With a define for the magic number of packets received as batch
we can make sure that the EFI network stack caches the same amount
of packets.
Signed-off-by: Patrick Wildt <patrick@blueri.se>
net_init does not always succeed, and there is no existing mechanism to
discover errors. This patch allows callers of net_init (such as net_init)
to handle errors. The root issue is that eth_get_dev can fail, but
net_init_loop doesn't expose that. The ideal way to fix eth_get_dev would
be to return an error with ERR_PTR, but there are a lot of callers, and all
of them just check if it's NULL. Another approach would be to change the
signature to something like
int eth_get_dev(struct udevice **pdev)
but that would require rewriting all of the many callers.
Signed-off-by: Sean Anderson <seanga2@gmail.com>
This commits update the support of sntp to use
the framework udp. This change allows to remove
all the reference to sntp in the main network
file net/net.c.
Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
This commit adds a generic udp protocol framework in the
network loop. So protocol based on udp may be implemented
without modifying the network loop (for example custom
wait magic packet).
Write the 'No ethernet found' message via the log drivers. This allows
suppressing it during output via the syslog driver.
This fixes the problem reported in:
[PATCH 0/4] log: Fix the syslog spam when running tests
https://lists.denx.de/pipermail/u-boot/2020-September/426343.html
Reported-by: Simon Glass <sjg@chromium.org>
When load the last block, the "len" might not be a block size. This cause
loading the incorrect last block data.
The fix change "len" to tftp_block_size and minus one tftp_block_size
for offset calculation.
Use same offset calculation formula as in store_block().
Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
Reviewed-By: Ramon Fried <rfried.dev@gmail.com>
tftp_cur_block start with 1 for first block, but tftp_cur_block counter is
start with zero when block number is rollover. The existing code
"tftp_cur_block - 1" will cause the block number become -1 in store_block()
when tftp_cur_block is 0 when tftp_cur_block is rollover.
The fix pass in tftp_cur_block to store_block() and minus the
tftp_block_size when do the offset calculation.
Fixes missing update to tftp_prev_block counter before increase
tftp_cur_block counter when do the tftpput operation.
tftp_prev_block counter is used in update_block_number() function to
check whether block number (sequence number) is rollover. This bug
cause the tftpput command fail to upload a large file when block
number is greater than 16-bit (0xFFFF).
The name of the device we are working on is `ethdev` and not just `dev`.
Tested-by: Patrick Delaunay <patrick.delaunay@st.com>
Android 10 adds support for dynamic partitions and in order to support
this userspace fastboot must be used[1]. New tool fastbootd is
included into recovery.
Userspace fastboot works from recovery and is launched if:
1) - Dynamic partitioning is enabled
2) - Boot control block has 'boot-fastboot' value into command field
The bootloader is expected to load and boot into the recovery image
upon seeing boot-fastboot in the BCB command. Recovery then parses the
BCB message and switches to fastbootd mode[2].
Please note that boot script is expected to handle 'boot-fastboot'
command in BCB and load into recovery mode.
Bootloader must support 'reboot fastboot' command which should reboot
device into userspace fastboot to accomodate those changes[3].
Another command that bootloader must support[3] is 'reboot recovery'. This
command should simply reboot device into recovery mode.
[1] - https://source.android.com/devices/bootloader/fastbootd
[2] - https://source.android.com/devices/bootloader/fastbootd#unified_fastboot_and_recovery
[3] - https://source.android.com/devices/bootloader/fastbootd#modifications_to_the_bootloader
Signed-off-by: Roman Kovalivskyi <roman.kovalivskyi@globallogic.com>
Signed-off-by: Roman Stratiienko <r.stratiienko@gmail.com>
Change-Id: I9d2bdc9a6f6f31ea98572fe155e1cc8341e9af76
Reset the stored ping IP address before entering a netloop with different
protocol to ensure that it won't be interrupted by the received
correct ICMP_ECHO_REPLY packet.
Add support for RFC 7440: "TFTP Windowsize Option".
This optional feature allows the client and server
to negotiate a window size of consecutive blocks to send as an
alternative for replacing the single-block lockstep schema.
windowsize can be defined statically during compilation by
setting CONFIG_TFTP_WINDOWSIZE, or defined in runtime by
setting an environment variable: "tftpwindowsize"
If not defined, the windowsize is set to 1, meaning that it
behaves as it was never defined.
