path: root/net
2017-08-16env: Rename some other getenv()-related functionsSimon Glass
We are now using an env_ prefix for environment functions. Rename these other functions as well, for consistency: getenv_vlan() getenv_bootm_size() getenv_bootm_low() getenv_bootm_mapsize() env_get_default() Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename eth_getenv_enetaddr() to eth_env_get_enetaddr()Simon Glass
Rename this function for consistency with env_get(). Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename getenv_hex(), getenv_yesno(), getenv_ulong()Simon Glass
We are now using an env_ prefix for environment functions. Rename these for consistency. Also add function comments in common.h. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename eth_setenv_enetaddr() to eth_env_set_enetaddr()Simon Glass
Rename this function for consistency with env_set(). Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename common functions related to setenv()Simon Glass
We are now using an env_ prefix for environment functions. Rename these commonly used functions, for consistency. Also add function comments in common.h. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-07net: Use packed structures for networkingDenis Pynkin
PXE boot is broken with GCC 7.1 due option '-fstore-merging' enabled by default for '-O2': BOOTP broadcast 1 data abort pc : [<8ff8bb30>] lr : [<00004f1f>] reloc pc : [<17832b30>] lr : [<878abf1f>] sp : 8f558bc0 ip : 00000000 fp : 8ffef5a4 r10: 8ffed248 r9 : 8f558ee0 r8 : 8ffef594 r7 : 0000000e r6 : 8ffed700 r5 : 00000000 r4 : 8ffed74e r3 : 00060101 r2 : 8ffed230 r1 : 8ffed706 r0 : 00000ddd Flags: nzcv IRQs off FIQs off Mode SVC_32 Resetting CPU ... Core reason is usage of structures for network headers without packed attribute. Reviewed-by: Yauheni Kaliuta <yauheni.kaliuta@redhat.com> Signed-off-by: Denis Pynkin <denis.pynkin@collabora.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-08-07net: Fix compile failure in net.cHolger Dengler
Add missing "defined" statement to fix the compile failures. Signed-off-by: Holger Dengler <dengler@linutronix.de> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-08-07net: tftp: silence a subscript above array bounds compile time warningVladimir Zapolskiy
For strncpy() select a minimal string length of destination and source strings, here DEFAULT_NAME_LEN is preferable to MAX_LEN. Due to the NUL-terminated contents of default_string the change is a noop, however it removes a compilation warning if SH2/3/4 platform specific strncpy() function is used: In file included from include/linux/string.h:21:0, from include/common.h:28, from net/tftp.c:9: net/tftp.c: In function 'tftp_start': arch/sh/include/asm/string.h:52:42: warning: array subscript is above array bounds [-Warray-bounds] : "0" (__dest), "1" (__src), "r" (__src+__n) Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-08-07net: Get mac address from driver as seedJimmy Du
Previously seeded by obtaining mac addr from env. If mac addr was never set, rand would output 0. This fix obtains the mac addr from driver instead. Signed-off-by: Jimmy Du <jimmy.du@ni.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-06-02net: core: avoid possible NULL pointer dereferencexypron.glpk@gmx.de
Checking if dev is NULL after dereferencing it does not make sense. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-05-12net: Disable the format-extra-args warningTom Rini
We will see warnings such as: net/eth_common.c:57:61: warning: data argument not used by format string [-Wformat-extra-args] sprintf(enetvar, index ? "%s%daddr" : "%saddr", base_name, index); ~~~~~~~~ ^ With clang. In this case we do not want to re-write our code to be less compact as the above is intentional and readable. Add a comment above the disabling so that it's clear why we want that warning off. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-12net/arp: remove superfluous assignmentsxypron.glpk@gmx.de
The value of variable pkt is never used. The problem was indicated by clang scan-build. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2017-03-26net: link_local: Fix netmask endianness bugAlexandre Messier
The network mask must be stored in network order when in a 'struct in_addr'. This fix removes the "gatewayip needed but not set" message on the console when using a link-local IP setup. Signed-off-by: Alexandre Messier <amessier@tycoint.com> Signed-off-by: Sylvain Lemieux <slemieux@tycoint.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-03-20net: don't override ethernet address environmentRoger Quadros
If the ethernet address environment is set with a valid ethernet address prevent overriding it as it is most likely set by the user and he/she doesn't want board code to automatically override it whatsoever. Signed-off-by: Roger Quadros <rogerq@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-02-07net: core: cosmetic: A MAC address is not limited to SROMoliver@schinagl.nl
Currently, we print that the MAC from the SROM does not match. It can be many forms of ROM, so lets drop the S. Signed-off-by: Olliver Schinagl <oliver@schinagl.nl> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-02-07net: cosmetic: Make the MAC address string less magicaloliver@schinagl.nl
