path: root/net
2008-11-09Moved initialization of FCC Ethernet controller to cpu_eth_initBen Warren
Affected boards: Several MPC8xx boards Several MPC8260/MPC8272 boards Several MPC85xx boards Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-11-09net: Move initialization of Au1x00 SoC ethernet MAC to cpu_eth_initShinya Kuribayashi
This patch will move au1x00_eth_initialize from net/eth.c to cpu_eth_init as a part of ongoing eth_initialize cleanup work. The function ret value is also fixed as it should be negative on fail. Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-11-09Moved initialization of IXP4XX_NPE Ethernet controller to cpu_eth_init()Ben Warren
Also, removed the driver initialization from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-10-18net: Make TFTP server timeout configurableBartlomiej Sieka
There are two aspects of a TFTP transfer involving timeouts: 1. timeout waiting for initial server reply after sending RRQ 2. timeouts while transferring actual data from the server Since the upcoming auto-update feature attempts a TFTP download during each boot, it is undesirable to have a long delay when the TFTP server is not available. Thus, this commit makes the server timeout (1.) configurable by two global variables: TftpRRQTimeoutMSecs TftpRRQTimeoutCountMax TftpRRQTimeoutMSecs overrides default timeout when trying to connect to a TFTP server, TftpRRQTimeoutCountMax overrides default number of connection retries. The total delay when trying to download a file from a non-existing TFTP server is TftpRRQTimeoutMSecs x TftpRRQTimeoutCountMax milliseconds. Timeouts during file transfers (2.) are unaffected. Signed-off-by: Rafal Czubak <rcz@semihalf.com> Signed-off-by: Bartlomiej Sieka <tur@semihalf.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-10-18net: express the first argument to NetSetTimeout() in millisecondsBartlomiej Sieka
Enforce millisecond semantics of the first argument to NetSetTimeout() -- the change is transparent for well-behaving boards (CFG_HZ == 1000 and get_timer() countiing in milliseconds). Rationale for this patch is to enable millisecond granularity for network-related timeouts, which is needed for the upcoming automatic software update feature. Summary of changes: - do not scale the first argument to NetSetTimeout() by CFG_HZ - change timeout values used in the networking code to milliseconds Signed-off-by: Rafal Czubak <rcz@semihalf.com> Signed-off-by: Bartlomiej Sieka <tur@semihalf.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-10-18Adds two more ethernet interface to 83xxrichardretanubun
Added as a convenience for other platforms that uses MPC8360 (has 8 UCC). Six eth interface is chosen because the platform I am using combines UCC1&2 and UCC3&4 as 1000 Eth and the other four UCCs as 10/100 Eth. Signed-off-by: Richard Retanubun <RichardRetanubun@RugggedCom.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Don't tftp to unknown flashJochen Friedrich
If a board has a variable number of flash banks, there are empty entries in flash_info[] and CFG_DIRECT_FLASH_TFTP is set, tftp boot fails with "Outside available Flash". This patch skips flash banks with unknown flash ids. Signed-off-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Moved initialization of EEPRO100 Ethernet controller to board_eth_init()Ben Warren
Affected boards: db64360 db64460 katmai taihu taishan yucca cpc45 cpu87 eXalion elppc debris kvme080 mpc8315erdb integratorap ixdp425 oxc pm826 pm828 pm854 pm856 ppmc7xx sc3 sc520_spunk sorcery tqm8272 tqm85xx utx8245 Removed initialization of the driver from net/eth.c Also, wrapped contents of pci_eth_init() by CONFIG_PCI. Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Moved initialization of TULIP Ethernet controller to board_eth_init()Ben Warren
Affected boards: cu824 bab7xx adciop dasa_sim mousse mpc8540eval musenki mvblue pcippc2/pcippc6 sbc8240 stxssa Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Moved initialization of E1000 Ethernet controller to board_eth_init()Ben Warren
Affected boards: ap1000 mvbc_p PM854 Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Moved initialization of plb2800 Ethernet driver to board_eth_initBen Warren
Affected boards: purple Removed initialization of controller from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Moved initialization of MPC5xxx_FEC Ethernet driver to CPU directoryBen Warren
Modified board_eth_init() functions of boards that have this FEC in addition to other Ethernet controllers. Affected boards: bc3450 icecube mvbc_p o2dnt pm520 total5200 tq5200 Removed initialization of controller from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Moved initialization of MPC512x_FEC Ethernet driver to CPU directoryBen Warren
Added a cpu_eth_init() function to MPC512x CPU directory and removed code from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Moved initialization of IncaIP Ethernet controller to board_eth_initBen Warren
Affected boards: IncaIP Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Moved initialization of 3COM Ethernet controller (AmigaOne) to board_eth_init()Ben Warren
Affected boards: AmigaOneG3SE Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Moved initialization of GT6426x Ethernet controller to board_eth_init()Ben Warren
Affected boards: EVB64260 P3G4 ZUMA Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Moved initialization of PCNET Ethernet controller to board_eth_init()Ben Warren
Affected boards: PN62 sc520_cdp Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Moved initialization of NATSEMI Ethernet controller to board_eth_init()Ben Warren
Affected boards: a3000 Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Moved initialization of NS8382X Ethernet controller to board_eth_init()Ben Warren
Affected boards: bc3450 cpci5200 mecp5200 pf2000 icecube o2dnt pm520 sandpoint8245 total5200 tqm5200 Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Moved initialization of TSI108 Ethernet controller to board_eth_init()Ben Warren
Affected boards: mpc7448hpc2 Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Moved initialization of RTL8139 Ethernet controller to board_eth_init()Ben Warren
Affected boards: hidden_dragon MPC8544DS MPC8610HPCN R2DPLUS TB0229 Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Moved initialization of RTL8169 Ethernet controller to board_eth_init()Ben Warren
