The compiler will help find mismatches between printf formats and
arguments if you let it. This patch adds the necessary attributes to
declarations in include/common.h, then begins to correct the resulting
compiler warnings. Some of these were bugs, e.g., "$d" instead of
"%d" and incorrect arguments. Others were just annoying, like
int-long mismatches on a system where both are 32 bits. It's worth
fixing the annoying errors to catch the real ones.
Signed-off-by: Andrew Klossner <andrew@cesa.opbu.xerox.com>
This patch is the first step in cleaning up net/eth.c, by moving Ethernet
initialization to CPU or board-specific code. Initial implementation is
only on the Freescale TSEC controller, but others will be added soon.
U-boot can complain a lot about 'checksum bad' when it is attached to the network.
It is annoying for ordinary users who start to doubt the network connection
in general when they see messages like this.
This is caused by the routine NetCksumOk() which cannot handle IP-headers longer
than 20 bytes. Those packages can be ignored anyway by U-boot, so we trash them
now before checking the checksum.
Signed-off-by: Remy Bohmer <linux@bohmer.net>
Merge branch 'testing-V2'
board/atmel/at91cap9adk/Makefile
Fixing copyright
board/atmel/at91sam9260ek/Makefile
Fixing copyright
board/atmel/at91sam9260ek/u-boot.lds
Delete no more needed ld script
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
This patch adds support for the AT91SAM9263 chip and the AT91SAM9263EK
board.
Signed-off-by: Stelian Pop <stelian@popies.net>
Currently the timeout waiting for an ARP reply is hard set to 5 seconds.
On i.MX31ADS due to a hardware "strangeness" up to four first IP packets
to the boards get lost, which typically are ARP replies. By configuring
the timeout to a lower value we significantly improve the first network
transfer time on this board. The timeout is specified in milliseconds,
later internally it is converted to deciseconds, because it has to be
converted to hardware ticks, and CFG_HZ ranges from 900 to 27000000 on
different boards.
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
Support for booting from internal DataFlash, external DataFlash card
or NAND flash is available.
AT91CAP9 and AT91SAM9 SoCs are very close hardware wise, so a
common infrastructure can be used. Let this infrastructure be
named after the AT91SAM9 family, and move the existing AT91CAP9
files to the new place.
GRETH is an Ethernet 10/100 or 10/100/1000 MAC with out without
a debug link (EDCL). The GRETH core is documented in GRIP.pdf
available at www.gaisler.com.
If the GRETH has GigaBit support (GBIT, Scatter gather, checksum
offloading etc.) can be determined by a bit in the control register.
The GBIT MAC is supported by operating in GRTEH 10/100 legacy mode.
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
Added option CONFIG_BOOTP_DHCP_REQUEST_DELAY. This provides an optional
delay before sending "DHCP Request" in net/bootp.c. Required to overcome
interoperability problems with Windows Server 200x DHCP server when U-Boot
client responds too fast for server to handle.
Signed-off-by: Aras Vaichas <arasv@magtech.com.au>
This patch fixes a problem seen on PPC4xx boards, when no MAC address is
defined. Then no ethernet interface is available but a simple "tftp"
command will return without any error message which is quite confusing.
Retry to send NFS packet before reaching timeout.
Signed-off-by: Hiroshi Ito <ito@mlb.co.jp>
allow to use a different server as set in serverip
add CONFIG_TFTP_FILE_NAME_MAX_LEN to configure the file name length
if not defined the max length will be at 128
Add support for the ATNGW100 Network Gateway reference design,
including flash, ethernet and MMC support.
Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
Signed-off by: John Rigby <jrigby@freescale.com>
[PATCH] net: add 'ethrotate' environment variable
This patch replaces the buildtime configuration option
CONFIG_NET_DO_NOT_TRY_ANOTHER through the 'ethrotate' runtime
configuration veriable. See README.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
This patch extends the number of supported UECs to 4. Note that the
problem of QE thread resources exhaustion is resolved by setting the
correct number of QE threads according to Ethernet type (GBE or FE).
