This prints a tftp speed indication after the download completes. This is the
3.6 MiB/s indicator below.
Tegra2 (SeaBoard) # tftp ...
Using asx0 device
TFTP from server 172.22.72.144; our IP address is 172.22.73.81
Filename '/tftpboot/uImage-user-seaboard-1'.
Load address: 0x408000
Loading: ################################################# 3.6 MiB/s
done
BUG=chromium-os:13228
TEST=Boot on Seaboard, make sure message appears. Use 'time tftp ...' to make
sure that speed reported is approximately right.
Change-Id: I5e96e2ef6aa196a6fd8486f2dae0fe11f7464f20
Reviewed-on: http://gerrit.chromium.org/gerrit/225
This defines the basics of a new boot time measurement feature. This allows
logging of very accurate time measurements as the boot proceeds, by using
an available microsecond counter.
To enable the feature, define CONFIG_BOOTSTAGE in your board config file.
Also available is CONFIG_BOOTSTAGE_REPORT which will cause a report to be
printed just before handing off to the OS.
BUG=chromium-os:13875
TEST=build and boot, check that progress is reported before running Linux:
Timer summary in microseconds:
Mark Elapsed Stage
0 0 awake
2,181,078 2,181,078 usb_start
11,861,817 9,680,739 bootp_start
11,884,610 22,793 bootp_stop
11,884,689 79 tftp start
15,271,536 3,386,847 tftp done
15,271,568 32 bootm_start
15,406,551 134,983 start_kernel
Change-Id: I71b89c8402dc5dec75e68333bd24a6bab7500a1b
Reviewed-on: http://gerrit.chromium.org/gerrit/197
At least on ARM the ipaddr is only set in board_init_r function. The
problem is if ipaddr is not defined in environment importing another
environment defined don't update the ipaddr value.
For example, suppose we've a default environment without net variables
defined and we want to import an uEnv.txt environment from SD-card like
this:
ipaddr=192.168.2.240
netmask=255.255.255.0
gatewayip=192.168.2.1
serverip=192.168.2.114
Then if you try boot from NFS results in:
Importing environment from mmc ...
Running uenvcmd ...
smc911x: detected LAN9221 controller
smc911x: phy initialized
smc911x: MAC ac:de:48:00:00:00
*** ERROR: `ipaddr' not set
The ipaddr at this point is NULL beacause is only set at board_init_r
function. This patch updates the ipaddr value if the environment has
changed.
Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it>
Acked-by: Detlev Zundel <dzu@denx.de>
With the upcoming TFTP server implementation, requests can be either
outgoing or incoming, so avoid ambiguities.
With the upcoming TFTP server implementation, the remote node can be
either a client or a server, so avoid ambiguities.
This removes the following checkpatch issue:
- ERROR: do not initialise statics to 0 or NULL
- WARNING: suspect code indent for conditional statements
- ERROR: trailing statements should be on next line
This removes the following checkpatch issues:
- WARNING: braces {} are not necessary for single statement blocks
- WARNING: braces {} are not necessary for any arm of this statement
- ERROR: do not use assignment in if condition.
There is one such error left:
#239: FILE: tftp.c:239:
+ if (!ProhibitMcast
+ && (Bitmap = malloc(Mapsize))
+ && eth_get_dev()->mcast) {
which would require an additional nested if to be fixed, resulting in longer
and less readable code.
- ERROR: "foo * bar" should be "foo *bar"
- ERROR: "(foo*)" should be "(foo *)"
- ERROR: space prohibited before that close parenthesis ')'
- ERROR: space required after that ';' (ctx:BxV)
- ERROR: space required after that ',' (ctx:VxV)
- ERROR: space required after that ';' (ctx:VxV)
- ERROR: spaces required around that '<<=' (ctx:VxV)
- ERROR: spaces required around that '<' (ctx:VxV)
- ERROR: spaces required around that '=' (ctx:VxV)
- ERROR: spaces required around that '+=' (ctx:VxV)
- ERROR: spaces required around that '=' (ctx:VxW)
- WARNING: please, no spaces at the start of a line
- WARNING: space prohibited between function name and open parenthesis '('
Cc: Ben Warren <biggerbadderben@gmail.com>
- ERROR: switch and case should be at the same indent
- WARNING: labels should not be indented
- ERROR: return is not a function, parentheses are not required
- ERROR: space prohibited after that open parenthesis '('
- ERROR: space prohibited after that open square bracket '['
- ERROR: space prohibited after that '&' (ctx:WxW)
- ERROR: space required before the open parenthesis '('
- ERROR: need consistent spacing around '+' (ctx:WxV)
- WARNING: unnecessary whitespace before a quoted newline
parenthesis '('
Cc: Mike Frysinger <vapier@gentoo.org>
This removes the following checkpatch errors:
- ERROR: do not initialise globals to 0 or NULL
- ERROR: that open brace { should be on the previous line
This removes the following checkpatch warning:
- WARNING: line over 80 characters
There are three such warnings left.
