Affected boards:
AmigaOneG3SE
Removed initialization of the driver from net/eth.c
Affected boards:
EVB64260
P3G4
ZUMA
Affected boards:
PN62
sc520_cdp
Affected boards:
a3000
Affected boards:
bc3450
cpci5200
mecp5200
pf2000
icecube
o2dnt
pm520
sandpoint8245
total5200
tqm5200
Affected boards:
mpc7448hpc2
Affected boards:
hidden_dragon
MPC8544DS
MPC8610HPCN
R2DPLUS
TB0229
Affected boards:
linkstation
r7780mp
Removed at91sam9_eth_initialize() from net/eth.c
DM644x is just one of a series of DaVinci chips that use the EMAC driver.
By replacing all the function names that start with dm644x_* to davinci_*
we make these function more portable. I have tested this change on my EVM.
DM6467 is another DaVinci SOC which uses the EMAC driver and i will
be sending patches that add DaVinci DM6467 support to the list soon.
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
The DHCP handler has 1 state that is not listed in this case, causing a
failure message when there is actually no failure.
Signed-off-by: Remy Bohmer <linux@bohmer.net>
The option CONFIG_BOOTP_RANDOM_DELAY does not compile, because of a
missing extern inside the net/bootp.h header
The only board using this driver is the SL8245 board.
Removed initialization for the driver from net/eth.c
The only board using this driver is the Freescale MPC8610HPCD board.
Added board_eth_init() function to bf537-stamp board.
Removed initialization for the Blackin EMAC driver from net/eth.c
Added a cpu_eth_init() function to leon2/leon3 CPU directories and
removed code from net/eth.c
Added a cpu_eth_init() function to coldfire CPU directories and
Added a cpu_eth_init() function to cpu/mcf547x_8x directory and
Renamed initialization functions for atngw100 and atstk1000.
Removed initializations for these boards from net/eth.c
Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
on the network with it's offered IP number; it should not reply until
after it has received a DHCP ACK message. Also ensures that U-Boot
does it's DHCPREQUEST as broadcast (per RFC 2131).
Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org>
Acked-by: Ben Warren <biggerbadderben@gmail.com>
The compiler will help find mismatches between printf formats and
arguments if you let it. This patch adds the necessary attributes to
declarations in include/common.h, then begins to correct the resulting
compiler warnings. Some of these were bugs, e.g., "$d" instead of
"%d" and incorrect arguments. Others were just annoying, like
int-long mismatches on a system where both are 32 bits. It's worth
fixing the annoying errors to catch the real ones.
Signed-off-by: Andrew Klossner <andrew@cesa.opbu.xerox.com>
This patch is the first step in cleaning up net/eth.c, by moving Ethernet
initialization to CPU or board-specific code. Initial implementation is
only on the Freescale TSEC controller, but others will be added soon.
U-boot can complain a lot about 'checksum bad' when it is attached to the network.
It is annoying for ordinary users who start to doubt the network connection
in general when they see messages like this.
This is caused by the routine NetCksumOk() which cannot handle IP-headers longer
than 20 bytes. Those packages can be ignored anyway by U-boot, so we trash them
now before checking the checksum.
Merge branch 'testing-V2'
board/atmel/at91cap9adk/Makefile
Fixing copyright
board/atmel/at91sam9260ek/Makefile
Fixing copyright
board/atmel/at91sam9260ek/u-boot.lds
Delete no more needed ld script
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
This patch adds support for the AT91SAM9263 chip and the AT91SAM9263EK
board.
Signed-off-by: Stelian Pop <stelian@popies.net>
Currently the timeout waiting for an ARP reply is hard set to 5 seconds.
On i.MX31ADS due to a hardware "strangeness" up to four first IP packets
to the boards get lost, which typically are ARP replies. By configuring
the timeout to a lower value we significantly improve the first network
transfer time on this board. The timeout is specified in milliseconds,
later internally it is converted to deciseconds, because it has to be
converted to hardware ticks, and CFG_HZ ranges from 900 to 27000000 on
different boards.
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
Support for booting from internal DataFlash, external DataFlash card
or NAND flash is available.
AT91CAP9 and AT91SAM9 SoCs are very close hardware wise, so a
common infrastructure can be used. Let this infrastructure be
named after the AT91SAM9 family, and move the existing AT91CAP9
files to the new place.
GRETH is an Ethernet 10/100 or 10/100/1000 MAC with out without
a debug link (EDCL). The GRETH core is documented in GRIP.pdf
available at www.gaisler.com.
If the GRETH has GigaBit support (GBIT, Scatter gather, checksum
offloading etc.) can be determined by a bit in the control register.
The GBIT MAC is supported by operating in GRTEH 10/100 legacy mode.
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
Added option CONFIG_BOOTP_DHCP_REQUEST_DELAY. This provides an optional
delay before sending "DHCP Request" in net/bootp.c. Required to overcome
interoperability problems with Windows Server 200x DHCP server when U-Boot
client responds too fast for server to handle.
Signed-off-by: Aras Vaichas <arasv@magtech.com.au>
This patch fixes a problem seen on PPC4xx boards, when no MAC address is
defined. Then no ethernet interface is available but a simple "tftp"
command will return without any error message which is quite confusing.
Retry to send NFS packet before reaching timeout.
Signed-off-by: Hiroshi Ito <ito@mlb.co.jp>
allow to use a different server as set in serverip
add CONFIG_TFTP_FILE_NAME_MAX_LEN to configure the file name length
if not defined the max length will be at 128
Add support for the ATNGW100 Network Gateway reference design,
including flash, ethernet and MMC support.
Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
Signed-off by: John Rigby <jrigby@freescale.com>
[PATCH] net: add 'ethrotate' environment variable
This patch replaces the buildtime configuration option
CONFIG_NET_DO_NOT_TRY_ANOTHER through the 'ethrotate' runtime
configuration veriable. See README.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
