path: root/net
2019-06-14net: Convert CONFIG_TFTP_BLOCKSIZE to KconfigMarek Vasut
Convert CONFIG_TFTP_BLOCKSIZE to Kconfig, update defconfigs, headers and whitelist. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Christian Gmeiner <christian.gmeiner@gmail.com> Cc: Joe Hershberger <joe.hershberger@ni.com>
2019-06-14net: Convert CONFIG_IP_DEFRAG to KconfigMarek Vasut
Convert CONFIG_IP_DEFRAG to Kconfig, update defconfigs, headers and whitelist. This patch is a follow-up on a patch by Christian Gmeiner with the added config/header/whitelist updates. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Reported-by: Christian Gmeiner <christian.gmeiner@gmail.com> Cc: Joe Hershberger <joe.hershberger@ni.com>
2019-06-01net: eth-uclass: Support device tree MAC addressesThierry Reding
Add the standard Ethernet device tree bindings (imported from v5.0 of the Linux kernel) and implement support for reading the MAC address for Ethernet devices in the Ethernet uclass. If the "mac-address" property exists, the MAC address will be parsed from that. If that property does not exist, the "local-mac-address" property will be tried as fallback. MAC addresses from device tree take precedence over the ones stored in a network interface card's ROM. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Grygorii Strashko <grygorii.strashko@ti.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2019-06-01net: eth-uclass: Write MAC address to hardware after probeThierry Reding
In order for the device to use the proper MAC address, which can have been configured in the environment prior to the device being registered, ensure that the MAC address is written after the device has been probed. For devices that are registered before the network stack is initialized, this is already done during eth_initialize(). If the Ethernet device is on a bus that is not initialized on early boot, such as PCI, the device is not available at the time eth_initialize() is called, so we need the MAC address programming to also happen after probe. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2019-02-02lmb: handle more than one DRAM BANKSimon Goldschmidt
This fixes the automatic lmb initialization and reservation for boards with more than one DRAM bank. This fixes the CVE-2018-18439 and -18440 fixes that only allowed to load files into the firs DRAM bank from fs and via tftp. Found-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Tested-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-01-26lib: lmb: rename lmb_get_unreserved_size to lmb_get_free_sizeSimon Goldschmidt
As a follow-up, change the name of the newly introduced function 'lmb_get_unreserved_size' to 'lmb_get_free_size', which is more appropriate. Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> [trini: Fix test/lib/lmb.c] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-01-24net: remove CONFIG_MCAST_TFTPChris Packham
No mainline board enables CONFIG_MCAST_TFTP and there have been compilation issues with the code for some time. Additionally, it has a potential buffer underrun issue (reported as a side note in CVE-2018-18439). Remove the multicast TFTP code but keep the driver API for the future addition of IPv6. Cc: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Signed-off-by: Chris Packham <judge.packham@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2019-01-24net: move ether_crc to tsec driverChris Packham
ether_crc was added to the core net code in commit 53a5c424bf86 ("multicast tftp: RFC2090") so that other drivers could use it. However the only current user of it is tsec.c so move it there. Signed-off-by: Chris Packham <judge.packham@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2019-01-24net: explicitly assign errno to return code in case of network failureThomas RIENOESSL
When dealing with two ethernet ports and having "netretry" set to "once", it could occur that the connection (e.g. an ARP request) failed, hence the status of the netloop was "NETLOOP_FAIL". Due to the setting of "netretry", the network logic would then switch to the other network interface, assigning "ret" with the return value of "net_start_again()". If this call succeeded we would return 0 (i.e. success) to the caller when in reality the network action failed. Signed-off-by: Thomas RIENOESSL <thomas.rienoessl@bachmann.info> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2019-01-16tftp: prevent overwriting reserved memorySimon Goldschmidt
This fixes CVE-2018-18439 ("insufficient boundary checks in network image boot") by using lmb to check for a valid range to store received blocks. Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> [trini: Always build lib/lmb.o on LMB and lib/fdtdec.o on OF_LIBFDT] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-10-10net: Consolidate UDP header functionsDuncan Hare
Make it possible to add TCP versions of the same, while reusing IP portions. This patch should not change any behavior. Signed-off-by: Duncan Hare <DH@Synoia.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-10-10net: Don't overwrite waiting packets with asynchronous repliesJoe Hershberger