Choosing the appropriate windowsize depends on the specific
network topology, underlying NIC.
You should test various windowsize scenarios and see which
best work for you.
Setting a windowsize too big can actually decreases performance.
Signed-off-by: Ramon Fried <rfried.dev@gmail.com>
This header file should not be included in other header files. Remove it
and use other headers and C inclusions instead.
CONFIG_BOOTP_SEND_HOSTNAME
The Linux coding style guide (Documentation/process/coding-style.rst)
clearly says:
It's a **mistake** to use typedef for structures and pointers.
Besides, using typedef for structures is annoying when you try to make
headers self-contained.
Let's say you have the following function declaration in a header:
void foo(bd_t *bd);
This is not self-contained since bd_t is not defined.
To tell the compiler what 'bd_t' is, you need to include <asm/u-boot.h>
#include <asm/u-boot.h>
void foo(bd_t *bd);
Then, the include direcective pulls in more bloat needlessly.
If you use 'struct bd_info' instead, it is enough to put a forward
declaration as follows:
struct bd_info;
void foo(struct bd_info *bd);
Right, typedef'ing bd_t is a mistake.
I used coccinelle to generate this commit.
The semantic patch that makes this change is as follows:
<smpl>
typedef bd_t;
-bd_t
+struct bd_info
</smpl>
Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
Similar to patch 821fec0ceb3e ("net: remove scary warning about EEPROM
provided MAC address") this removes the somewhat awkward "warning" on
boards using DM_ETH:
In many parts of the computing world having a unique MAC address
sitting in some on-NIC storage is considered the normal case.
If there is a properly provided MAC address (either from ROM or from DT),
remove the warning to not scare the user unnecessarily.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
The random_port() routine is not used anywhere else. Make it local to
dns.c to reduce code clutter, and shrink generated code a little.
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
RFC2348, RFC2349:
- Option string is case in-sensitive.
- Client must generate ERR pkt in case option value mismatch in server OACK
- Fix debug print for options
Signed-off-by: Ravik Hasija <rahasij@linux.microsoft.com>
During packet sequence number wraparound the show_block_marker() API was
not called, as a result the progress marker doesn't stay within column
boundary. Use position in file instead of sequence number to align the
marker.
If 'CONFIG_CMD_TFTPBOOT' or 'CONFIG_CMD_BOOTP' are disabled, the usage must be disabled, too!
Signed-off-by: Olaf Krebs <olaf.krebs@emh-metering.com>
CC: Joe Hershberger <joe.hershberger@ni.com>
Move this uncommon header out of the common header.
Move this header out of the common header.
We should not use typedefs in U-Boot. They cannot be used as forward
declarations which means that header files must include the full header to
access them.
Drop the typedef and rename the struct to remove the _s suffix which is
now not useful.
This requires quite a few header-file additions.
Move this fairly uncommon header out of the common header.
Move this header out of the common header. Network support is used in
quite a few places but it still does not warrant blanket inclusion.
Note that this net.h header itself has quite a lot in it. It could be
split into the driver-mode support, functions, structures, checksumming,
etc.
For dual ethernet controllers, the HW design may connect ETH phys to
one MDIO ports. So two different ethernet drivers have to share MDIO bus.
Since two ethernet drivers are independent, we can't ensure their probe
order.
To resolve this problem, introduce an eth phy generic driver and uclass.
After eth-uclass binds, we search the mdio node and binds the phy node
with the eth-phy-generic driver.
When one eth driver get its phy device, the parent of phy device will
probe prior than phy device. So this ensure the eth driver ownes the
MDIO bus will be probed before using its MDIO.
Signed-off-by: Ye Li <ye.li@nxp.com>
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Add return value check
Remove the unneeded define TFTP_MTU_BLOCKSIZE.
Since the KConfig migration done by commit b618b3707633 ("net:
Convert CONFIG_TFTP_BLOCKSIZE to Kconfig"), CONFIG_TFTP_BLOCKSIZE
is always defined and can be used directly to avoid confusion
(fallback to 1468 in code is never used).
