CONFIG_TFTP_TSIZE should limit a tftp downloads progress to 50 '#' chars.
Make this work also for small files.
If the file size is small, i.e. smaller than 2 tftp block sizes the number
of '#' can get much larger. i.e. with a 1 byte file 65000 characters are
printed, with a 512 byte file around 500.
When using CONFIG TFTP BLOCKSIZE together with CONFIG_IP_DEFRAG the issue
is more notable.
Drop the old checksum functions in favour of the new ones.
Move the checksum code out into its own file so it can be used elsewhere.
Also use a new version which supports a length which is not a multiple of
2 and add a new function to add two checksums.
Currenly when CONFIG_BOOTP_SERVERIP is defined, the SERVERIP is not changed
when receive the BOOTP packet. But BOOTFILE is changed via BOOTP packet.
As we will load the BOOTFILE from SERVERIP, if the BOOTFILE is modified
by bootp packet but SERVERIP is not, that is not make sense.
This patch make SERVERIP and BOOTFILE be consistent. If we define the
CONFIG_BOOTP_SERVERIP, then SERVERIP and BOOTFILE will not changed by
BOOTP packet. Only IP address is changed.
Signed-off-by: Josh Wu <josh.wu@atmel.com>
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
If we know the file size, display it after loading the file.
A number of network related files were imported from the LiMon
project; these contain a somewhat unclear license statement:
Copyright 1994 - 2000 Neil Russell.
(See License)
I analyzed the source code of LiMon v1.4.2 which was used for this
import. It does not contain any "License" file, but the top level
directory contains a file "COPYING", which turns out to be GPL v2
of June 1991. So it is legitimate to conclude that the LiMon derived
files are also to be released under GPLv2. Mark them as such.
This would be useful to start moving various config options.
When a DNS query is sent out, the ethernet packet can get directed to
the MAC address of a server that was communicated to before. This is
wrong when the previously stored MAC address corresponds to a different
server's IP address, i.e. when the IP address of the previous and the
current communication are different.
The error can get reproduced by running a sequence of e.g. a TFTP
download and a DNS query, where the TFTP and DNS servers reside on
individual machines.
The fix is to clear the server's MAC address that might be left from a
previous operation, and to fetch the peer's MAC address in a new ARP
lookup, before the DNS query is sent. This is the approach taken in
other network services, like 8e52533d1095 ("net: tftpsrv: Get correct
client MAC address").
Reported-by: Dirk Zimoch <dirk.zimoch@psi.ch>
Signed-off-by: Gerhard Sittig <gsi@denx.de>
It's not unusual for DHCP servers to take a couple hundred milliseconds
to respond to DHCP discover messages. One possible reason for the delay
can be that the server checks (typically using an ARP request) that the
IP it's about to hand out isn't in use yet. To make matters worse, some
servers may also queue up requests and process them sequentially, which
can cause excessively long delays if clients retry too fast.
Commit f59be6e850b3 ("net: BOOTP retry timeout improvements") shortened
the retry timeouts significantly, but the BOOTP/DHCP implementation in
U-Boot doesn't handle that well because it will ignore incoming replies
to earlier requests. In one particular setup this increases the time it
takes to obtain a DHCP lease from 630 ms to 8313 ms.
This commit attempts to fix this in two ways. First it increases the
initial retry timeout from 10 ms to 250 ms to give DHCP servers some
more time to respond. At the same time a cache of outstanding DHCP
request IDs is kept so that the implementation will know to continue
transactions even after a retransmission of the DISCOVER message. The
maximum retry timeout is also increased from 1 second to 2 seconds. An
ID cache of size 4 will keep DHCP requests around for 8 seconds (once
the maximum retry timeout has been reached) before dropping them. This
should give servers plenty of time to respond. If it ever turns out
that this isn't enough, the size of the cache can easily be increased.
With this commit the DHCP lease on the above-mentioned setup still takes
longer (1230 ms) than originally, but that's an acceptable compromise to
improve DHCP lease acquisition time for a broader range of setups.
To make it easier to benchmark DHCP in the future, this commit also adds
the time it took to obtain a lease to the final "DHCP client bound to
address x.x.x.x" message.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Currently, the BOOTP code sends out its initial request as soon as the
Ethernet driver indicates "link up". If this packet is lost or not
replied to for some reason, the code waits for a 1s timeout before
retrying. For some reason, such early packets are often lost on my
system, so this causes an annoying delay.
