path: root/net
2008-04-28net: make ARP timeout configurableGuennadi Liakhovetski
Currently the timeout waiting for an ARP reply is hard set to 5 seconds. On i.MX31ADS due to a hardware "strangeness" up to four first IP packets to the boards get lost, which typically are ARP replies. By configuring the timeout to a lower value we significantly improve the first network transfer time on this board. The timeout is specified in milliseconds, later internally it is converted to deciseconds, because it has to be converted to hardware ticks, and CFG_HZ ranges from 900 to 27000000 on different boards. Signed-off-by: Guennadi Liakhovetski <lg@denx.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-04-13Coding Style cleanup; update CHANGELOGWolfgang Denk
2008-04-08Merge branch 'master' of git://www.denx.de/git/u-boot-at91Wolfgang Denk
2008-04-01Add support for AT91SAM9260EKStelian Pop
Support for booting from internal DataFlash, external DataFlash card or NAND flash is available. Signed-off-by: Stelian Pop <stelian@popies.net>
2008-04-01Move at91cap9 specific files to at91sam9 directoryStelian Pop
AT91CAP9 and AT91SAM9 SoCs are very close hardware wise, so a common infrastructure can be used. Let this infrastructure be named after the AT91SAM9 family, and move the existing AT91CAP9 files to the new place. Signed-off-by: Stelian Pop <stelian@popies.net>
2008-03-30SPARC/LEON3: Added GRETH Ethernet 10/100/1000 driver.Daniel Hellstrom
GRETH is an Ethernet 10/100 or 10/100/1000 MAC with out without a debug link (EDCL). The GRETH core is documented in GRIP.pdf available at www.gaisler.com. If the GRETH has GigaBit support (GBIT, Scatter gather, checksum offloading etc.) can be determined by a bit in the control register. The GBIT MAC is supported by operating in GRTEH 10/100 legacy mode. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-03-30DHCP request fix for Windows Server 2003Aras Vaichas
Added option CONFIG_BOOTP_DHCP_REQUEST_DELAY. This provides an optional delay before sending "DHCP Request" in net/bootp.c. Required to overcome interoperability problems with Windows Server 200x DHCP server when U-Boot client responds too fast for server to handle. Signed-off-by: Aras Vaichas <arasv@magtech.com.au> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-03-05net: Print error message upon net usage when no ethernet-interface is foundStefan Roese
This patch fixes a problem seen on PPC4xx boards, when no MAC address is defined. Then no ethernet interface is available but a simple "tftp" command will return without any error message which is quite confusing. Signed-off-by: Stefan Roese <sr@denx.de>
2008-02-15Merge branch '080116_at91cap9' of git://linux-arm.org/u-boot-armdevPeter Pearse
2008-02-14TFTP: fix search of ':' in BootFileJean-Christophe PLAGNIOL-VILLARD
2008-02-14AT91CAP9 support : build integrationStelian Pop
2008-02-14NFS Timeout with large files.Hiroshi Ito
Retry to send NFS packet before reaching timeout. Signed-off-by: Hiroshi Ito <ito@mlb.co.jp>
2008-02-05TFTP: add host ip addr supportJean-Christophe PLAGNIOL-VILLARD
allow to use a different server as set in serverip add CONFIG_TFTP_FILE_NAME_MAX_LEN to configure the file name length if not defined the max length will be at 128 Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-01-23Merge branch 'master' of git://www.denx.de/git/u-boot-avr32Wolfgang Denk
2008-01-23Merge branch 'master' of git://www.denx.de/git/u-boot-coldfireWolfgang Denk
2008-01-18AVR32: ATNGW100 board supportHaavard Skinnemoen
Add support for the ATNGW100 Network Gateway reference design, including flash, ethernet and MMC support. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2008-01-17ColdFire: Add MCF547x_8x FEC driverTsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off by: John Rigby <jrigby@freescale.com>
2008-01-17net: add 'ethrotate' environment variableMatthias Fuchs
[PATCH] net: add 'ethrotate' environment variable This patch replaces the buildtime configuration option CONFIG_NET_DO_NOT_TRY_ANOTHER through the 'ethrotate' runtime configuration veriable. See README. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-01-15QE UEC: Extend number of supported UECs to 4David Saada
