path: root/net
2010-06-20net/eth.c: eth_mac_skip() is only needed when CONFIG_NET_MULTI is setWolfgang Denk
Move it inside the #ifdef CONFIG_NET_MULTI to avoid eth.c:64: warning: 'eth_mac_skip' defined but not used messages from a number of old, non-CONFIG_NET_MULTI boards. Signed-off-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-06-20ip/defrag: fix processing of last short fragmentFillod Stephane
TFTP'ing a file of size 1747851 bytes with CONFIG_IP_DEFRAG and CONFIG_TFTP_BLOCKSIZE set to 4096 fails with a timeout, because the last fragment is not taken into account. This patch fixes IP fragments having less than 8 bytes of payload. Signed-off-by: Stephane Fillod <stephane.fillod@grassvalley.com> Acked-by: Alessandro Rubini <rubini@gnudd.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-05-03Program net device MAC addresses after initializingBen Warren
Add a new function to the eth_device struct for programming a network controller's hardware address. After all network devices have been initialized and the proper MAC address for each has been determined, make a device driver call to program the address into the device. Only device instances with valid unicast addresses will be programmed. Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Detlev Zundel <dzu@denx.de> Tested-by: Prafulla Wadaskar <prafulla@marvell.com> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Thomas Chou <thomas@wytron.com.tw>
2010-05-03./net/net.c - make Microsoft dns servers happy with random_port() numbersRobin Getz
For some reason, (which I can't find any documentation on), if U-Boot gives a port number higher than 17500 to a Microsoft DNS server, the server will reply to port 17500, and U-Boot will ignore things (since that isn't the port it asked the DNS server to reply to). This fixes that by ensuring the random port number is less than 17500. Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-05-03net: Trivial coding style issue with empty for statementDetlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-03-21TFTP: allow for adjustable retransmission timoutWolfgang Denk
So far, TFTP negotiated a fixed retransmission timeout of 5 seconds. In some cases (busy networks, slow TFTP servers) this caused very slow transfers. A new environment variable "tftptimeout" allows to set this timeout. Lowering this value may make downloads succeed faster in networks with high packet loss rates or with unreliable TFTP servers. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-01-17Make getenv_IPaddr() globalDirk Behme
There are boards out there that do not have network support in U-Boot (CONFIG_CMD_NET not set), but they do so in Linux. This makes it desirable to be able to port network configuration (like the IP address) to the Linux kernel. We should not make the passing of the IP configuration to Linux dependent on U-Boot features / settings. For this, make getenv_IPaddr() global. This fixes build error u-boot/lib_xxx/board.c:360: undefined reference to `getenv_IPaddr' on various architectures. Signed-off-by: Dirk Behme <dirk.behme@googlemail.com> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2009-12-13Add error codes/handling for TFTP-serverRemy Bohmer
Signed-off-by: Remy Bohmer <linux@bohmer.net> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-12-13net: pull CONFIG checks out of source and into makefileMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-12-07nfs: NfsTimeout() updatesEvan Samanas
- NfsTimeout() does not correctly update the NFS timeout value which results in NfsTimeout() only being called once in certain situations. This can result in the 'nfs' command hanging indefinetly. For example, the command: nfs 192.168.0.1:/home/user/file will not exit until ctrl-c is pressed if 192.168.0.1 does not have an NFS server running. This issue is resolved by reinitializting the NFS timeout value inside NfsTimeout() when a timeout occurs. - Make the 'nfs' command print the 'T' character when a timeout occurs. Previously there was no indication that timeouts were occuring. - Mimic the 'tftpboot' command and when a download fails print "Retry count exceeded; starting again", and restart the download taking the 'netretry' environment variable into account. Signed-off-by: Evan Samanas <esamanas@xes-inc.com> Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Tested on TQM8xxL. Tested by: Wolfgang Denk <wd@denx.de> Tested on MPC8527DS. Tested by: Ed Swarthout <Ed.Swarthout@freescale.com>
2009-12-07fix nfs symlink name corruptionEd Swarthout
