path: root/net
2004-10-11* Patch by Philippe Robin, 28 Sept 2004:wdenk
Fix Flash support for Versatile. * Patch by Roger Blofeld, 16 Sep 2004: Fix timeout for DHCP command retry
2004-10-09Patch by Andreas Engel, 16 Aug 2004:wdenk
parameter type cleanup for NetSetTimeout()
2004-09-28* Patch by Ganapathi C, 04 Aug 2004:wdenk
Fix NFS timeout issue
2004-08-02Add support for console over UDP (compatible to Ingo Molnar'swdenk
netconsole patch under Linux)
2004-07-09Patch by Jon Loeliger, 17 June 2004:wdenk
Completion of the 8540ADS/8560ADS updates: Fix some PCI and Rapid I/O memory maps, Initialize both TSEC 1 and 2, Initialize SDRAM Update MAINTAINER for 85xx boards and README.mpc85xxads
2004-06-30* Fix "cls" command when used with splash screenLABEL_2004_07_01_1200wdenk
* Increase NFS download timeout (now 1 min - 10 sec is to short for a slow download of a big image)
2004-05-08Change init sequence for multiple network interfaces: initializewdenk
on-chip interfaces before external cards.
2004-04-25* Patch by John Kerl, 19 Apr 2004:wdenk
Use U-boot's miiphy.h for PHY register names, rather than introducing a new header file. * Update pci_ids.h from linux-2.4.26 * Patch by Masami Komiya, 19 Apr 2004: Fix problem cause by VLAN function on little endian architecture without VLAN environment
2004-04-18* Patch by Sangmoon Kim, 12 Apr 2004:wdenk
Update max RAM size for debris board * Patch by Travis Sawyer, 08 Apr 2004: Add TLB entry for second DIMM slot on ocotea * Patch by Masami Komiya, 08 Apr 2004: add RTL8169 network driver
2004-04-18* Cleanup, minor fixeswdenk
* Patch by Rune Torgersen, 16 Apr 2004: LBA48 fixes * Patches by Pantelis Antoniou, 16 Apr 2004: - Fix some compile problems; add "once" functionality for the netretry variable
2004-04-15Patches by Pantelis Antoniou, 30 Mar 2004:wdenk
add networking support for VLANs (802.1q), and CDP (Cisco Discovery Protocol)
2004-03-23* Patches by Thomas Viehweger, 16 Mar 2004:wdenk
- show PCI clock frequency on MPC8260 systems - add FCC_PSMR_RMII flag for HiP7 processors - in do_jffs2_fsload(), take load address from load_addr if not set explicit, update load_addr otherwise - replaced printf by putc/puts when no formatting is needed (smaller code size, faster execution)
2004-03-14* Patch by Philippe Robin, 09 Mar 2004:wdenk
Added ARM Integrator AP, CP and Versatile PB926EJ-S Reference Platform support. * Patch by Masami Komiya, 08 Mar 2004: Don't overwrite server IP address or boot file name when the boot server does not return values * Patch by listmember@orkun.us, 5 Mar 2004: Removed compile time restriction on CFG_I2C_SPEED for DS1338 RTC
2004-03-14* Patch by Yuli Barcohen, 4 Mar 2004:wdenk
Fix problems with GCC 3.3.x which changed handling of global variables explicitly initialized to zero (now in .bss instead of .data as before). * Patch by Leon Kukovec, 02 Mar 2004: add strswab() to fix IDE LBA capacity, firmware and model numbers on little endian machines * Patch by Masami Komiya, 02 Mar 2004: - Remove get_ticks() from NFS code - Add verification of RPC transaction ID * Patch by Pierre Aubert, 02 Mar 2004: cleanup for IDE and USB drivers for MPC5200
2004-03-14* Patch by Travis Sawyer, 01 Mar 2004:wdenk
Ocotea: - Add IBM PPC440GX Ref Platform support (Ocotea) Original code by Paul Reynolds <PaulReynolds@lhsolutions.com> Adapted to U-Boot and 440GX port 440gx_enet.c: - Add gracious handling of all Ethernet Pin Selections for 440GX - Add RGMII selection for Cicada CIS8201 Gigabit PHY ppc440.h: - Add needed bit definitions - Fix formatting * Patch by Carl Riechers, 1 Mar 2004: Add PPC440GX prbdv0 divider to fix memory clock calculation. * Patch by Stephan Linz, 27 Feb 2004 - avoid problems for targets without NFS download support
2004-03-13* Patch by Rune Torgersen, 27 Feb 2004:wdenk
- Added LBA48 support (CONFIG_LBA48 & CFG_64BIT_LBA) - Added support for 64bit printing in vsprintf (CFG_64BIT_VSPRINTF) - Added support for 64bit strtoul (CFG_64BIT_STRTOUL) * Patch by Masami Komiya, 27 Feb 2004: Fix rarpboot: add autoload by NFS * Patch by Dan Eisenhut, 26 Feb 2004: fix flash_write return value in saveenv * Patch by Stephan Linz, 11 Dec 2003 expand config.mk to avoid trigraph warnings on NIOS * Rename "BMS2003" board into "HMI10"
2004-03-12Add support for Siemens SX1 mobile phone;LABEL_2004_03_12_0130wdenk
add support for USB-based console (enable with "setenv stdout usbtty; setenv stdin usbtty")
2004-02-27* Patch by Pierre Aubert, 26 Feb 2004wdenk
add IDE support for MPC5200 * Patch by Masami Komiya, 26 Feb 2004: add autoload via NFS * Patch by Stephen Williams Use of CONFIG_SERIAL_SOFTWARE_FIFO in board.c consistent with uses elsewhere in the source.