Peter originally sent a fix, but it breaks a number of other things. This addresses the original reported issue in a different way. That report was: > U-Boot has 1 common buffer to send Ethernet frames, pointed to by > net_tx_packet. When sending to an IP address without knowing the MAC > address, U-Boot makes an ARP request (using the arp_tx_packet buffer) > to find out the MAC address of the IP addressr. When a matching ARP > reply is received, U-Boot continues sending the frame stored in the > net_tx_packet buffer. > > However, in the mean time, if U-Boot needs to send out any network > packets (e.g. replying ping packets or ARP requests for its own IP > address etc.), it will use the net_tx_packet buffer to prepare the > new packet. Thus this buffer is no longer the original packet meant > to be transmitted after the ARP reply. The original packet will be > lost. This instead uses the ARP tx buffer to send async replies in the case where we are actively waiting for an ARP reply. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reported-by: Tran Tien Dat <peter.trantiendat@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2018-10-10net: Add an accessor to know if waiting for ARPJoe Hershberger
This single-sources the state of the ARP. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2018-08-21net: eth-uclass: Fix for DM USB ethernet supportJean-Jacques Hiblot
When a USB ethernet device is halted, the device driver is removed. When this happens the uclass private memory is freed and uclass_priv is set to NULL. This causes a data abort when uclass_priv->state is then set to ETH_STATE_PASSIVE. Fix it by checking if uclass_priv is NULL before setting uclass_priv->state Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-07-26net: Consolidate the parsing of bootfileJoe Hershberger
The same basic parsing was implemented in tftp and nfs, so add a helper function to do the work once. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2018-07-26net: Read bootfile from env on netboot_common()Joe Hershberger
Instead of depending on a env callback for bootfile, read it explicitly. We do this because the bootfile can be specified on the command line and if it is, we will overwrite the internal variable. If a netboot_common() is called again with no bootfile parameter, we want to use the one in the environment. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2018-07-26net: Make copy_filename() accept NULL srcJoe Hershberger
Rather than crashing, check the src ptr and set dst to empty string. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2018-07-26net: Re-check prerequisites when autoloadingJoe Hershberger
With net autoload, we check the prerequisites for the initial command, but the greater prerequisites when autoloading are not checked. If we would attempt to autoload, check those prerequisites too. If we are not expecting a serverip from the server, then don't worry about it not being set, but don't attempt to load if it isn't. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2018-07-26net: When checking prerequisites, consider boot_file_nameJoe Hershberger
For net_boot_common, we allow the serverip to be specified as part of the boot file name. For net commands that require serverip, include that source as a valid specification of serverip. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Alexander Graf <agraf@suse.de>
2018-07-26net: Always print basic info for nfs, just like tftpJoe Hershberger
nfs was only printing basic info about the transfer in the case of a DEBUG build. Print the same level of detail as tftp always. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2018-07-26net: Check subnet against the actual ip address in use for nfsJoe Hershberger
The check for sending to the gateway was not using the correct variable for comparison, so it was reporting that packets are sent to the gateway when they were not. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2018-07-26net: Correct size of NFS buffersJoe Hershberger
Reported-by: Coverity (CID: 152888) Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2018-07-26net: Only call halt on a driver that has been init'edJoe Hershberger
With driver model, we were not checking if the state of the device was marked as active before calling the halt function. Check that the device is probed and also marked as active. This avoids the case where we were calling halt on the first device in net_init() and the driver would operate on bogus data structures causing problems. In this case, the priv was all 0, so halt() would close STDIN. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-07-02net: Add option to prefer bootp/dhcp serveripAlexander Graf
Currently we can choose between 2 different types of behavior for the serverip variable: 1) Always overwrite it with the DHCP server IP address (default) 2) Ignore what the DHCP server says (CONFIG_BOOTP_SERVERIP) This patch adds a 3rd option: 3) Use serverip from DHCP if no serverip is given (CONFIG_BOOTP_PREFER_SERVERIP) With this new option, we can have the default case that a boot file gets loaded from the DHCP provided TFTP server work while allowing users to specify their own serverip variable to explicitly use a different tftp server. Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-07-02net: Prefer command line argumentsAlexander Graf