The first is hard to fix with cosmetic-only changes without compromising code
readability, so I'm leaving it as it is for now:
#1537: FILE: net.c:1537:
+ [4 tabs] memcpy(((Ethernet_t *)NetArpWaitTxPacket)->et_dest, ...
The other two cannot be fixed without splitting string literals, so it is
preferred to keep them longer than 80 characters.
This is needed for the upcoming TFTP server implementation.
This also simplifies PingHandler() and fixes rxhand_f documentation.
Netconsole use the environment variable `ncip' to configure the
destination IP. `serverip' don't need to be defined.
Signed-off-by: Simon Guinot <sguinot@lacie.com>
If neither CONFIG_CMD_PING or CONFIG_CMD_SNTP are defined but
CONFIG_CMD_DNS is, a compile-time error will occur due to the
absence of a goto label.
Signed-off-by: Gray Remlin <gryrmln@gmail.com>
Extends the mii_dev structure to participate in a full-blown MDIO and
PHY driver scheme. The mii_dev structure and miiphy calls are modified
in such a way to allow the original mii command and miiphy
infrastructure to work as before, but also to support a new set of APIs
which allow (among other things) sharing of PHY driver code and 10G support
The mii command will continue to support normal PHY management functions
(Clause 22 of 802.3), but will not be changed to support 10G
(Clause 45).
The basic design is similar to PHY Lib from Linux, but simplified for
U-Boot's network and driver infrastructure.
We now have MDIO drivers and PHY drivers
An MDIO driver provides:
read
write
reset
A PHY driver provides:
(optionally): probe
config - initial setup, starting of auto-negotiation
startup - waiting for AN, and reading link state
shutdown - any cleanup needed
The ethernet drivers interact with the PHY Lib using these functions:
phy_connect()
phy_config()
phy_startup()
phy_shutdown()
Each PHY driver can be configured separately, or all at once using
config_phylib_all_drivers.h (added in the patch which adds the drivers)
We also provide generic drivers for Clause 22 (10/100/1000), and
Clause 45 (10G) PHYs.
We also implement phy_reset(), and call it in phy_connect(). Because
phy_reset() is essentially the same as miiphy_reset, but:
a) must support 10G PHYs, and
b) should use the phylib primitives,
we implement miiphy_reset, using phy_reset(), but only when
CONFIG_PHYLIB is set. Otherwise, we just use the old version. In this
way, we save on compile size, even if we don't manage to save code size.
Pulled ethtool.h and mdio.h from:
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6
782d640afd15af7a1faf01cfe566ca4ac511319d
With many, many deletions so as to enable compilation under u-boot
Signed-off-by: Andy Fleming <afleming@freescale.com>
This seems to pad to one byte longer than required
Signed-off-by: Remy Bohmer <linux@bohmer.net>
This adds support for using USB Ethernet dongles in host mode. This is just
the framework - drivers will come later. A new config option called
CONFIG_USB_HOST_ETHER can be defined in board config files to switch this
on.
The was originally written by NVIDIA and was cleaned up for release by the
Chromium authors.
Before this commit, weak symbols were not overridden by non-weak symbols
found in archive libraries when linking with recent versions of
binutils. As stated in the System V ABI, "the link editor does not
extract archive members to resolve undefined weak symbols".
This commit changes all Makefiles to use partial linking (ld -r) instead
of creating library archives, which forces all symbols to participate in
linking, allowing non-weak symbols to override weak symbols as intended.
This approach is also used by Linux, from which the gmake function
cmd_link_o_target (defined in config.mk and used in all Makefiles) is
inspired.
The name of each former library archive is preserved except for
extensions which change from ".a" to ".o". This commit updates
references accordingly where needed, in particular in some linker
scripts.
This commit reveals board configurations that exclude some features but
include source files that depend these disabled features in the build,
resulting in undefined symbols. Known such cases include:
- disabling CMD_NET but not CMD_NFS;
- enabling CONFIG_OF_LIBFDT but not CONFIG_QE.
