Make a thorough pass through all variables and function names contained
within tftp and remove CamelCase and improve naming.
Update the naming convention used in the network stack functions and
variables that Ethernet drivers use to interact with it.
This cleans up the temporary hacks that were added to this interface
along with the DM support.
This patch has a few remaining checkpatch.pl failures that would be out
of the scope of this patch to fix (drivers that are in gross violation
of checkpatch.pl).
This patch cleans up the names of internal packet buffer names that are
used within the network stack and the functions that use them.
Use "_ethaddr" at the end of variables and drop CamelCase.
Make constant values actually 'const'.
Remove CamelCase variable naming.
Move the definition to the same compilation unit as the primary use.
The variables around the bootfile were inconsistent and used CamelCase.
Update them to make the code more readable.
This patch is simply clean-up to make the IPv4 type that is used match
what Linux uses. It also attempts to move all variables that are IP
addresses use good naming instead of CamelCase. No functional change.
Some drivers need a chance to manage their receive buffers after the
packet has been handled by the network stack. Add an operation that
will allow the driver to be called in that case.
Reported-by: Simon Glass <sjg@chromium.org>
Tested-on: pcduino3
Take a pass at plumbing errors through to the users of the network stack
Currently only the start() function errors will be returned from
NetLoop(). recv() tends not to have errors, so that is likely not worth
adding. send() certainly can return errors, but this patch does not
attempt to plumb them yet. halt() is not expected to error.
The ethprime env var is used to indicate the starting device if none is
specified in ethact. Also support aliases specified in the ethprime var.
Allow network devices to be referred to as "eth0" instead of
"eth@12345678" when specified in ethact.
Add tests to verify this behavior.
Stop forcing drivers to call net_process_received_packet() - formerly
called NetReceive(). Now the uclass will handle calling the driver for
each packet until the driver errors or has nothing to return. The uclass
will then pass the good packets off to the network stack by calling
net_process_received_packet().
Take the opportunity to enforce better names on newly written or
retrofitted Ethernet drivers.
First just add support for MAC drivers.
Previously the net functions would access memory assuming physmem did
not need to be mapped. In sandbox, that's not the case.
Now we map the physmem specified by the user in loadaddr to the buffer
that represents that space.
netretry previously would only retry in one specific case (your MAC
address is not set) and no other. This is basically useless. In the DM
implementation for eth it turns this into a completely useless case
since an un-configured MAC address results in not even entering the
NetLoop. The behavior is now changed to retry any failed command
(rotating through the eth adapters if ethrotate != no).
It also defaulted to retry forever. It is now changed to default to not
retry
This value is not used by the network stack and is available in the
global data, so stop passing it around. For the one legacy function
that still expects it (init op on old Ethernet drivers) pass in the
global pointer version directly to avoid changing that interface.
(Trival fix to remove an unneeded variable declaration in 4xx_enet.c)
On some archs masking the parameter is inefficient, so don't use u8.
Many functions returned -1 previously. Change them to return appropriate error
codes.
Move some things around and organize things so that the driver model
implementation will fit in more easily.
Make it clear that the helper is checking the addr, not setting it.
The current implementation exposes the eth_device struct to code that
needs to access the MAC address. Add a wrapper function for this to
abstract away the pointer for this operation.
Drop the old checksum functions in favour of the new ones.
Move the checksum code out into its own file so it can be used elsewhere.
Also use a new version which supports a length which is not a multiple of
2 and add a new function to add two checksums.
Currenly when CONFIG_BOOTP_SERVERIP is defined, the SERVERIP is not changed
when receive the BOOTP packet. But BOOTFILE is changed via BOOTP packet.
As we will load the BOOTFILE from SERVERIP, if the BOOTFILE is modified
by bootp packet but SERVERIP is not, that is not make sense.
This patch make SERVERIP and BOOTFILE be consistent. If we define the
CONFIG_BOOTP_SERVERIP, then SERVERIP and BOOTFILE will not changed by
BOOTP packet. Only IP address is changed.
Signed-off-by: Josh Wu <josh.wu@atmel.com>
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
If we know the file size, display it after loading the file.
A number of network related files were imported from the LiMon
project; these contain a somewhat unclear license statement:
Copyright 1994 - 2000 Neil Russell.
(See License)
I analyzed the source code of LiMon v1.4.2 which was used for this
import. It does not contain any "License" file, but the top level
directory contains a file "COPYING", which turns out to be GPL v2
of June 1991. So it is legitimate to conclude that the LiMon derived
files are also to be released under GPLv2. Mark them as such.