Affected boards: linkstation r7780mp Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Moved initialization of Ethernet controllers on Atmel AT91 to board_eth_init()Ben Warren
Removed at91sam9_eth_initialize() from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-31davinci: fix remaining dm644x_ethJean-Christophe PLAGNIOL-VILLARD
2008-08-31ARM DaVinci: Changing function names for EMAC driverSandeep Paulraj
DM644x is just one of a series of DaVinci chips that use the EMAC driver. By replacing all the function names that start with dm644x_* to davinci_* we make these function more portable. I have tested this change on my EVM. DM6467 is another DaVinci SOC which uses the EMAC driver and i will be sending patches that add DaVinci DM6467 support to the list soon. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2008-08-26Fix bogus error message in the DHCP handlerRemy Bohmer
The DHCP handler has 1 state that is not listed in this case, causing a failure message when there is actually no failure. Signed-off-by: Remy Bohmer <linux@bohmer.net> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-26Fix compile error when CONFIG_BOOTP_RANDOM_DELAY is set.Remy Bohmer
The option CONFIG_BOOTP_RANDOM_DELAY does not compile, because of a missing extern inside the net/bootp.h header Signed-off-by: Remy Bohmer <linux@bohmer.net> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-26Moved initialization of SKGE Ethernet driver to board code.Ben Warren
The only board using this driver is the SL8245 board. Removed initialization for the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-26Moved initialization of ULI526X Ethernet driver to board code.Ben Warren
The only board using this driver is the Freescale MPC8610HPCD board. Removed initialization for the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-26Moved initialization of Blackfin EMAC Ethernet controller to board_eth_init()Ben Warren
Added board_eth_init() function to bf537-stamp board. Removed initialization for the Blackin EMAC driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-26Moved initialization of GRETH Ethernet driver to CPU directoryBen Warren
Added a cpu_eth_init() function to leon2/leon3 CPU directories and removed code from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-26Moved initialization of MCFFEC Ethernet driver to CPU directoryBen Warren
Added a cpu_eth_init() function to coldfire CPU directories and removed code from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-26Moved initialization of FSL_MCDMAFEC Ethernet driver to CPU directoryBen Warren
Added a cpu_eth_init() function to cpu/mcf547x_8x directory and removed code from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-07-24Moved initialization of AVR32 Ethernet controllers to board_eth_init()Ben Warren
Renamed initialization functions for atngw100 and atstk1000. Removed initializations for these boards from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-07-15Fix DHCP protocol so U-Boot does not respond too earlyRobin Getz
on the network with it's offered IP number; it should not reply until after it has received a DHCP ACK message. Also ensures that U-Boot does it's DHCPREQUEST as broadcast (per RFC 2131). Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org> Acked-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-07-14Fix printf() format issues with sizeof_t types by using %zuWolfgang Denk
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-07-13Fix some more printf() format issues.Wolfgang Denk
2008-07-13Fix some more printf() format issues.Jean-Christophe PLAGNIOL-VILLARD
2008-07-11Fix some more print() format errors.Wolfgang Denk
2008-07-09Fix printf errors.Andrew Klossner
The compiler will help find mismatches between printf formats and arguments if you let it. This patch adds the necessary attributes to declarations in include/common.h, then begins to correct the resulting compiler warnings. Some of these were bugs, e.g., "$d" instead of "%d" and incorrect arguments. Others were just annoying, like int-long mismatches on a system where both are 32 bits. It's worth fixing the annoying errors to catch the real ones. Signed-off-by: Andrew Klossner <andrew@cesa.opbu.xerox.com>
2008-07-06Add mechanisms for CPU and board-specific Ethernet initializationBen Warren
This patch is the first step in cleaning up net/eth.c, by moving Ethernet initialization to CPU or board-specific code. Initial implementation is only on the Freescale TSEC controller, but others will be added soon. Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-06-08Merge branch 'master' of git://git.denx.de/u-bootBen Warren
2008-06-04Get rid of annoying/superfluous bad-checksum warning messageRemy Bohmer
U-boot can complain a lot about 'checksum bad' when it is attached to the network. It is annoying for ordinary users who start to doubt the network connection in general when they see messages like this. This is caused by the routine NetCksumOk() which cannot handle IP-headers longer than 20 bytes. Those packages can be ignored anyway by U-boot, so we trash them now before checking the checksum. Signed-off-by: Remy Bohmer <linux@bohmer.net> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-05-24Merging Stelian Pop AT91 patchesJean-Christophe PLAGNIOL-VILLARD
Merge branch 'testing-V2' Conflicts: board/atmel/at91cap9adk/Makefile Fixing copyright board/atmel/at91sam9260ek/Makefile Fixing copyright board/atmel/at91sam9260ek/u-boot.lds Delete no more needed ld script Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10AT91SAM9263EK supportStelian Pop
This patch adds support for the AT91SAM9263 chip and the AT91SAM9263EK board. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-04-28net: make ARP timeout configurableGuennadi Liakhovetski
Currently the timeout waiting for an ARP reply is hard set to 5 seconds. On i.MX31ADS due to a hardware "strangeness" up to four first IP packets to the boards get lost, which typically are ARP replies. By configuring the timeout to a lower value we significantly improve the first network transfer time on this board. The timeout is specified in milliseconds, later internally it is converted to deciseconds, because it has to be converted to hardware ticks, and CFG_HZ ranges from 900 to 27000000 on different boards. Signed-off-by: Guennadi Liakhovetski <lg@denx.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-04-13Coding Style cleanup; update CHANGELOGWolfgang Denk
2008-04-08Merge branch 'master' of git://www.denx.de/git/u-boot-at91Wolfgang Denk