An off by one error may cause nfs readlink lookup fail if nfs_path_buff has non-zero data from a previous use. Loading: *** ERROR: File lookup fail Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
2009-11-24Repair the 'netretry=once' option.Remy Bohmer
'netretry = once' does the same as 'netretry = yes', because it is not stored when it was tried once. Signed-off-by: Remy Bohmer <linux@bohmer.net> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-09-11net/bootp.c: fix compile warningWolfgang Denk
Fix warning: bootp.c:695: warning: dereferencing type-punned pointer will break strict-aliasing rules Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Ben Warren <biggerbadderben@gmail.com>
2009-08-25Add Transfer Size Option to tftpRobin Getz
Optionally add RFC 2349 "Transfer Size Option", so we can minimize the time spent sending data over the UART (now print a single line during a tftp transfer). - If turned on (CONFIG_TFTP_TSIZE), U-Boot asks for the size of the file. - if receives the file size, a single line (50 chars) are printed. one hash mark == 2% of the file downloaded. - if it doesn't receive the file size (the server doesn't support RFC 2349, prints standard hash marks (one mark for each UDP frame). Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-08-25nfs: accept CONFIG_NFS_READ_SIZE from config fileAlessandro Rubini
To take advantage of defragmented packets, the config file can define CONFIG_NFS_READ_SIZE to override the 1kB default. No support is there for an environment variable by now. Signed-off-by: Alessandro Rubini <rubini@gnudd.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-08-25tftp: get the tftp block size from config file and from the environmentAlessandro Rubini
Increasing the block size is useful if CONFIG_IP_DEFRAG is used. Howerver, the last fragments in a burst may overflow the receiving ethernet, so the default is left at 1468, with thre new CONFIG_TFTP_BLOCKSIZE for config files. Further, "tftpblocksize" can be set in the environment. Signed-off-by: Alessandro Rubini <rubini@gnudd.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-08-25net: defragment IP packetsAlessandro Rubini
The defragmenting code is enabled by CONFIG_IP_DEFRAG; the code is useful for TFTP and NFS transfers. The user can specify the maximum defragmented payload as CONFIG_NET_MAXDEFRAG (default 16k). Since NFS has a bigger per-packet overhead than TFTP, the static reassembly buffer can hold CONFIG_NET_MAXDEFRAG + the NFS overhead. The packet buffer is used as an array of "hole" structures, acting as a double-linked list. Each new fragment can split a hole in two, reduce a hole or fill a hole. No support is there for a fragment overlapping two diffrent holes (i.e., thre new fragment is across an already-received fragment). Signed-off-by: Alessandro Rubini <rubini@gnudd.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-08-10net/tftp.c: fix warning: pointer targets differ in signednessWolfgang Denk
tftp.c:294: warning: pointer targets in passing argument 1 of 'strlen' differ in signedness This was only visible for the utx8245 board which seems to have DEBUG enabled. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-08-07net: sync env ethaddr to device enetaddr in eth_init()Mike Frysinger
In the previous enetaddr refactoring, the assumption with commit 56b555a644 was that the eth layer would handle the env -> device enetaddr syncing. This was not the case as eth_initialize() is called only once and the sync occurs there. So make sure the eth_init() function does the env -> device sync with every network init. Reported-by: Andrzej Wolski <awolski@poczta.fm> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-08-07minor debug cleanups in ./netRobin Getz
Minor ./net cleanups - no functional changes - change #ifdef DEBUG printf(); #endif to just debug() - changed __FUNCTION__ to __func__ - got rid of extra whitespace between function and opening brace - removed unnecessary braces on if statements gcc dead code elimination should make this functionally/size equivalent when DEBUG is not defined. (confirmed on Blackfin, with gcc 4.3.3). Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-07-23Coding Style cleanup; update CHANGELOG.Wolfgang Denk
2009-07-22Save server's MAC address in environmentRobin Getz