To optimize this, modify the BOOTP code to have very short timeouts for
the first packet transmitted, but gradually increase the timeout each
time a timeout occurs. This way, if the first packet is lost, the second
packet is transmitted quite quickly and hence the overall delay is low.
However, if there's still no response, we don't keep spewing out packets
at an insane speed.
It's arguably more correct to try and find out why the first packet is
lost. However, it seems to disappear inside my Ethenet chip; the TX chip
indicates no error during TX (not that it has much in the way of
reporting...), yet wireshark on the RX side doesn't see any packet.
FWIW, I'm using an ASIX USB Ethernet adapter. Perhaps "link up" is
reported too early or based on the wrong condition in HW, and we should
add some fixed extra delay into the driver. However, this would slow down
every link up event even if it ends up not being needed in some cases.
Having BOOTP retry quickly applies the fix/WAR to every possible
Ethernet device, and is quite simple to implement, so seems a better
solution.
Improve error messages in case of invalid/unset ethernet addresses.
Signed-off-by: Pavel Machek <pavel@denx.de>
Cleanup bootp code by using mdelay.
SPL stage does not support various networking things, and therefore
CONFIG_NETCONSOLE cannot be built within SPL.
Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
Some functions in include/net.h are ported from
include/linux/etherdevice.h of Linux Kernel.
For ex.
is_zero_ether_addr()
is_multicast_ether_addr()
is_broadcast_ether_addr()
is_valid_ether_addr();
So, we should use the same function name as that of Linux Kernel,
eth_rand_addr(), for consistency.
Besides, eth_rand_addr() has been implemented as an inline function.
So it should not be surrounded by #ifdef CONFIG_RANDOM_MACADDR.
Changes in lib/uuid.c to:
- uuid_str_to_bin()
- uuid_bin_to_str()
New parameter is added to specify input/output string format in listed functions
This change allows easy recognize which UUID type is or should be stored in given
string array. Binary data of UUID and GUID is always stored in big endian, only
string representations are different as follows.
String byte: 0 36
String char: xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
string UUID: be be be be be
string GUID: le le le be be
This patch also updates functions calls and declarations in a whole code.
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
Cc: Stephen Warren <swarren@nvidia.com>
Cc: Lukasz Majewski <l.majewski@samsung.com>
Cc: trini@ti.com
Now we are ready to switch over to real Kbuild.
This commit disables temporary scripts:
scripts/{Makefile.build.tmp, Makefile.host.tmp}
and enables real Kbuild scripts:
scripts/{Makefile.build,Makefile.host,Makefile.lib}.
This switch is triggered by the line in scripts/Kbuild.include
-build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build.tmp obj
+build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build obj
We need to adjust some build scripts for U-Boot.
But smaller amount of modification is preferable.
Additionally, we need to fix compiler flags which are
locally added or removed.
In Kbuild, it is not allowed to change CFLAGS locally.
Instead, ccflags-y, asflags-y, cppflags-y,
CFLAGS_$(basetarget).o, CFLAGS_REMOVE_$(basetarget).o
are prepared for that purpose.
Tested-by: Gerhard Sittig <gsi@denx.de>
In "common/Makefile" "miiphyutil.o" gets built if any of the following
items enabled:
* CONFIG_PHYLIB
* CONFIG_MII
* CONFIG_CMD_MII
So it's possible to not define CONFIG_MII or CONFIG_CMD_MII and still
use functions like "miiphy_get_dev_by_name".
In its turn "miiphy_get_dev_by_name" traverses "mii_devs" list which is
not initialized because "miiphy_init" never got called.
Cc: Rob Herring <rob.herring@calxeda.com>
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
NetServerEther was not being cleared in the tftp server code, so the
destination MAC address would be whatever the last destination MAC
address was.
Scenario:
U-Boot:
dhcp
tftpsrv
Host:
Send device WRQ
Device:
Responds with ACK to dhcp server mac address with
host ip address
By clearing NetServerEther, we force a lookup of the host MAC address
to go with the associated host IP.