2004-02-27* Patch by Steven Scholz, 25 Feb 2004:wdenk
- Timeouts in FPGA code should be based on CFG_HZ - Minor cleanup in code for Altera FPGA ACEX1K * Patch by Steven Scholz, 25 Feb 2004: Changed "Directory Hierarchy" section in README * Patch by Masami Komiya, 25 Feb 2004: Reduce copy count in nfs_read_reply() of NFS code
2004-02-24* Patch by Masami Komiya, 24 Feb 2004:wdenk
Update NetBootFileXferSize in NFS code * Patch by Scott McNutt, 24 Feb 2004: fix packet length in NFS code
2004-02-24* Patch by Masami Komiy, 22 Feb 2004:wdenk
Add support for NFS for file download * Minor code cleanup
2004-02-23* Patch by Laurent Mohin, 10 Feb 2004:wdenk
Fix buffer overflow in common/usb.c * Patch by Tolunay Orkun, 10 Feb 2004: Add support for Cogent CSB272 board * Code cleanup
2004-02-23* CVS add missing fileswdenk
* Cleanup compiler warnings * Fix problem with side effects in macros in include/usb.h * Patch by David Benson, 13 Nov 2003: bug 841358 - fix TFTP download size limit * Fixing bug 850768: improper flush_cache() in load_serial() * Fixing bug 834943: MPC8540 - missing volatile declarations * Patch by Stephen Williams, 09 Feb 2004: Add support for Xilinx SystemACE chip: - New files common/cmd_ace.c and include/systemace.h - Hook systemace support into cmd_fat and the partition manager * Patch by Travis Sawyer, 09 Feb 2004: Add bi_opbfreq & bi_iic_fast to 440GX bd_info as needed for Linux
2004-02-06Patch by Travis Sawyer, 30 Dec 2003:wdenk
Add support for IBM PPC440GX. Multiple EMAC Ethernet devices, select MDI port based on enabled EMAC device. Add support for XES Inc <http://www.xes-inc.com> XPedite1000 440GX base PrPMC board.
2004-01-03* Patch by Ronen Shitrit, 10 Dec 2003:wdenk
Add support for the Marvell DB64360 / DB64460 development boards * Patch by Detlev Zundel, 10 Dec 2003: fix dependency problem in examples/Makefile
2004-01-02* Patch by André Schwarz, 8 Dec 2003:wdenk
fixes for Davicom DM9102A Ethernet Chip (#define CONFIG_TULIP_FIX_DAVICOM): - TX and RX deskriptors must be quad-word aligned - does not work with only one TX deskriptor - standard reset method does not work * Patch by Masami Komiya, 08 Dec 2003: add RTL8139 ethernet driver * Patches by Ed Okerson, 07 Dec 2003: - fix ethernet for the AU1x00 processors in little-endian mode. - extend memsetup.S for the AU1x00 processors in BE and LE modes
2004-01-02* Cleanup lowboot code for MPC5200wdenk
* Minor code cleanup (coding style) * Patch by Reinhard Meyer, 30 Dec 2003: - cpu/mpc5xxx/fec.c: added CONFIG_PHY_ADDR, added CONFIG_PHY_TYPE, - added CONFIG_PHY_ADDR to include/configs/IceCube.h, - turned debug print of PHY registers into a function (called in two places) - added support for EMK MPC5200 based modules * Fix MPC8xx PLPRCR_MFD_SHIFT typo * Add support for TQM866M modules * Fixes for TQM855M with 4 MB flash (Am29DL163 = _no_ mirror bit flash) * Fix a few compiler warnings
2003-11-17* Use "-fPIC" instead of "-mrelocatable" to prevent problems withwdenk
recent tools * Add checksum verification to 'imls' command * Add bd_info fields needed for 4xx Linux I2C driver * Patch by Martin Krause, 4 Nov. 2003: Fix error in cmd_vfd.c (TRAB board: "vfd /1" shows now only one Bitmap) * Print used network interface when CONFIG_NET_MULTI is set
2003-10-09* Patch by Steven Scholz, 10 Oct 2003LABEL_2003_10_09_2320wdenk