Signed-off-by: David Saada <david.saada@ecitele.com>
Change return values of init() functions in all Ethernet drivers to conform
to the following:
>=0: Success
<0: Failure
All drivers going forward should return 0 on success. Current drivers that
return 1 on success were left as-is to minimize changes.
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
Acked-By: Timur Tabi <timur@freescale.com>
Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
When CONFIG_NET_DO_NOT_TRY_ANOTHER is defined U-Boot's
networking stack does not automatically switch to
another interface. This patch does not touch the default
behavior.
This patch modifies the return code handling in the eth_init()
function, to be compatible with the handling of the return codes in
the other network stack files. It now returns a 0 on Success and -1 on
error.
Signed-off-by: Upakul Barkakaty <upakul.barkakaty@conexant.com>
Assigning the output of simple_strtoul(CB:A9:87:65:43:21) to `char', we are
warned as below:
U-Boot 1.2.0 (Aug 30 2007 - 08:27:37)
DRAM: 256 MB
Flash: 32 MB
In: serial
Out: serial
Err: serial
Net: NEC-Candy
Warning: NEC-Candy MAC addresses don't match:
Address in SROM is 00:00:4C:80:92:A2
Address in environment is FFFFFFCB:FFFFFFA9:FFFFFF87:65:43:21
This patch changes env_enetaddr type from `char' to `unsigned char'.
Cc: Masaki Ishikawa <ishikawa-masaki@cnt.mxe.nes.nec.co.jp>
Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
The purpose of this routine is receiving a single network frame, outside of
U-Boot's NetLoop(). Exporting it to standalone programs that run on top of
U-Boot will let them utilise networking facilities. For sending a raw frame
the already existing eth_send() can be used.
The direct consumer of this routine is the newly introduced API layer for
external applications (enabled with CONFIG_API).
Signed-off-by: Rafal Jaworowski <raj@semihalf.com>
Signed-off-by: Piotr Kruszynski <ppk@semihalf.com>
drivers/Makefile
This change is in preparation for condtitionial compile support in the
build system. By spliting them all into seperate lines now, subsequent
patches that change 'COBJS-y += ' into 'COBJS-$(CONFIG_<blah>) += ' will
be less invasive and easier to review
This patch implements general ULi 526x Ethernet driver.
Until now, it is the only native Ethernet port on
MPC8610HPCD board, but it could be used on other boards
with ULi 526x Ethernet port as well.
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
Signed-off-by: Zhang Wei <wei.zhang@freescale.com>
Acked-by: Jon Loeliger <jdl@freescale.com>
Signed-off-by: Ben Warren <bwarren@qstreams.com>
An obvious typo. Originally fixed in linkstation u-boot port.
This is a multi-part message in MIME format.
commit e6e505eae94ed721e123e177489291fc4544b7b8
Author: Justin Flammia <jflammia@savantav.com>
Date: Mon Oct 29 17:19:03 2007 -0400
Found a bug in the way the DHCP Request packet is built, where the IP address
that is offered by the server is bound to prematurely. This patch is a fix of
that bug where the IP address offered by the DHCP server is not used until
after the DHCP ACK from the server is received.
Signed-off-by: Justin Flammia <jflammia@savantav.com>
The old code had a loop limit overflow bug which caused a semi-
infinite loop for small packets, because in "i<len-8", "i" was signed,
but "len" was unsigned, and "len-8" became a huge number for small
values of "len".
This is a workaround which replaces broken commit 8f1bc284.
The TFTP OACK code trusts that the incoming packet is formated as
ASCII text and can be processed by string functions. It also has a
loop limit overflow bug where if the packet length is less than 8, it
ends up looping over *all* of memory to find the 'blksize' string.
This patch solves the problem by forcing the packet to be null
terminated and using strstr() to search for the sub string.
TFTP does not work anymore after multicast tftp
patch was applied on little endian systems.
This patch fix it.
Remove a leftover in net/tftp.c while we're at it.
