Add return value check
Coverity 392391
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Currently, we print that the MAC from the SROM does not match. It can be
many forms of ROM, so lets drop the S.
Signed-off-by: Olliver Schinagl <oliver@schinagl.nl>
In u-boot printf has been extended with the %pM formatter to allow
printing of MAC addresses. However buffers that want to store a MAC
address cannot safely get the size. Add a define for this case so the
string of a MAC address can be reliably obtained.
Commit 674bb249825a ("net: cosmetic: Replace magic numbers in arp.c with
constants") introduced a nice define to replace the magic value 6 for
the ethernet hardware address. Replace more hardcoded instances of 6
which really reference the ARP_HLEN (iow the MAC/Hardware/Ethernet
address).
Move all of the status LED feature to drivers/led/Kconfig.
The LED status definitions were moved from the board configuration
files to the defconfig files.
TBD: Move all of the definitions in the include/status_led.h to the
relevant board's defconfig files.
Tested boards: CL-SOM-AM57x, CM-T335
Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il>
If mac-address is changed using "setenv ethaddr ...." command the new
mac-adress also must be written into the responsible ethernet driver.
This fixes the legacy ethernet handling.
Cc: Hannes Schmelzer <oe5hpm@oevsv.at>
Reviewed-by: Hannes Schmelzer <oe5hpm@oevsv.at>
Use random ethernet address if the ethernet address found
is invalid, not zero and config for random address
is defined.
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
Now, arch/${ARCH}/include/asm/errno.h and include/linux/errno.h have
the same content. (both just wrap <asm-generic/errno.h>)
Replace all include directives for <asm/errno.h> with <linux/errno.h>.
[trini: Fixup include/clk.]
There are a lot of SPL options in U-Boot to enable various features and
drivers. Currently these do not use Kconfig. Add them to Kconfig along
with suitable help, and drop them from the README.
This reverts commit 6279b49e6c2fdaf8665355d1777bc90cd41fcf90.
This caused a bad data crc.
Reported-by: Guillaume GARDET <guillaume.gardet@free.fr>
This reverts commit 998372b4798fd7ebb666f571950df925b8d80f69.
This caused a data abort on some platform.
We use an empty hostname, so remove all the "processing" of the
known-to-be-empty hostname and just write 0's where needed.
Instead of always allocating a huge temporary buffer on the stack and
then memcpy()ing the result into the transmit buffer, simply figure out
where in the transmit buffer the bytes will belong and write them there
directly as each message is built.
Much of the information is verbose and derived directly from the
environment. Only output in debug mode. This also saves about 300 bytes
from the code size.
Use the same name throughout the nfs code and use the same member of the
union to avoid casts.
The buffer is of 32-bit elements, not bytes.
Instead of repeating the same large snippet for dealing with attributes
it should be shared with a helper function.
Fix complaints from checkpatch.pl.
The type of the buffer is uint32_t, but the parameter used to size it
is referring to bytes. Divide by the size of the array elements.
Strictly speaking, this shouldn't be needed at all... It could just be 1
just like the request.
The v3 handles can be larger than v2, but that doesn't mean we need a
separate buffer. Reuse the same (larger) buffer for both.
This patch enables NFSv3 support.
If NFSv2 is available use it as usual.
If NFSv2 is not available, but NFSv3 is available, use NFSv3.
If NFSv2 and NFSv3 are not available, print an error message since NFSv4 is not supported.
Tested on iMX6 sabrelite with 4 Linux NFS servers:
* NFSv2 + NFSv3 + NFSv4 server: use NFSv2 protocol
* NFSv2 + NFSv3 server: use NFSv2 protocol
* NFSv3 + NFSv4 server: use NFSv3 protocol
* NFSv3 server: use NFSv3 protocol
Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr>
Cc: joe.hershberger@ni.com
Unreferenced, so remove the noise.
There is no reason to store the default filename in a separate buffer
only to immediately copy it to the main name buffer. Just write it there
directly and remove the other buffer.
At least on bfin, this "specimen" is actually allocated in the BSS and
wastes lots of memory in already tight memory conditions.
Also, with the introduction of NFSv3 support, this waste got
substantially larger.
Just remove it. If a board needs a specific different defragment size,
that board can override this setting.
Fix a number of typos, including:
* "compatble" -> "compatible"
* "eanbeld" -> "enabled"
* "envrionment" -> "environment"
* "FTD" -> "FDT" (for "flattened device tree")
* "ommitted" -> "omitted"
* "overriden" -> "overridden"
* "partiton" -> "partition"
* "propogate" -> "propagate"
* "resourse" -> "resource"
* "rest in piece" -> "rest in peace"
* "suport" -> "support"
* "varible" -> "variable"
This patch fixes incorrect RPC packet layout caused by
'long' type size difference on 64 and 32-bit architectures.
Signed-off-by: Ralf Hubert <r.hubert@technisat.de>
server
Avoid generating this section if there is nothing in it.
Signed-off-by: Andre Renaud <andre@designa-electronics.com>
The client architecture that we pass to a dhcp server depends on the target
payload that we want to execute. An EFI binary has a different client arch
than a legacy binary or a u-boot binary.