Add help message for the CONFIG_TFTP_BLOCKSIZE default value,
as explain in tftp.c before migration in commit b618b3707633
("net: Convert CONFIG_TFTP_BLOCKSIZE to Kconfig")
When local-mac-address DT property is specified it is reported the same way
as address read from eeprom/ROM. Show properly if mac address is coming
from DT or ROM.
When printing unsigned numbers use %u.
Signed-off-by: Rasmus Villemoes <rasmus.villemoes@prevas.dk>
At present dm/device.h includes the linux-compatible features. This
requires including linux/compat.h which in turn includes a lot of headers.
One of these is malloc.h which we thus end up including in every file in
U-Boot. Apart from the inefficiency of this, it is problematic for sandbox
which needs to use the system malloc() in some files.
Move the compatibility features into a separate header file.
These three globals relate to image handling. Move them to the image
header file.
These global variables are quite short and generic. In fact the same name
is more often used locally for struct members and function arguments.
Add a image_ prefix to make them easier to distinguish.
This function belongs more in flash.h than common.h so move it.
Also remove the space before the bracket in some calls.
These functions are used by code outside the network support, so move them
to lib/ to be more accessible.
Without this, the functions are only accessible in SPL/TPL only if
CONFIG_SPL/TPL_NET are defined. Many boards do not enable those option but
still want to do checksums in this format.
Fix up a few code-style nits while we are here.
The function connects an ethernet device to a PHY using DT information.
This API is only available for eth devices with an associated device tree
node.
Signed-off-by: Alex Marginean <alexandru.marginean@nxp.com>
Renamed dm_mdio_phy_connect arguments dev to mdiodev and addr to phyaddr
for a bit more clarity and consistency with the following patches.
Also use NULL instead of 0 on error return path.
Commit b618b3707633 ("net: Convert CONFIG_TFTP_BLOCKSIZE to Kconfig")
accidentally set the default *option* TFTP block size to 512 bytes, even
though the comment in the code says that this is a terrible choice. Most
boards didn't define the symbol before, so they got the default block size
of 1468 bytes before, but now use 512 bytes, which is also the fallback.
This leads to both abysmal performance and a lot of hashes printed
on the screen (one character for every 5K), which is both annoying and
slow over serial links.
Set the default block size in Kconfig back to the value it had before.
This improves TFTP performance from 2.8 MB/s to 6.9 MB/s on a Pine64.
Fixes: b618b3707633 ("net: Convert CONFIG_TFTP_BLOCKSIZE to Kconfig")
device_probe() may fail in which case the seq_id will be -1. Don't
display these devices during startup. While this is only a cosmetic
change, the return value of eth_initialize() will also change to the
actual number of available devices. The return value is only used in
spl_net to decide whether there are any devices to boot from. So
returning only available devices is also more correct in that case.
Signed-off-by: Michael Walle <michael@walle.cc>
During testing of qemu-riscv32 with a 2GiB memory configuration,
tftp always fails with a error message:
Load address: 0x84000000
Loading: #
TFTP error: trying to overwrite reserved memory...
It turns out the result of 'tftp_load_addr + tftp_load_size' just
overflows (0x100000000) and the test logic in store_block() fails.
Fix this by adjusting the end address to ULONG_MAX when overflow
is detected.
Fixes: a156c47e39ad ("tftp: prevent overwriting reserved memory")
sandbox_defconfig does not compile using GCC 9.2.1:
net/net.c: In function ‘net_process_received_packet’:
net/net.c:1288:23: error: taking address of packed member of ‘struct
ip_udp_hdr’ may result in an unaligned pointer value
[-Werror=address-of-packed-member]
1288 | sumptr = (ushort *)&(ip->udp_src);
Avoid the error by using a u8 pointer instead of an u16 pointer and
in-lining ntohs().
Simplify the checksumming of the last message byte.
While we have networking use cases within SPL we do not support loading
files via NFS at this point in time. Disable calling nfs_start() so
that the NFS related code can be garbage collected at link time.
Part of the env cleanup moved this out of the environment code and into
the net code. However, this helper is sometimes needed even when the net
stack isn't included.
Move the helper to lib/net_utils.c like it's similarly-purposed
string_to_ip(). Also rename the moved function to similar naming.
Reported-by: Ondrej Jirman <megous@megous.com>
This function belongs in time.h so move it over and add a comment.
Create a new rand.h header file and move functions into it, to reduce
the size of common.h
