios2_config.mk
2009-07-21Move architecture specific config.mk files into subdirsPeter Tyser
This cleans up U-Boot's toplevel directory a bit and makes the architecture 'config.mk' file naming and location similar to board and cpu 'config.mk' files Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-07-19push CROSS_COMPILE out to $(ARCH)_config.mkMike Frysinger
Each arch should handle setting a proper default CROSS_COMPILE value in their own config.mk file rather than having to maintain a large ugly list in the Makefile. By using conditional assignment, we don't have to worry about the variable already being set (env/cmdline/etc...). The common config.mk file takes care of exporting CROSS_COMPILE already, and while a few variables (toolchain ones) utilize CROSS_COMPILE before including the arch config.mk, they do so with deferred assignment. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2006-06-08Nios II - Fix I/O Macros and mini-app stubsScott McNutt
-Fix asm/io.h macros -Eliminate use of CACHE_BYPASS in cpu code -Eliminate assembler warnings -Fix mini-app stubs and force no small data Patch by Scott McNutt, 08 Jun 2006
2004-10-10Patches by Scott McNutt, 24 Aug 2004:wdenk
- Add support for Altera Nios-II processors. - Add support for Psyent PCI-5441 board. - Add support for Psyent PK1C20 board.