- Add support for Altera FPGA ACEX1K * Patches by Thomas Lange, 09 Oct 2003: - Endian swap ATA identity for all big endian CPUs, not just PPC - MIPS only: New option CONFIG_MEMSIZE_IN_BYTES for passing memsize args to linux - add support for dbau1x00 board (MIPS32)
2003-10-08* Patch by Sangmoon Kim, 23 Sep 2003:wdenk
fix pll_pci_to_mem_multiplier table for MPC8245 * Patch by Anders Larsen, 22 Sep 2003: enable timed autoboot on PXA * Patch by David Müller, 22 Sep 2003: - add $(CFLAGS) to "-print-libgcc-filename" so compiler driver returns correct libgcc file path - "latency" reduction of busy-loop waiting to improve "U-Boot" boot time on s3c24x0 systems * Patch by Jon Diekema, 19 Sep 2003: - Add CFG_FAULT_ECHO_LINK_DOWN option to echo the inverted Ethernet link state to the fault LED. - In NetLoop, make the Fault LED reflect the link status. The link status gets updated on entry, and on timeouts.
2003-10-06* Update TRAB auto update codeLABEL_2003_10_06_2355wdenk
* Make fatload set filesize environment variable fix potential buffer overlow problem * enable basic / medium / high-end configurations for PPChameleonEVB board; fix NAND code * enable TFTP client code to specify to the server the desired timeout value (see RFC-2349)
2003-09-05* Add support for SK98xx driverLABEL_2003_09_06_0055wdenk
* Add PCI support for SL8245 board * Support IceCube board configurations with 1 x AMD AM29LV065 (8 MB) or 1 x AM29LV652 (two LV065 in one chip = 16 MB); Run IPB at 133 Mhz; adjust the MII clock frequency accordingly * Set BRG_CLK on PM825/826 to 64MHz (VCO_OUT / 4, instead of 16 MHz) to allow for more accurate baudrate settings (error now 0.7% at 115 kbps, instead of 3.5% before) * Patch by Andreas Mohr, 4 Sep 2003: Fix a lot of spelling errors
2003-08-28- Added CONFIG_BOOTP_DNS2 and CONFIG_BOOTP_SEND_HOSTNAME to CONFIG_BOOTP_MASK.stroese
2003-08-17* Make Ethernet autonegotiation on INCA-IP work for all clock rates;U-Boot-0_4_6wdenk
allow selection of clock frequency as "make" target * Implement memory autosizing code for IceCube boards * Configure network port on INCA-IP for autonegotiation * Fix overflow problem in network timeout code * Patch by Richard Woodruff, 8 Aug 2003: Allow crc32 to be used at address 0x000 (crc32_no_comp, too).
2003-07-16* Add support for IceCube board (with MGT5100 and MPC5200 CPUs)U-Boot-0_4_4wdenk
2003-06-19* Patch by Richard Woodruff, 19 June 03:wdenk
- Fixed smc91c111 driver to sync with the u-boot environment (driver/smc91c111.c). - Added eth_init error return check in NetLoop (net/net.c).
2003-06-15* Fix CONFIG_NET_MULTI support in include/net.hLABEL_2003_06_16_0055wdenk
* Patches by Kyle Harris, 13 Mar 2003: - Add FAT partition support - Add command support for FAT - Add command support for MMC ---- - Add Intel PXA support for video - Add Intel PXA support for MMC ---- - Enable MMC and FAT for lubbock board - Other misc changes for lubbock board
2003-06-06- Fix compile bug (PPC4xx).stroese
2003-06-05* Patch by Vladimir Gurevich, 04 Jun 2003:LABEL_2003_06_05_2140wdenk
make ppc405 ethernet driver compatible with CONFIG_NET_MULTI option
2003-06-05* Add support for RMU boardwdenk
* Add support for TQM862L at 100/50 MHz * Patch by Pantelis Antoniou, 02 Jun 2003: major reconstruction of networking code; add "ping" support (outgoing only!)