So let's parameterize the pxe client arch field to allow an override via
the distro script, so that our efi boot path can tell the dhcp server that
it's actually an efi firmware.
Now that we can expose network functionality to EFI applications,
the logical next step is to load them via pxe to execute them as
well.
This patch adds the necessary bits to the distro script to automatically
load and execute EFI payloads. It identifies the dhcp client as a uEFI
capable PXE client, hoping the server returns a tftp path to a workable
EFI binary that we can then execute.
To enable boards that don't come with a working device tree preloaded,
this patch also adds support to load a device tree from the /dtb directory
on the remote tftp server.
This patch also adds the SPL time VCI string into Kconfig.
There are client identifiers specifically reserved for ARM U-Boot
according to http://www.ietf.org/assignments/dhcpv6-parameters/dhcpv6-parameters.xml#processor-architecture.
So let's actually make use of them rather than the bogus 0x100 that
we emitted so far.
[trini: Drop the Xilinx define to 0x100 as it's not the correct value to
use].
We have a bunch of boards that define their vendor class identifier and
client archs in the board files or in the distro config. Move everything
to the generic Kconfig options.
We're missing the distinction between i386 and x86_64, as I couldn't find
any config variable that would tell us the difference. Is that really important
to people? I guess not, so I left it out.
Both the dhcp as well as the bootp case add vendor class identifier
parameters into their packets. Let's move that into a separate function
to make overlaying easier.
We can now successfully boot EFI applications from disk, but users
may want to also run them from a PXE setup.
This patch implements rudimentary network support, allowing a payload
to send and receive network packets.
With this patch, I was able to successfully run grub2 with network
access inside of QEMU's -M xlnx-ep108.
In rare circumstances two dhcp clients may generate the same
bootp ID. If this happens it is vital that the client also checks
the hw address in the received response to prevent IP address conflicts.
Signed-off-by: Anton Persson <don.juanton@gmail.com>
There is currently one config option (CONFIG_NET_RETRY_COUNT) that
is available to tune the retries of the network stack.
Unfortunately, it is global to all protocols, and the value is
interpreted differently in all of them.
Add a new environment variable that directly sets the retry period for
BOOTP timeouts. If this new value is not set, the period is still derived
from the default number of retries, or from CONFIG_NET_RETRY_COUNT if
defined. When both the new variable is set and CONFIG_NET_RETRY_COUNT
is defined, the variable has precedence.
Signed-off-by: Alexandre Messier <amessier@tycoint.com>
This fixes the following error when building microblaze-generic:
net/eth-uclass.c: In function 'eth_post_probe':
net/eth-uclass.c:466:18: error: 'gd' undeclared (first use in this function)
ops->start += gd->reloc_off;
Fixes: db9391e1 ("net: Move driver-model code into its own file")
Add the bootfile name in the DHCP Request packet, in addition
to it already being sent in the DHCP Discover.
This is needed by some DHCP servers so that the bootfile name is
properly returned by the server to the client in the DHCP Ack, as
expected by U-Boot.
Rename this file to make it clear it is for the old networking drivers
and not for use with driver model.
Every other uclass is in its own file. Create a new eth-uclass.c file and
move the driver-model code into it, so that networking is consistent.
Move eth_current_changed(), eth_set_current(), eth_mac_skip() and
eth_get_name() into the common file.
Move the functions which set ethernet environment variables to the common
file.
Only half of the init is actually common. Move that part into a new common
file and call it from driver-model and legacy code. More common functions
will be added in future patches.
We should avoid weak functions with driver model. Existing boards that use
driver model don't need them, so let's kill them off.
When doing `dhcp`, there is a bad dhcp server in my network
which always reply dhcp request with yiaddr 0, which cause
uboot can not successfully get ipaddr from the good dhcp server.
But the Linux PC can get the ip address even if there is a bad
dhcp server. This patch is to fix that even if there is a bad
dhcp server, uboot can still get ipaddr and tftp work ok.
The way is to ignore the packets from the bad dhcp server by filtering
out the yiaddr whose value is 0.
Reviewed-by: Wolfgang Denk <wd@denx.de>
In many parts of the computing world having a unique MAC address
sitting in some on-NIC storage is considered the normal case.
Remove the warning to not scare the user unnecessarily.
This applies to Highbank/Midway and ARM's Juno, for instance.
Besides that this fixes the formatting on Midway, for instance,
which currently looks like:
Net: xgmac0
Warning: xgmac0 using MAC address from net device
, xgmac1
Warning: xgmac1 using MAC address from net device
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Introduced in 45b4773 (net/arp: account for ARP delay, avoid duplicate packets on timeout)
Check the arp timeout and adjust the timeout start time before the call
to eth_recv() so that the sandbox driver has the opportunity to adjust
the sandbox timer after the new start time has been recorded.
Also, change the adjustment amount by 11 seconds instead of exactly the
10 seconds that the ping timout is expecting since the timeout check is
looking for the time elapsed to be greater than but not equal to the
specified delay.
Reviewed-by: Stefan Brüns <stefan.bruens@rwth-aachen.de>
When 'ethrotate' variable is set to 'no' and 'ethact' variable
is already set to an ethernet device, we should stick to 'ethact'.