Signed-off-by: Andrew Ruder <andrew.ruder@elecsyscorp.com>
When the block 0 store to the memory of client and timeout at this
moment. Because of no ACK packet, the server will send block 0 again,
if this client reconnect to the server at this time,
TftpBlockWrapOffset will become larger than it should be.
Signed-off-by: Rockly <rocklygnome@gmail.com>
Patch: 264417
This flag is to make console aware that NET transfer is running or not.
Signed-off-by: Jim Lin <jilin@nvidia.com>
[trini: Fixup common/cmd_io.c]
Make the link-local code conform more completely with the RFC.
This will prevent ARP queries for the target (such as while it is
rebooting) from causing the device to choose a different link-local
address, thinking that its address is in use by another machine.
tftp.c:464:17: warning: cast to restricted __be16
tftp.c:552:29: warning: cast to restricted __be16
tftp.c:640:33: warning: cast to restricted __be16
tftp.c:642:25: warning: cast to restricted __be16
Cc: Joe Hershberger <joe.hershberger@gmail.com>
This patch tackles the time out problem which leads to break the
boot process, when loading file over nfs. The patch does two things.
First of all, we just ignore messages that arrive with a rpc_id smaller
then the client id. We just interpret this messages as answers to
formaly timed out messages.
Second, when a time out occurs we double the time to wait, so that we
do not stress the server resending the last message.
Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
Tested-by: Enric Balletbo i Serra <eballetbo@gmail.com>
If we try to boot from NET device, NetInitLoop in net.c will be invoked.
If NET device is not installed, eth_get_dev() function will return
eth_current value, which is NULL.
When NetInitLoop is called, "eth_get_dev->enetaddr" will access
restricted memory area and therefore cause hanging.
This issue is found on Tegra30 Cardhu platform after adding
CONFIG_CMD_NET and CONFIG_CMD_DHCP in config header file.
Use setenv_ulong(), setenv_hex() and setenv_addr() in net/
The ip is stored in network order, so we can't test it in host order.
Reviewed-by: Kim Phillips <kim.phillips@freescale.com>
This prints a tftp speed indication after the download completes. This
is the 3.6 MiB/s indicator below.
Tegra2 (SeaBoard) # tftp ...
Using asx0 device
TFTP from server 172.22.72.144; our IP address is 172.22.73.81
Filename '/tftpboot/uImage-user-seaboard-1'.
Load address: 0x408000
Loading: #################################################
3.6 MiB/s
done
Remove the hard-coded bootfile handler and use a callback instead
Move the getenv_yesno() to env_common.c and change most checks for
'y' or 'n' to use this helper.
bootp.c:44:14: warning: symbol 'dhcp_state' was not declared. Should it be static?
bootp.c:45:15: warning: symbol 'dhcp_leasetime' was not declared. Should it be static?
bootp.c:46:10: warning: symbol 'NetDHCPServerIP' was not declared. Should it be static?
arp.c:30:17: warning: symbol 'NetArpWaitReplyIP' was not declared. Should it be static?
arp.c:37:16: warning: symbol 'NetArpTxPacket' was not declared. Should it be static?
arp.c:38:17: warning: symbol 'NetArpPacketBuf' was not declared. Should it be static?
atheros.c:33:19: warning: symbol 'AR8021_driver' was not declared. Should it be static?
net.c:183:7: warning: symbol 'PktBuf' was not declared. Should it be static?
net.c:159:21: warning: symbol 'net_state' was not declared. Should it be static?
ping.c:73:6: warning: symbol 'ping_start' was not declared. Should it be static?
ping.c:82:13: warning: symbol 'ping_receive' was not declared. Should it be static?
tftp.c:53:7: warning: symbol 'TftpRRQTimeoutMSecs' was not declared. Should it be static?
tftp.c:54:5: warning: symbol 'TftpRRQTimeoutCountMax' was not declared. Should it be static?
eth.c:125:19: warning: symbol 'eth_current' was not declared. Should it be static?
Note: in the ping.c fix, commit a36b12f95a29647a06b5459198684fc142482020
"net: Move PING out of net.c" mistakenly carried the ifdef CMD_PING
clause from when it was necessary to avoid warnings when it was embedded
in net.c.
Adjustment of Michael Walle's fix patch
Commit 8a0eccb1056b313b45ab62e3aac400f339aa71b4 breaks netconsole. src_ip
must not be converted to host byte order, because nc_ip is already stored
in network byte order (see string_to_ip(), called by getenv_IPaddr()).
