path: root/net
2011-11-23net/bootp.c: Fix GCC 4.6 warningAnatolij Gustschin
Fix: bootp.c: In function 'BootpCopyNetParams': bootp.c:108:11: warning: unused variable 'tmp_ip' [-Wunused-variable] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-11-07net/net.c: Fix GCC 4.6 build warningWolfgang Denk
Fix: net.c: In function 'CDPHandler': net.c:1083:8: warning: variable 'applid' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-10-27net: Export auto_load, use it in rarpSimon Glass
The rarp code includes another instance of the auto_load logic, so call what is now net_auto_load() instead. This also fixes an incorrect call to TftpStart() which was never seen since apparently no boards enable rarp. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-27net: Change for loop to memset()Simon Glass
This is intended purely as a code size reduction. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-27net: Add more #ifdefs for tftpput to reduce code sizeSimon Glass
If CONFIG_CMD_TFTPPUT is not enabled, we want minimal code size impact on the tftp code. This introduces a few more #ifdefs. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-27net: Make net_transfer() a static functionSimon Glass
This should be a static function so it can be inlined. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-27net: Hide more code behind CONFIG_CMD_TFTPPUTSimon Glass
This commit reduces code size a little by making the ICMP handler only available to tftpput. This is reasonable since it is the only user at present (ping just uses the normal handler). Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26net: tftpput: implement tftp logicSimon Glass
This adds logic to tftp.c to implement the tftp 'put' command, and updates the README. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26net: tftpput: Support selecting get/put for tftpSimon Glass
TftpStart should support starting either a get or a put. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26net: tftpput: Factor out start, restart and next block functionsSimon Glass
This code is required for tftpput, so move it into separate functions. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26net: tftpput: move common code into separate functionsSimon Glass
We want to show block markers on completion of get and put, so move this common code into separate functions. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26net: tftpput: Rename TFTP to TFTPGETSimon Glass
This is a better name for this protocol. Also remove the typedef to keep checkpatch happy, and move zeroing of NetBootFileXferSize a little earlier since TFTPPUT will need to change this. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26net: tftpput: Add support for receiving ICMP packetsSimon Glass
ICMP packets can tell you when there is no server at the other end. It is useful for tftp to figure this out, so that a quick error can be displayed, rather than pointlessly retrying. This adds an ICMP packet handler to the net interface. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26net: tftpput: Move ICMP code into its own functionSimon Glass
NetReceive() is a very long function with a lot of indent. Before adding code to the ICMP bit, split it out. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-23net/dns.c: Fix endian conversion for big-endian in dns commandBernhard Kaindl
net/dns.c used endian conversion macros wrongly (shorts in reply were put swapped into CPU, and then ntohs() was used to swap it back, which broke on big-endian). Fix this by using the correct linux conversion macro for reading a unaligned short in network byte order: get_unaligned_be16() Thanks to Mike Frysinger pointing at the best macro to use. Tested on big and little endian qemu boards (mips and versatile) Signed-off-by: Bernhard Kaindl <bernhard.kaindl@thalesgroup.com> Cc: Pieter Voorthuijsen <pieter.voorthuijsen@prodrive.nl> Cc: Robin Getz <rgetz@blackfin.uclinux.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-17net: bootp: add PXE/RFC 4578 DHCP options supportJason Hobbs
These options are required to be present in RFC 4578 compliant DHCP requests. They give more information to DHCP servers to allow serving different DHCP responses to different systems based on client architecture, client capabilities, UUID, or vendor. Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com>
2011-10-05net: drop !NET_MULTI codeMike Frysinger
This is long over due. All but two net drivers have been converted, but those have now been dropped. The only thing left to do is actually delete all references to NET_MULTI and code that is compiled when that is not defined. So here we scrub the core code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-05net: drop !NET_MULTI ns7520 driverMike Frysinger
This driver was never converted to NET_MULTI, and no board uses it. So punt it and be done. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-01net: Add \n before warning message so it prints on a new line.Philip Balister
Signed-off-by: Philip Balister <philip@opensdr.com>
2011-09-21net: turn name len check into an assertMike Frysinger
The new sanity check introduces a printf warning for some systems: eth.c:233: warning: format '%zu' expects type 'size_t', but argument 3 has type 'int' Rather than tweak the format string, use the new assert() helper instead. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-09-19net/bootp.c: fix tftp load if autoload environment var isn't setPeter Korsgaard