2003-06-03* Patches by Udi Finkelstein, 2 June 2003:LABEL_2003_06_04_0200wdenk
- Added support for custom keyboards, initialized by defining a board-specific drv_keyboard_init as well as defining CONFIG_KEYBOARD . - Added support for the RBC823 board. - cpu/mpc8xx/lcd.c now automatically calculates the Horizontal Pixel Count field. * Fix alignment problem in BOOTP (dhcp_leasetime option) [pointed out by Nicolas Lacressonnière, 2 Jun 2003] * Patch by Mark Rakes, 14 May 2003: add support for Intel e1000 gig cards. * Patch by Nye Liu, 3 Jun 2003: fix critical typo in MAMR definition (include/mpc8xx.h) * Fix requirement to align U-Boot image on 16 kB boundaries on PPC. * Patch by Klaus Heydeck, 2 Jun 2003 Minor changes for KUP4K configuration
2003-05-31* Patch by Marc Singer, 29 May 2003:LABEL_2003_05_31_2115wdenk
Fixed rarp boot method for IA32 and other little-endian CPUs. * Patch by Marc Singer, 28 May 2003: Added port I/O commands. * Patch by Matthew McClintock, 28 May 2003 - cpu/mpc824x/start.S: fix relocation code when booting from RAM - minor patches for utx8245 * Patch by Daniel Engström, 28 May 2003: x86 update * Patch by Dave Ellis, 9 May 2003 + 27 May 2003: add nand flash support to SXNI855T configuration fix/extend nand flash support: - fix 'nand erase' command so does not erase bad blocks - fix 'nand write' command so does not write to bad blocks - fix nand_probe() so handles no flash detected properly - add doc/README.nand - add .jffs2 and .oob options to nand read/write - add 'nand bad' command to list bad blocks - add 'clean' option to 'nand erase' to write JFFS2 clean markers - make NAND read/write faster * Patch by Rune Torgersen, 23 May 2003: Update for MPC8266ADS board
2003-04-10Changed DHCP client to use ip address from server option field #54 from the ↵stroese
OFFER-paket in the server option field #54 in the REQUEST-paket. This fixes a problem using a Windows 2000 DHCP server, where the DHCP-server is not the TFTP-server.
2003-04-05* Patch by Arun Dharankar, 4 Apr 2003:LABEL_2003_04_05_0300wdenk
Add IDMA example code (tested on 8260 only) * Add support for Purple Board (MIPS64 5Kc) * Add support for MIPS64 5Kc CPUs * Fix missing setting of "loadaddr" and "bootfile" on ARM and MIPS * Patch by Denis Peter, 04 Apr 2003: - update MIP405-4 board * Patches by Denis Peter, 03 April 2003: - fix PCI IRQs on MPL boards - fix two more un-relocated pointer problems * Fix behaviour of "run" command: - print error message iv variable does not exist - terminate processing of arguments in case of error * Patches by Peter Figuli, 10 Mar 2003 - Add support for BTUART on PXA platform - Add support for WEP EP250 (PXA) board * Fix flash problems on INCA-IP; add tool to allow bruning images to flash using a BDI2000 * Implement fix for I2C Edge Conditions problem for all boards that use the bit-banging driver (common/soft_i2c.c) * Add patches by Robert Schwebel, 31 Mar 2003: - csb226 board: bring in sync with innokom/memsetup.S - csb226 board: fix MDREFR handling - misc doc fixes / extensions - innokom board: cleanup, MDREFR fix in memsetup.S, config update - add BOOT_PROGRESS to armlinux.c
2003-03-06* Patches by Robert Schwebel, 06 Mar 2003:wdenk
- fix bug in BOOTP code (must use NetCopyIP) - update of CSB226 port - clear BSS segment on XScale - added support for i2c_init_board() function - update to the Innokom plattform * Extend support for redundand environments for configurations where environment size < sector size
2003-02-28* Add support for 16 MB flash configuration of TRAB boardLABEL_2003_02_28_0150wdenk
* Patch by Erwin Rol, 27 Feb 2003: Add support for RTEMS * Add image information to README * Fix dual PCMCIA slot support (when running with just one slot populated) * Add VFD type detection to trab board * extend drivers/cs8900.c driver to synchronize ethaddr environment variable with value in the EEPROM * Start adding MIPS support files
2003-01-17* Add dual ethernet support on PM826wdenk
* Add support for LXT971 PHY on PM826 * Patch by Tord Andersson, 16 Jan 2003: Fix flash sector count for TQM8xxL * Fix I2C EEPROM problem on ICU862 board (would only write the first 16 bytes out of each 32 byte block)