Signed-off-by: Sebastien Carlier <sebastien.carlier@gmail.com>
This has always been confusing, and the idea of these functions returning the
number of interfaces initialized was half-baked and ultimately pointless.
Instead, act more like regular functions and return < 0 on failure, >= 0 on
success.
This change shouldn't break anything.
Can't get IP address with dhcp due to the dhcp server not
allow the empty param list request under some network env
This patch is based on Gray Remlin's initial patch.
Signed-off-by: Jason Liu <r64343@freescale.com>
Signed-off-by: Gray Remlin <g_remlin@rocketmail.com>
Most people don't use the 'rarpboot' command, so only enable it when
CONFIG_CMD_RARP is defined.
All are within an #ifdef CONFIG_NET_MULTI block already
Commit 6e37b1a3a25004d3df5867de49fff6b3fc9c4f04 modifies several net calls
to take a (const char *) parameter instead of (char *), but in some cases
the modified functions call other functions taking (char *). The end result
is warnings about discarding the const qualifier.
This patch fixes these other function signatures.
Some commands operate on eth device names (like 'mii'), but those cannot
be passed on the command line as one argument. So detect devices like
these and warn about them so someone will fix it.
Move it inside the #ifdef CONFIG_NET_MULTI to avoid
eth.c:64: warning: 'eth_mac_skip' defined but not used
messages from a number of old, non-CONFIG_NET_MULTI boards.
TFTP'ing a file of size 1747851 bytes with CONFIG_IP_DEFRAG and
CONFIG_TFTP_BLOCKSIZE set to 4096 fails with a timeout, because
the last fragment is not taken into account. This patch fixes
IP fragments having less than 8 bytes of payload.
Signed-off-by: Stephane Fillod <stephane.fillod@grassvalley.com>
Acked-by: Alessandro Rubini <rubini@gnudd.com>
Add a new function to the eth_device struct for programming a network
controller's hardware address.
After all network devices have been initialized and the proper MAC address
for each has been determined, make a device driver call to program the
address into the device. Only device instances with valid unicast addresses
will be programmed.
Tested-by: Prafulla Wadaskar <prafulla@marvell.com>
Tested-by: Heiko Schocher <hs@denx.de>
Tested-by: Thomas Chou <thomas@wytron.com.tw>
For some reason, (which I can't find any documentation on), if U-Boot
gives a port number higher than 17500 to a Microsoft DNS server, the
server will reply to port 17500, and U-Boot will ignore things (since
that isn't the port it asked the DNS server to reply to).
This fixes that by ensuring the random port number is less than 17500.
Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org>
Signed-off-by: Detlev Zundel <dzu@denx.de>
So far, TFTP negotiated a fixed retransmission timeout of 5 seconds.
In some cases (busy networks, slow TFTP servers) this caused very
slow transfers. A new environment variable "tftptimeout" allows to
set this timeout. Lowering this value may make downloads succeed
faster in networks with high packet loss rates or with unreliable
TFTP servers.
There are boards out there that do not have network support in
U-Boot (CONFIG_CMD_NET not set), but they do so in Linux. This
makes it desirable to be able to port network configuration (like
the IP address) to the Linux kernel.
We should not make the passing of the IP configuration to Linux
dependent on U-Boot features / settings.
For this, make getenv_IPaddr() global. This fixes build error
u-boot/lib_xxx/board.c:360: undefined reference to `getenv_IPaddr'
on various architectures.
Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
Acked-by: Ben Warren <biggerbadderben@gmail.com>
- NfsTimeout() does not correctly update the NFS timeout value which
results in NfsTimeout() only being called once in certain situations.
This can result in the 'nfs' command hanging indefinetly. For
example, the command:
nfs 192.168.0.1:/home/user/file
will not exit until ctrl-c is pressed if 192.168.0.1 does not have an
NFS server running.
This issue is resolved by reinitializting the NFS timeout value inside
NfsTimeout() when a timeout occurs.
- Make the 'nfs' command print the 'T' character when a timeout occurs.
Previously there was no indication that timeouts were occuring.
- Mimic the 'tftpboot' command and when a download fails print "Retry
count exceeded; starting again", and restart the download taking the
'netretry' environment variable into account.
Signed-off-by: Evan Samanas <esamanas@xes-inc.com>
Tested on TQM8xxL.
Tested by: Wolfgang Denk <wd@denx.de>
Tested on MPC8527DS.
Tested by: Ed Swarthout <Ed.Swarthout@freescale.com>