Linux's netconsole works much better when you can pass it the MAC address of the server. (otherwise it just uses broadcast, which everyone else on my network complains about :) This sets the env var "serveraddr" (to match ethaddr), so that you can pass it to linux with whatever bootargs you want to.... addnetconsole=set bootargs $(bootargs) netconsole=@$(ipaddr)/eth0,@$(serverip)/$(serveraddr) Signed-of-by: Robin Getz <rgetz@blackfin.uclinux.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-07-22DHCP regression on 2009-06Michael Zaidman
Fixed the DHCP/BOOTP/RARP regression introduced in u-boot-2009.06 by initializing our IP addr to 0 in order to accept any IP addr assigned to us by the DHCP/BOOTP/RARP server. Ack-by: Robin Getz <rgetz@blackfin.uclinux.org> Signed-off-by: Michael Zaidman <michael.zaidman@gmail.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-07-22Add warning about upcoming removal of old Ethernet APIBen Warren
2009-07-22Add DNS supportRobin Getz
On 04 Oct 2008 Pieter posted a dns implementation for U-Boot. http://www.mail-archive.com/u-boot-users@lists.sourceforge.net/msg10216.html > > DNS can be enabled by setting CFG_CMD_DNS. After performing a query, > the serverip environment var is updated. > > Probably there are some cosmetic issues with the patch. Unfortunatly I > do not have the time to correct these. So if anybody else likes DNS > support in U-Boot and has the time, feel free to patch it in the main tree. Here it is again - slightly modified & smaller: - update to 2009-06 (Pieter's patch was for U-Boot 1.2.0) - README.dns is added - syntax is changed (now takes a third option, the env var to store the result in) - add a random port() function in net.c - sort Makefile in ./net/Makefile - dns just returns unless a env var is given - run through checkpatch, and clean up style issues - remove packet from stack - cleaned up some comments - failure returns much faster (if server responds, don't wait for timeout) - use built in functions (memcpy) rather than byte copy. Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org> Signed-off-by: Pieter Voorthuijsen <pieter.voorthuijsen@prodrive.nl> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-07-22net: rename NetRxPkt to NetRxPacketMike Frysinger
The net code is mostly consistent in using 'Packet' rather than 'Pkt', so rename the minor detractor to follow suite. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-06-15A VLAN tagged DHCP request/discover is 4 bytes shortNorbert van Bolhuis
The problem is that BOOTP_SIZE uses ETHER_HDR_SIZE which is 14 bytes. If sending a VLAN tagged frame (when env variable vlan is set) this should be VLAN_ETHER_HDR_SIZE=18 which is what NetSetEther returns. Signed-off-by: Norbert van Bolhuis <nvbolhuis@aimvalley.nl> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-06-15Remove support for non-CONFIG_NET_MULTI on PPC4xx EMACBen Warren
2009-06-15Switched davinci_emac Ethernet driver to use newer APIBen Warren
Added CONFIG_NET_MULTI to all Davinci boards Removed all calls to Davinci network driver from board code Added cpu_eth_init() to cpu/arm926ejs/cpu.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-05-15netloop: updates for NetLoopHeiko Schocher
Fix some issues introduced from commit: 2f70c49e5b9813635ad73666aa30f304c7fdeda9 suggested by Mike Frysinger. - added some comment for the env_id variable in common_cmd_nvedit.c - moved some variables in fn scope instead of file scope - NetInitLoop now static void Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2009-04-28Replace __attribute references with __attribute__Peter Tyser
__attribute__ follows gcc's documented syntax and is generally more common than __attribute. This change is only asthetic and should not affect functionality. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-04-19NetLoop initialization bugMichael Zaidman
The patch fixes the bug of partial initialization of global network parameters. Upon u-boot's start up the first ping command causes a failure of the consequent TFTP command. It happens in the recently added mechanism of the NetLoop initialization where initialization of global network parameters is separated in the NetInitLoop routine which is called per env_id change. Thus, ping request will initialize the network parameters necessary for ping operation only, afterwards the env_changed_id will be set to the env_id that will prevent all following initialization requests from other protocols. The problem is that the initialized by ping subset of network parameters is not sufficient for other protocols and particularly for TFTP which requires the NetServerIp also. Signed-off-by: Michael Zaidman <michael.zaidman@gmail.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-03-20net: get mac address from environment and use eth util funcsMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20net: new utility functions for working with enetaddr'sMike Frysinger