This patch extends the number of supported UECs to 4. Note that the problem of QE thread resources exhaustion is resolved by setting the correct number of QE threads according to Ethernet type (GBE or FE). Signed-off-by: David Saada <david.saada@ecitele.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-01-10Fix Ethernet init() return codesBen Warren
Change return values of init() functions in all Ethernet drivers to conform to the following: >=0: Success <0: Failure All drivers going forward should return 0 on success. Current drivers that return 1 on success were left as-is to minimize changes. Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Kim Phillips <kim.phillips@freescale.com> Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Acked-By: Timur Tabi <timur@freescale.com>
2008-01-08Add support CONFIG_UEC_ETH3 in MPC83xxJoakim Tjernlund
Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2008-01-03net: Add CONFIG_NET_DO_NOT_TRY_ANOTHER optionMatthias Fuchs
When CONFIG_NET_DO_NOT_TRY_ANOTHER is defined U-Boot's networking stack does not automatically switch to another interface. This patch does not touch the default behavior. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-01-03NET: Proper return code handling in eth_init() function in file eth.cUpakul Barkakaty
This patch modifies the return code handling in the eth_init() function, to be compatible with the handling of the return codes in the other network stack files. It now returns a 0 on Success and -1 on error. Signed-off-by: Upakul Barkakaty <upakul.barkakaty@conexant.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-01-03net/eth.c: Fix env_enetaddr signed overflowShinya Kuribayashi
Assigning the output of simple_strtoul(CB:A9:87:65:43:21) to `char', we are warned as below: U-Boot 1.2.0 (Aug 30 2007 - 08:27:37) DRAM: 256 MB Flash: 32 MB In: serial Out: serial Err: serial Net: NEC-Candy Warning: NEC-Candy MAC addresses don't match: Address in SROM is 00:00:4C:80:92:A2 Address in environment is FFFFFFCB:FFFFFFA9:FFFFFF87:65:43:21 This patch changes env_enetaddr type from `char' to `unsigned char'. Cc: Masaki Ishikawa <ishikawa-masaki@cnt.mxe.nes.nec.co.jp> Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-01-03Introduce new eth_receive routineRafal Jaworowski
The purpose of this routine is receiving a single network frame, outside of U-Boot's NetLoop(). Exporting it to standalone programs that run on top of U-Boot will let them utilise networking facilities. For sending a raw frame the already existing eth_send() can be used. The direct consumer of this routine is the newly introduced API layer for external applications (enabled with CONFIG_API). Signed-off-by: Rafal Jaworowski <raj@semihalf.com> Signed-off-by: Piotr Kruszynski <ppk@semihalf.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2007-11-20Merge branch 'origin' into kconfig-for-1.3.1Grant Likely
2007-11-18Fix warning differ in signedness in net/net.c and net/nfs.cJean-Christophe PLAGNIOL-VILLARD
2007-11-16Merge branch 'origin' into kconfig-for-1.3.1Grant Likely
Conflicts: drivers/Makefile
2007-11-15Build: split COBJS value into multiple linesGrant Likely
This change is in preparation for condtitionial compile support in the build system. By spliting them all into seperate lines now, subsequent patches that change 'COBJS-y += ' into 'COBJS-$(CONFIG_<blah>) += ' will be less invasive and easier to review Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-11-06Implement general ULi 526x Ethernet driver support in U-bootRoy Zang
This patch implements general ULi 526x Ethernet driver. Until now, it is the only native Ethernet port on MPC8610HPCD board, but it could be used on other boards with ULi 526x Ethernet port as well. Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Zhang Wei <wei.zhang@freescale.com> Acked-by: Jon Loeliger <jdl@freescale.com> Signed-off-by: Ben Warren <bwarren@qstreams.com>
2007-11-03Cleanup coding style; update CHANGELOGWolfgang Denk
2007-11-03Fix typo in nfs.cGuennadi Liakhovetski
An obvious typo. Originally fixed in linkstation u-boot port. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2007-11-01DHCP Client FixJustin Flammia
This is a multi-part message in MIME format. commit e6e505eae94ed721e123e177489291fc4544b7b8 Author: Justin Flammia <jflammia@savantav.com> Date: Mon Oct 29 17:19:03 2007 -0400 Found a bug in the way the DHCP Request packet is built, where the IP address that is offered by the server is bound to prematurely. This patch is a fix of that bug where the IP address offered by the DHCP server is not used until after the DHCP ACK from the server is received. Signed-off-by: Justin Flammia <jflammia@savantav.com> Signed-off-by: Ben Warren <bwarren@qstreams.com>