Commit 093498669 (Put common autoload code into auto_load() function) broke handling of autoload environment variable not being set. The bootp/dhcp code will just keep on requesting IP address forever and never start TFTP download. Fix it by moving TftpStart() outside the conditional like it was before. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Tested-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Simon Glass <sjg@chromium.org>
2011-09-09net/eth.c: throw BUG for eth_get_dev_by_name(NULL)Helmut Raiger
eth_get_dev_by_name() is not safe to use for devname being NULL as it uses strcmp. This patch makes it fail with a BUG(). Signed-off-by: Helmut Raiger <helmut.raiger@hale.at> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-09-05Correct call to eth_write_hwaddr()Simon Glass
This fixes "Warning: failed to set MAC address" on platforms which rely on an 'ethaddr' environment variable to set the MAC address. This bug was introduced by this commit: 7616e785 Add Ethernet hardware MAC address framework to usbnet Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Kumar Gala <galak@kernel.crashing.org> Tested-by: Michal Simek <monstr@monstr.eu> Tested-by: Heiko Schocher <hs@denx.de>
2011-09-04net: Check network device driver nameMichal Simek
If name is longer than allocated space NAMESIZE mac address is rewritten which show error message like: Error message: Warning: Xlltemac.87000000 MAC addresses don't match: Address in SROM is 30:00:00:00:00:00 Address in environment is 00:0a:35:00:6a:04 NAMESIZE contains Driver name + zero terminated character. Signed-off-by: Michal Simek <monstr@monstr.eu>
2011-08-08Put common autoload code into auto_load() functionSimon Glass
This is a small clean-up patch. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Eric Bénard <eric@eukrea.com>
2011-08-08Add Ethernet hardware MAC address framework to usbnetSimon Glass
Built-in Ethernet adapters support setting the mac address by means of a ethaddr environment variable for each interface (ethaddr, eth1addr, eth2addr). This adds similar support to the USB network side, using the names usbethaddr, usbeth1addr, etc. They are kept separate since we don't want a USB device taking the MAC address of a built-in device or vice versa. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Eric Bénard <eric@eukrea.com>
2011-08-03net/eth.c: drop obsolete at91rm9200 supportAndreas Bießmann
All available at91rm9200 boards have migrated to ar920t/at91 and therefore to CONFIG_NET_MULTI. The obsolete at91rm9200_miiphy_initialize() was removed in "ARM: remove obsolete at91rm9200". Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2011-07-27bootp: add ntpserver option to bootp requestLuuk Paulussen
Signed-off-by: Luuk Paulussen <luuk.paulussen@alliedtelesis.co.nz> Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz> Cc: Ben Warren <biggerbadderben@gmail.com>
2011-06-01net/net.c: Update ipaddr if the environment has changedEnric Balletbo i Serra
At least on ARM the ipaddr is only set in board_init_r function. The problem is if ipaddr is not defined in environment importing another environment defined don't update the ipaddr value. For example, suppose we've a default environment without net variables defined and we want to import an uEnv.txt environment from SD-card like this: ipaddr=192.168.2.240 netmask=255.255.255.0 gatewayip=192.168.2.1 serverip=192.168.2.114 Then if you try boot from NFS results in: Importing environment from mmc ... Running uenvcmd ... smc911x: detected LAN9221 controller smc911x: phy initialized smc911x: MAC ac:de:48:00:00:00 *** ERROR: `ipaddr' not set The ipaddr at this point is NULL beacause is only set at board_init_r function. This patch updates the ipaddr value if the environment has changed. Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-05-19net/tftp.c: fix typoLuca Ceresoli
Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2011-05-19TFTP: add tftpsrv commandLuca Ceresoli
2011-05-19TFTP: net/tftp.c: add server mode receiveLuca Ceresoli
2011-05-19TFTP: rename STATE_RRQ to STATE_SEND_RRQLuca Ceresoli
With the upcoming TFTP server implementation, requests can be either outgoing or incoming, so avoid ambiguities. Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2011-05-19TFTP: replace "server" with "remote" in local variable namesLuca Ceresoli
With the upcoming TFTP server implementation, the remote node can be either a client or a server, so avoid ambiguities. Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2011-05-19net/tftp.c: cosmetic: do not initialise statics to 0 or NULLLuca Ceresoli
This removes the following checkpatch issue: - ERROR: do not initialise statics to 0 or NULL Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de>
2011-05-19net/tftp.c: cosmetic: fix indentationLuca Ceresoli
This removes the following checkpatch issue: - WARNING: suspect code indent for conditional statements Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de>
2011-05-19net/tftp.c: cosmetic: trailing statements should be on next lineLuca Ceresoli
This removes the following checkpatch issue: - ERROR: trailing statements should be on next line Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de>
2011-05-19net/tftp.c: cosmetic: fix brace issuesLuca Ceresoli