In u-boot printf has been extended with the %pM formatter to allow printing of MAC addresses. However buffers that want to store a MAC address cannot safely get the size. Add a define for this case so the string of a MAC address can be reliably obtained. Signed-off-by: Olliver Schinagl <oliver@schinagl.nl> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-02-07net: cosmetic: Do not use magic values for ARP_HLENoliver@schinagl.nl
Commit 674bb249825a ("net: cosmetic: Replace magic numbers in arp.c with constants") introduced a nice define to replace the magic value 6 for the ethernet hardware address. Replace more hardcoded instances of 6 which really reference the ARP_HLEN (iow the MAC/Hardware/Ethernet address). Signed-off-by: Olliver Schinagl <oliver@schinagl.nl> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-01-21status_led: Kconfig migrationUri Mashiach
Move all of the status LED feature to drivers/led/Kconfig. The LED status definitions were moved from the board configuration files to the defconfig files. TBD: Move all of the definitions in the include/status_led.h to the relevant board's defconfig files. Tested boards: CL-SOM-AM57x, CM-T335 Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il>
2016-11-13net: write enetaddr down to hardware on env_callbackMarek Vasut
If mac-address is changed using "setenv ethaddr ...." command the new mac-adress also must be written into the responsible ethernet driver. This fixes the legacy ethernet handling. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Hannes Schmelzer <oe5hpm@oevsv.at> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Hannes Schmelzer <oe5hpm@oevsv.at>
2016-11-07net: use random ethernet address if invalid and not zeroSiva Durga Prasad Paladugu
Use random ethernet address if the ethernet address found is invalid, not zero and config for random address is defined. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-10-13net: write enetaddr down to hardware on env_callbackHannes Schmelzer
If mac-address is changed using "setenv ethaddr ...." command the new mac-adress also must be written into the responsible ethernet driver. Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-09-16Kconfig: spl: Add SPL support options to KconfigSimon Glass
There are a lot of SPL options in U-Boot to enable various features and drivers. Currently these do not use Kconfig. Add them to Kconfig along with suitable help, and drop them from the README. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-09Revert "net: nfs: Correct the reply data buffer size"Joe Hershberger
This reverts commit 6279b49e6c2fdaf8665355d1777bc90cd41fcf90. This caused a bad data crc. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reported-by: Guillaume GARDET <guillaume.gardet@free.fr>
2016-09-09Revert "net: nfs: Use the tx buffer to construct rpc msgs"Joe Hershberger
This reverts commit 998372b4798fd7ebb666f571950df925b8d80f69. This caused a data abort on some platform. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reported-by: Guillaume GARDET <guillaume.gardet@free.fr>
2016-08-22net: nfs: Simplify rpc_add_credentials()Joe Hershberger
We use an empty hostname, so remove all the "processing" of the known-to-be-empty hostname and just write 0's where needed. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2016-08-22net: nfs: Use the tx buffer to construct rpc msgsJoe Hershberger
Instead of always allocating a huge temporary buffer on the stack and then memcpy()ing the result into the transmit buffer, simply figure out where in the transmit buffer the bytes will belong and write them there directly as each message is built. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2016-08-22net: nfs: Move some prints to debug statementsJoe Hershberger
Much of the information is verbose and derived directly from the environment. Only output in debug mode. This also saves about 300 bytes from the code size. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2016-08-22net: nfs: Use consistent names for the rpc_pktJoe Hershberger
Use the same name throughout the nfs code and use the same member of the union to avoid casts. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2016-08-22net: nfs: Correct a commentJoe Hershberger
The buffer is of 32-bit elements, not bytes. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2016-08-22net: nfs: Consolidate handling of NFSv3 attributesJoe Hershberger
Instead of repeating the same large snippet for dealing with attributes it should be shared with a helper function. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2016-08-22net: nfs: Fix lines that are too longJoe Hershberger
Fix complaints from checkpatch.pl. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2016-08-22net: nfs: Correct the reply data buffer sizeJoe Hershberger
The type of the buffer is uint32_t, but the parameter used to size it is referring to bytes. Divide by the size of the array elements. Strictly speaking, this shouldn't be needed at all... It could just be 1 just like the request. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2016-08-22net: nfs: Share the file handle buffer for v2 / v3Joe Hershberger
The v3 handles can be larger than v2, but that doesn't mean we need a separate buffer. Reuse the same (larger) buffer for both. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2016-08-22net: NFS: Add NFSv3 supportGuillaume GARDET