Declare new utility functions for converting between the environment variables (eth*addr) and the binary MAC address representation. This way we can unify all the random places that already do this kind of thing. The functions in question: eth_parse_enetaddr - "..." -> {...} eth_getenv_enetaddr - env -> {...} eth_setenv_enetaddr - {...} -> env Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20convert print_IPaddr() to %pI4Mike Frysinger
Now that our printf functions support the %pI4 modifier like the kernel, let's drop the inflexible print_IPaddr() function and covert over to the %pI4 modifier. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-02-22netloop: speed up NetLoopHeiko Schocher
NetLoop polls every cycle with getenv some environment variables. This is horribly slow, especially when the environment is big. This patch reads only the environment variables in NetLoop, when they were changed. Also moved the init part of the NetLoop function in a seperate function. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-02-16Add eth_get_dev_by_indexAndy Fleming
This allows code to iterate through the ethernet devices Signed-off-by: Andy Fleming <afleming@freescale.com>
2009-02-09net/sntp.c: move ifdef into Makefile COBJS-$(...)Mike Frysinger
2009-01-28Fix IP alignment problemOlav Morken
This patch removes volatile from: volatile IP_t *ip = (IP_t *)xip; Due to a bug, avr32-gcc will assume that ip is aligned on a word boundary when using volatile, which causes an exception since xip isn't aligned on a word boundary. Signed-off-by: Gunnar Rangoy <gunnar@rangoy.com> Signed-off-by: Paul Driveklepp <pauldriveklepp@gmail.com> Signed-off-by: Olav Morken <olavmrk@gmail.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-12-09Merge branch 'master' of git://git.denx.de/u-boot-netWolfgang Denk
2008-12-06Update U-Boot's build timestamp on every compilePeter Tyser
Use the GNU 'date' command to auto-generate a new U-Boot timestamp on every compile. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-12-04net: Fix TftpStart() ip:filename bugPeter Tyser
The TftpStart() function modifies the 'BootFile' string when 'BootFile' contains both an IP address and filename (eg 1.2.3.4:/path/file). This causes subsequent calls to TftpStart to incorrectly parse the TFTP filename and server IP address to use. For example: => tftp 0x100000 10.52.0.62:/home/ptyser/non_existant Speed: 100, half duplex Using eTSEC1 device TFTP from server 10.52.0.62; our IP address is 10.52.253.79 ^^^^^^^^^^ CORRECT Filename '/home/ptyser/non_existant'. ^^^^^^^^^^^^^^^^^^^^^^^^^ CORRECT Load address: 0x100000 Loading: * TFTP error: 'File not found' (1) Starting again eTSEC2: No link. Speed: 100, half duplex Using eTSEC1 device TFTP from server 10.52.0.33; our IP address is 10.52.253.79 ^^^^^^^^^^ WRONG Filename '10.52.0.62'. ^^^^^^^^^^ WRONG Load address: 0x100000 Loading: * TFTP error: 'File not found' (1) Starting again TftpStart() was modified to not modify the 'BootFile' string. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-12-04net: Add additional IP fragmentation checkPeter Tyser
Ignore IP packets which have the "more fragments" flag bit set. This flag indicates the IP packet is fragmented and must be ignored by U-Boot. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-12-04net: Define IP flag field valuesPeter Tyser
These defines were pulled from the "Add simple IP/UDP fragmentation support" patch from Frank Haverkamp <haver@vnet.ibm.com>. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-11-09Moved initialization of PPC4xx EMAC to cpu_eth_init()Ben Warren
Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Stefan Roese <sr@denx.de>
2008-11-09Changed PPC4xx EMAC driver to require CONFIG_PPC4xx_EMACBen Warren
All in-tree IBM/AMCC PPC4xx boards using the EMAC get this new CONFIG Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Stefan Roese <sr@denx.de>
2008-11-09Moved initialization of MPC8XX SCC to cpu_eth_init()Ben Warren
2008-11-09Moved initialization of MPC8220 FEC to cpu_eth_init()Ben Warren
2008-11-09Moved initialization of QE Ethernet controller to cpu_eth_init()Ben Warren
2008-11-09Moved initialization of FCC Ethernet controller to cpu_eth_initBen Warren
Affected boards: Several MPC8xx boards Several MPC8260/MPC8272 boards Several MPC85xx boards Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