We can call commands like dhcp and bootp without arguments or with explicit command line arguments that really should tell the code where to look for files instead. Unfortunately, the current code simply overwrites command line arguments in the dhcp case with dhcp values. This patch allows the code to preserve the command line values if they were set on the command line. That way the semantics are slightly more intuitive. The reason this patch does that by introducing a new variable is that we can not rely on net_boot_file_name[0] being unset, as today it's completely legal to call "dhcp" and afterwards run "tftp" and expect the latter to repeat the same query as before. I would prefer not to break that behavior in case anyone relies on it. Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-07-02net: Add new wol command - Wake on LANLothar Felten
Add a new command 'wol': Wait for an incoming Wake-on-LAN packet or time out if no WoL packed is received. If the WoL packet contains a password, it is saved in the environment variable 'wolpassword' using the etherwake format (dot or colon separated decimals). Intended use case: a networked device should boot an alternate image. It's attached to a network on a client site, modifying the DHCP server configuration or setup of a tftp server is not allowed. After power on the device waits a few seconds for a WoL packet. If a packet is received, the device boots the alternate image. Otherwise it boots the default image. This method is a simple way to interact with a system via network even if only the MAC address is known. Tools to send WoL packets are available on all common platforms. Some Ethernet drivers seem to pad the incoming packet. The additional padding bytes might be recognized as Wake-on-LAN password bytes. By default enabled in pengwyn_defconfig. Signed-off-by: Lothar Felten <lothar.felten@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-07-02net: fastboot: Fix build when FASTBOOT_FLASH is disabledAlex Kiernan
When building without FASTBOOT_FLASH we don't include the intermediate update callback to keep the client alive, so ensure we don't try setting it here. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-06-13net: nfs: don't fail when nfs_read_reply returns -NFS_RPC_DROPVasily Khoruzhick
That can happen if duplicate UDP packet arrived, and that's not uncommon. Anyway, we ignore packets with rpc_id lower than last we sent for other requests, so it makes sense to do that for read request as well. Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-06-13net: Protect net_state from reentrant net_loop()Leonid Iziumtsev
Global variable "net_state" is used in net_loop() state-machine. But it happens that some times the net_loop() can be called multiple times in the same call stack. For example when the netconsole is enabled and we print the message while some other net protocol is in action. Netconsole will overwrite the "net_state" and that will break the logic for earlier started protocol. To protect the state save and restore "net_state" variable each time when we enter and exit net_loop(). Signed-off-by: Leonid Iziumtsev <leonid.iziumtsev@se.atlascopco.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-06-13net: Initialize as many ethernet devices as possibleMario Six
On devices that have their first network interface provided by a FPGA, the initialization of further interfaces will fail if the FPGA is not yet programmed. This leads to problems during factory setup when the data is supposed to be loaded over secondary netowork interfaces. To avoid this, use the uclass_{first,next}_device_check functions to initialize as many ethernet devices as possible. Signed-off-by: Mario Six <mario.six@gdsys.cc> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-06-13net: Always align tx packetsMario Six
Make sure that TX packets are always cache-aligned. Signed-off-by: Mario Six <mario.six@gdsys.cc> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-05-30net: fastboot: Merge AOSP UDP fastbootAlex Kiernan
Merge UDP fastboot support from AOSP: https://android.googlesource.com/platform/external/u-boot/+/android-o-mr1-iot-preview-8 Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Signed-off-by: Alex Deymo <deymo@google.com> Signed-off-by: Jocelyn Bohr <bohr@google.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-05-14net: bootp: Fix compile error processing ntpserver optionChris Packham
When the following configuration is set # CONFIG_CMD_DHCP is not set CONFIG_CMD_BOOTP=y CONFIG_BOOTP_NTPSERVER=y The following compile error is observed error: used struct type value where scalar is required if (net_ntp_server) ^~~~~~~~~~~~~~ Resolve this by checking net_ntp_server.s_addr instead. Signed-off-by: Chris Packham <judge.packham@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-05-10SPDX: Convert a few files that were missed beforeTom Rini