This patch enables NFSv3 support. If NFSv2 is available use it as usual. If NFSv2 is not available, but NFSv3 is available, use NFSv3. If NFSv2 and NFSv3 are not available, print an error message since NFSv4 is not supported. Tested on iMX6 sabrelite with 4 Linux NFS servers: * NFSv2 + NFSv3 + NFSv4 server: use NFSv2 protocol * NFSv2 + NFSv3 server: use NFSv2 protocol * NFSv3 + NFSv4 server: use NFSv3 protocol * NFSv3 server: use NFSv3 protocol Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr> Cc: Tom Rini <trini@konsulko.com> Cc: joe.hershberger@ni.com Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-08-22net: nfs: Remove unused defineJoe Hershberger
Unreferenced, so remove the noise. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2016-08-22net: nfs: Remove separate buffer for default nameJoe Hershberger
There is no reason to store the default filename in a separate buffer only to immediately copy it to the main name buffer. Just write it there directly and remove the other buffer. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2016-08-22net: Stop including NFS overhead in defragment maxJoe Hershberger
At least on bfin, this "specimen" is actually allocated in the BSS and wastes lots of memory in already tight memory conditions. Also, with the introduction of NFSv3 support, this waste got substantially larger. Just remove it. If a board needs a specific different defragment size, that board can override this setting. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2016-07-16Various, unrelated tree-wide typo fixes.Robert P. J. Day
Fix a number of typos, including: * "compatble" -> "compatible" * "eanbeld" -> "enabled" * "envrionment" -> "environment" * "FTD" -> "FDT" (for "flattened device tree") * "ommitted" -> "omitted" * "overriden" -> "overridden" * "partiton" -> "partition" * "propogate" -> "propagate" * "resourse" -> "resource" * "rest in piece" -> "rest in peace" * "suport" -> "support" * "varible" -> "variable" Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2016-07-06net: Fix incorrect RPC packets on 64-bit systemsRalf Hubert
This patch fixes incorrect RPC packet layout caused by 'long' type size difference on 64 and 32-bit architectures. Signed-off-by: Ralf Hubert <r.hubert@technisat.de> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-06-21NFS: Add error message when U-Boot NFS version (V2) is not supported by NFS ↵Guillaume GARDET
server Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr> Cc: joe.hershberger@ni.com Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-06-12net: Handle an empty bootp extension sectionAndre Renaud
Avoid generating this section if there is nothing in it. Signed-off-by: Andre Renaud <andre@designa-electronics.com> Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-05-27net: Optionally use pxe client arch from variableAlexander Graf
The client architecture that we pass to a dhcp server depends on the target payload that we want to execute. An EFI binary has a different client arch than a legacy binary or a u-boot binary. So let's parameterize the pxe client arch field to allow an override via the distro script, so that our efi boot path can tell the dhcp server that it's actually an efi firmware. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-05-27distro: Add efi pxe boot codeAlexander Graf
Now that we can expose network functionality to EFI applications, the logical next step is to load them via pxe to execute them as well. This patch adds the necessary bits to the distro script to automatically load and execute EFI payloads. It identifies the dhcp client as a uEFI capable PXE client, hoping the server returns a tftp path to a workable EFI binary that we can then execute. To enable boards that don't come with a working device tree preloaded, this patch also adds support to load a device tree from the /dtb directory on the remote tftp server. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-05-27net: Move CONFIG_SPL_NET_VCI_STRING into KconfigAlexander Graf
This patch also adds the SPL time VCI string into Kconfig. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-05-27net: Fix client identifiers for ARMAlexander Graf
There are client identifiers specifically reserved for ARM U-Boot according to http://www.ietf.org/assignments/dhcpv6-parameters/dhcpv6-parameters.xml#processor-architecture. So let's actually make use of them rather than the bogus 0x100 that we emitted so far. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Drop the Xilinx define to 0x100 as it's not the correct value to use]. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-05-27net: Move the VCI and client arch values to KconfigAlexander Graf
We have a bunch of boards that define their vendor class identifier and client archs in the board files or in the distro config. Move everything to the generic Kconfig options. We're missing the distinction between i386 and x86_64, as I couldn't find any config variable that would tell us the difference. Is that really important to people? I guess not, so I left it out. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-05-27bootp: Move vendor class identifier set to functionAlexander Graf
Both the dhcp as well as the bootp case add vendor class identifier parameters into their packets. Let's move that into a separate function to make overlaying easier. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Tom Rini <trini@konsulko.com>