This patch adds support for networking in SPL. Some devices are
capable of loading SPL via network so it makes sense to load the
main U-Boot binary via network too. This patch tries to use
existing network code as much as possible. Unfortunately, it depends
on environment which in turn depends on other code so SPL size
is increased significantly. No effort was done to decouple network
code and environment so far.
Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com>
Vendor Class Identifier option is common to BOOTP and DHCP and
can be useful without PXE. So send VCI in both BOOTP and DHCP
requests if CONFIG_BOOTP_VCI_STRING is defined.
Some DHCP servers (notably dnsmasq) always transmit DHCP Option 28,
Broadcast Address as specified in RFC 2132. Without this patch u-boot
displays the warning:
*** Unhandled DHCP Option in OFFER/ACK: 28
The patch suppresses the warning and ignores DHCP Option 28. There is
no environment variable to set the broadcast address into and if for
some reason u-boot needs the broadcast it can be calculated from
ipaddr and netmask.
Signed-off-by: Brian Rzycki <bmr@freescale.com>
If dev->enetaddr was supposed to be set with dev->write_hwaddr() but the MAC
address was not valid, return an error.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Check the incoming packets' source IP address... if ncip isn't set to a
broadcast address, only listen to the client at ncip.
Previously u-boot would initialize the network interface for every
network operation and then shut it down again. This makes sense for
most operations where the network in not known to be needed soon after
the operation is complete. In the case of netconsole, it will use the
network for every interaction with the shell or every printf. This
means that the network is being reinitialized very often. On many
devices, this intialization is very slow.
This patch checks for consecutive netconsole actions and leaves the
ethernet hardware initialized between them. It will still behave the
same old way for all other network operations and any time another
network operation happens between netconsole operations.
NetSetTimeout sets incorrect value to timeDelta when CONFIG_SYS_HZ != 1000.
Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
If the requested length is too small to hold the received packet,
eth_receive() will return -1 and will leave the packet in the receive
buffers. Instead of returning an error in this case, we return the first
portion of the received packet and remove it from the receive buffers.
This fixes FreeBSD's ubldr. Without this patch it will just stop receiving
packets if the NIC receives more than PKTBUFSRX too large packets.
Signed-off-by: Michael Walle <michael@walle.cc>
Cc: Rafal Jaworowski <raj@semihalf.com>
Cc: Piotr Kruszynski <ppk@semihalf.com>
* 'next' of git://git.denx.de/u-boot:
MPC8xx: Fixup warning in arch/powerpc/cpu/mpc8xx/cpu.c
doc: cleanup - move board READMEs into respective board directories
net: sh_eth: add support for SH7757's GETHER
net: sh_eth: modify the definitions of regsiter
net: sh_eth: add SH_ETH_TYPE_ condition
net: sh_eth: clean up for the SH7757's code
net: fec_mxc: Fix MDC for xMII
net: fec_mxc: Fix setting of RCR for xMII
net: nfs: make NFS_TIMEOUT configurable
net: Inline the new eth_setenv_enetaddr_by_index function
net: allow setting env enetaddr from net device setting
net/designware: Consecutive writes to the same register to be avoided
CACHE: net: asix: Fix asix driver to work with data cache on
net: phy: micrel: make ksz9021 phy accessible
net: abort network initialization if the PHY driver fails
phylib: phy_startup() should return an error code on failure
net: tftp: fix type of block arg to store_block
NetConsole may call NetSendUDPPacket before NetLoop is called. This
will cause the source MAC address (NetOurEther) to be wrong. Instead
of only changing it in NetLoop, move it to NetLoopInit so that it is
also updated when net_init() is called (especially by nc_start()).
Reported-by: Michael Walle <michael@walle.cc>
Acked-by: Michael Walle <michael@walle.cc>
Fix comment within comment build error.
Fix NetSetState function name used with CONFIG_BOOTP_MAY_FAIL.
NFS_TIMEOUT is constant value defined in net/nfs.c. But sometimes it needs to adjust.
This patch enables to override NFS_TIMEOUT by defining CONFIG_NFS_TIMEOUT in a board specific config file.
* 'next' of git://git.denx.de/u-boot-net:
This function is currently only used in one case. Inline for now.