As part of the main conversion a few files were missed. These files had additional whitespace after the '*' and before the SPDX tag and my previous regex was too strict. This time I did a grep for all SPDX tags and then filtered out anything that matched the correct styles. Fixes: 83d290c56fab ("SPDX: Convert all of our single license tags to Linux Kernel style") Reported-by: Heinrich Schuchardt <xypron.debian@gmx.de> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-13net: Make core net code depend on NET instead of CMD_NETJoe Hershberger
No commands are necessary to have a network stack. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Duncan Hare <dh@synoia.com>
2018-04-13net: Move net command options to the cmd menuJoe Hershberger
Options that controlled the tftp and bootp commands depended on their commands, but lived in the net menu. Move them so they are in a consistent location. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Chris Packham <judge.packham@gmail.com>
2018-04-13net: Make CMD_NET a menuconfigJoe Hershberger
Previously, CMD_NET was an alias for 2 commands (bootp and tftpboot) and they we not able to be disabled. Separate out those 2 commands and move CMD_NET up to the menu level, which more accurately represents the code. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Duncan Hare <dh@synoia.com>
2018-04-08net: Move enetaddr env access code to env config instead of net configAlex Kiernan
In order that we can use eth_env_* even when CONFIG_NET isn't set, move these functions to environment code from net code. This fixes failures such as: board/ti/am335x/built-in.o: In function `board_late_init': board/ti/am335x/board.c:752: undefined reference to `eth_env_set_enetaddr' u-boot/board/ti/am335x/board.c:766: undefined reference to `eth_env_set_enetaddr' which caters for use cases such as: commit f411b5cca48f ("board: am335x: Always set eth/eth1addr environment variable") when Ethernet is required in Linux, but not U-Boot. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-03-22net: Only access network devices after initAlexander Graf
In the efi_loader main loop we call eth_rx() occasionally. This rx function might end up calling into devices that haven't been initialized yet, potentially resulting in a lot of transfer timeouts. Instead, let's make sure the ethernet device is actually initialized before reading from or writing to it. Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-03-22net: Fix netretry conditionLeonid Iziumtsev
The "net_try_count" counter starts from "1". And the "retrycnt" contains requested amount of retries. With current logic, that means that the actual retry amount will be one time less then what we set in "netretry" env. For example setting "netretry" to "once" will make "retrycnt" equal "1", so no retries will be triggered at all. Fix the logic by changing the statement of "if" condition. Signed-off-by: Leonid Iziumtsev <leonid.iziumtsev@se.atlascopco.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-02-27Kconfig: cmd: Make networking command dependent on NETMichal Simek
Enable networking command only when NET is enabled. And remove selecting NET for CMD_NET Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-08Convert CONFIG LIB_HW_RAND to KconfigAdam Ford
config_fallbacks.h had some logic to automatically select LIB_RAND if RANDOM_UUID or CMD_UUID were set if LIB_HW_RAND wasn't already selected. By migrating LIB_HW_RAND to Kconfig, we can remove this check from config_fallbacks.h and put it into Kconfig Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> [trini: Turn into a choice, add NET_RANDOM_ETHADDR] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-15net: dhcp: Allow "MAY_FAIL" to still try each adapterJoe Hershberger
This change allows the "MAY_FAIL" DHCP option to still attempt to contact a DHCP server on each adapter and only give up once each adapter has failed once. To get the existing behavior, set the already-existing ethrotate=no variable. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Keng Soon Cheah <keng.soon.cheah@ni.com> Cc: Chen Yee Chew <chen.yee.chew@ni.com>
2018-01-15net: Remove nfs.h include from bootp.cJoe Hershberger
Nothing from this header is used there, so remove it. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2017-09-22net/tftp: fix build if CMD_BOOTEFI is not setJörg Krause
Fixes: net/tftp.c:811: undefined reference to `efi_set_bootdev' Signed-off-by: Jörg Krause <joerg.krause@embedded.rocks> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-09-07net: nfs: Drop CONFIG_NFS_READ_SIZETom Rini
In the general case, CONFIG_NFS_READ_SIZE is unchanged from the default of 1024. There are in fact no in-tree users that increase this size. Adjust the comment to reflect what could be done in the future in conjunction with CONFIG_IP_DEFRAG. Cc: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-08-16env: Rename some other getenv()-related functionsSimon Glass
We are now using an env_ prefix for environment functions. Rename these other functions as well, for consistency: getenv_vlan() getenv_bootm_size() getenv_bootm_low() getenv_bootm_mapsize() env_get_default() Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