This removes the following checkpatch issues: - WARNING: braces {} are not necessary for single statement blocks - WARNING: braces {} are not necessary for any arm of this statement Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de>
2011-05-19net/tftp.c: cosmetic: do not use assignment in if conditionLuca Ceresoli
This removes the following checkpatch issue: - ERROR: do not use assignment in if condition. There is one such error left: ERROR: do not use assignment in if condition #239: FILE: tftp.c:239: + if (!ProhibitMcast + && (Bitmap = malloc(Mapsize)) + && eth_get_dev()->mcast) { which would require an additional nested if to be fixed, resulting in longer and less readable code. Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de>
2011-05-19net/tftp.c: cosmetic: fix pointer syntax issuesLuca Ceresoli
This removes the following checkpatch issues: - ERROR: "foo * bar" should be "foo *bar" - ERROR: "(foo*)" should be "(foo *)" Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de>
2011-05-19net/tftp.c: cosmetic: fix whitespace issuesLuca Ceresoli
This removes the following checkpatch issues: - ERROR: space prohibited before that close parenthesis ')' - ERROR: space required after that ';' (ctx:BxV) - ERROR: space required after that ',' (ctx:VxV) - ERROR: space required after that ';' (ctx:VxV) - ERROR: spaces required around that '<<=' (ctx:VxV) - ERROR: spaces required around that '<' (ctx:VxV) - ERROR: spaces required around that '=' (ctx:VxV) - ERROR: spaces required around that '+=' (ctx:VxV) - ERROR: spaces required around that '=' (ctx:VxW) - WARNING: please, no spaces at the start of a line - WARNING: space prohibited between function name and open parenthesis '(' Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de>
2011-05-19net/tftp.c: cosmetic: fix lines over 80 charactersLuca Ceresoli
2011-05-12net/net.c: cosmetic: do not use assignment in if conditionLuca Ceresoli
This removes the following checkpatch issue: - ERROR: do not use assignment in if condition Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Cc: Ben Warren <biggerbadderben@gmail.com>
2011-05-12net/net.c: cosmetic: fix indentationLuca Ceresoli
This removes the following checkpatch issues: - ERROR: switch and case should be at the same indent - WARNING: suspect code indent for conditional statements - WARNING: labels should not be indented Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Cc: Ben Warren <biggerbadderben@gmail.com>
2011-05-12net/net.c: cosmetic: parentheses not required for returnLuca Ceresoli
This removes the following checkpatch issue: - ERROR: return is not a function, parentheses are not required Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Cc: Ben Warren <biggerbadderben@gmail.com>
2011-05-12net/net.c: cosmetic: fix pointer syntax issuesLuca Ceresoli
This removes the following checkpatch issues: - ERROR: "foo * bar" should be "foo *bar" - ERROR: "(foo*)" should be "(foo *)" Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Cc: Ben Warren <biggerbadderben@gmail.com>
2011-05-12net/net.c: cosmetic: fix brace issuesLuca Ceresoli
This removes the following checkpatch issues: - WARNING: braces {} are not necessary for single statement blocks - WARNING: braces {} are not necessary for any arm of this statement Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Cc: Ben Warren <biggerbadderben@gmail.com>
2011-05-12net/net.c: cosmetic: fix whitespace issuesLuca Ceresoli
This removes the following checkpatch issues: - ERROR: space prohibited after that open parenthesis '(' - ERROR: space prohibited before that close parenthesis ')' - ERROR: space prohibited after that open square bracket '[' - ERROR: space prohibited after that '&' (ctx:WxW) - ERROR: spaces required around that '=' (ctx:VxW) - ERROR: space required before the open parenthesis '(' - ERROR: space required after that ',' (ctx:VxV) - ERROR: need consistent spacing around '+' (ctx:WxV) - WARNING: unnecessary whitespace before a quoted newline - WARNING: please, no spaces at the start of a line - WARNING: space prohibited between function name and open parenthesis '(' Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Cc: Ben Warren <biggerbadderben@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2011-05-12net/net.c: cosmetic: variable initializationsLuca Ceresoli
This removes the following checkpatch errors: - ERROR: do not initialise globals to 0 or NULL - ERROR: spaces required around that '=' (ctx:VxV) - ERROR: that open brace { should be on the previous line Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Cc: Ben Warren <biggerbadderben@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2011-05-12net/net.c: cosmetic: fix lines over 80 charactersLuca Ceresoli
This removes the following checkpatch warning: - WARNING: line over 80 characters There are three such warnings left. The first is hard to fix with cosmetic-only changes without compromising code readability, so I'm leaving it as it is for now: WARNING: line over 80 characters #1537: FILE: net.c:1537: + [4 tabs] memcpy(((Ethernet_t *)NetArpWaitTxPacket)->et_dest, ... The other two cannot be fixed without splitting string literals, so it is preferred to keep them longer than 80 characters. Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Cc: Ben Warren <biggerbadderben@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