2007-09-18Avoid compiler warning.Wolfgang Denk
2007-09-12Fix memory corruption problem on STX GP3 SSA Board.Wolfgang Denk
2007-08-31Fix TFTP OACK code for short packets.Wolfgang Denk
The old code had a loop limit overflow bug which caused a semi- infinite loop for small packets, because in "i<len-8", "i" was signed, but "len" was unsigned, and "len-8" became a huge number for small values of "len". This is a workaround which replaces broken commit 8f1bc284. Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-08-30Backout commit 8f1bc284 as it causes TFTP to fail.Wolfgang Denk
2007-08-30tftp: don't implicity trust the format of recevied packetsGrant Likely
The TFTP OACK code trusts that the incoming packet is formated as ASCII text and can be processed by string functions. It also has a loop limit overflow bug where if the packet length is less than 8, it ends up looping over *all* of memory to find the 'blksize' string. This patch solves the problem by forcing the packet to be null terminated and using strstr() to search for the sub string. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-08-29Fix: TFTP is not working on little endian systemsstefano babic
TFTP does not work anymore after multicast tftp patch was applied on little endian systems. This patch fix it. Signed-off-by: Stefano Babic <sbabic@denx.de>
2007-08-16Merge branch 'denx-coldfire' into coldfire-aug2007John Rigby
2007-08-1586xx: Fix lingering CFG_CMD_* references in sbc8641d.hJon Loeliger
Remove a leftover in net/tftp.c while we're at it. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-08-15Merge with git://www.denx.de/git/u-boot.gitStefan Roese
2007-08-14Coding style cleanup; rebuild CHANGELOGWolfgang Denk
2007-08-13multicast tftp: RFC2090David Updegraff
Implemented IETF RFC2090, Multicast TFTP. Initial implementation on Realtek RTL8139 and Freescale TSEC. Signed-off-by: David Updegraff <dave@cray.com> Signed-off-by: Ben Warren <bwarren@qstreams.com>
2007-08-13New CONFIG_BOOTP_SERVERIP optionWilson Callan
Added CONFIG_BOOTP_SERVERIP to allow the tftp server to be different from the bootp server Signed-off-by: Wilson Callan <wcallan@savantav.com> Signed-off-by: Ben Warren <bwarren@qstreams.com>
2007-08-10[ARM] TI DaVinci support, hopefully finalSergey Kubushyn
Add support for the following DaVinci boards: - DV_EVM - SCHMOOGIE - SONATA Changes: - Split into separate board directories - Removed changes to MTD_DEBUG (or whatever it's called) - New CONFIG_CMD party line followed - Some cosmetic fixes, cleanup etc. - Patches against the latest U-Boot tree as of now. - Fixed CONFIG_CMD_NET in net files. - Fixed CONFIG_CMD_EEPROM for schmoogie. - Made sure it compiles and works (forceenv() link problem) on SCHMOOGIE and DV_EVM. Can't check if it works on SONATA, don't have a board any more, but it at least compiles. Here is an excerpt from session log on SCHMOOGIE... U-Boot 1.2.0-g6c33c785-dirty (Aug 7 2007 - 13:07:17) DRAM: 128 MB NAND: 128 MiB In: serial Out: serial Err: serial ARM Clock : 297MHz DDR Clock : 162MHz ETH PHY : DP83848 @ 0x01 U-Boot > iprobe Valid chip addresses: 1B 38 3A 3D 3F 50 5D 6F U-Boot > ping 192.168.253.10 host 192.168.253.10 is alive U-Boot > Signed-off-by: Sergey Kubushyn <ksi@koi8.net> Acked-by: Dirk Behme <dirk.behme@gmail.com> Acked-by: Zach Sadecki <Zach.Sadecki@ripcode.com> Acked-by: Stefan Roese <sr@denx.de>
2007-08-06Merge with /home/wd/git/u-boot/custodian/u-boot-testingWolfgang Denk
2007-08-03Merge branch 'testing' into workingAndy Fleming
Conflicts: CHANGELOG fs/fat/fat.c include/configs/MPC8560ADS.h include/configs/pcs440ep.h net/eth.c
2007-07-27[ADS5121] Support for the ADS5121 boardRafal Jaworowski
The following MPC5121e subsystems are supported: - low-level CPU init - NOR Boot Flash (common CFI driver) - DDR SDRAM - FEC - I2C - Watchdog Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com> Signed-off-by: Rafal Jaworowski <raj@semihalf.com> Signed-off-by: Jan Wrobel <wrr@semihalf.com>
2007-07-16Merge with /home/stefan/git/u-boot/u-boot-coldfire-freescaleStefan Roese