This would be useful to start moving various config options.
When a DNS query is sent out, the ethernet packet can get directed to
the MAC address of a server that was communicated to before. This is
wrong when the previously stored MAC address corresponds to a different
server's IP address, i.e. when the IP address of the previous and the
current communication are different.
The error can get reproduced by running a sequence of e.g. a TFTP
download and a DNS query, where the TFTP and DNS servers reside on
individual machines.
The fix is to clear the server's MAC address that might be left from a
previous operation, and to fetch the peer's MAC address in a new ARP
lookup, before the DNS query is sent. This is the approach taken in
other network services, like 8e52533d1095 ("net: tftpsrv: Get correct
client MAC address").
Reported-by: Dirk Zimoch <dirk.zimoch@psi.ch>
Signed-off-by: Gerhard Sittig <gsi@denx.de>
It's not unusual for DHCP servers to take a couple hundred milliseconds
to respond to DHCP discover messages. One possible reason for the delay
can be that the server checks (typically using an ARP request) that the
IP it's about to hand out isn't in use yet. To make matters worse, some
servers may also queue up requests and process them sequentially, which
can cause excessively long delays if clients retry too fast.
Commit f59be6e850b3 ("net: BOOTP retry timeout improvements") shortened
the retry timeouts significantly, but the BOOTP/DHCP implementation in
U-Boot doesn't handle that well because it will ignore incoming replies
to earlier requests. In one particular setup this increases the time it
takes to obtain a DHCP lease from 630 ms to 8313 ms.
This commit attempts to fix this in two ways. First it increases the
initial retry timeout from 10 ms to 250 ms to give DHCP servers some
more time to respond. At the same time a cache of outstanding DHCP
request IDs is kept so that the implementation will know to continue
transactions even after a retransmission of the DISCOVER message. The
maximum retry timeout is also increased from 1 second to 2 seconds. An
ID cache of size 4 will keep DHCP requests around for 8 seconds (once
the maximum retry timeout has been reached) before dropping them. This
should give servers plenty of time to respond. If it ever turns out
that this isn't enough, the size of the cache can easily be increased.
With this commit the DHCP lease on the above-mentioned setup still takes
longer (1230 ms) than originally, but that's an acceptable compromise to
improve DHCP lease acquisition time for a broader range of setups.
To make it easier to benchmark DHCP in the future, this commit also adds
the time it took to obtain a lease to the final "DHCP client bound to
address x.x.x.x" message.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Currently, the BOOTP code sends out its initial request as soon as the
Ethernet driver indicates "link up". If this packet is lost or not
replied to for some reason, the code waits for a 1s timeout before
retrying. For some reason, such early packets are often lost on my
system, so this causes an annoying delay.
To optimize this, modify the BOOTP code to have very short timeouts for
the first packet transmitted, but gradually increase the timeout each
time a timeout occurs. This way, if the first packet is lost, the second
packet is transmitted quite quickly and hence the overall delay is low.
However, if there's still no response, we don't keep spewing out packets
at an insane speed.
It's arguably more correct to try and find out why the first packet is
lost. However, it seems to disappear inside my Ethenet chip; the TX chip
indicates no error during TX (not that it has much in the way of
reporting...), yet wireshark on the RX side doesn't see any packet.
FWIW, I'm using an ASIX USB Ethernet adapter. Perhaps "link up" is
reported too early or based on the wrong condition in HW, and we should
add some fixed extra delay into the driver. However, this would slow down
every link up event even if it ends up not being needed in some cases.
Having BOOTP retry quickly applies the fix/WAR to every possible
Ethernet device, and is quite simple to implement, so seems a better
solution.
Improve error messages in case of invalid/unset ethernet addresses.
Signed-off-by: Pavel Machek <pavel@denx.de>
Cleanup bootp code by using mdelay.
SPL stage does not support various networking things, and therefore
CONFIG_NETCONSOLE cannot be built within SPL.
Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
Some functions in include/net.h are ported from
include/linux/etherdevice.h of Linux Kernel.
For ex.
is_zero_ether_addr()
is_multicast_ether_addr()
is_broadcast_ether_addr()
is_valid_ether_addr();
So, we should use the same function name as that of Linux Kernel,
eth_rand_addr(), for consistency.
Besides, eth_rand_addr() has been implemented as an inline function.
So it should not be surrounded by #ifdef CONFIG_RANDOM_MACADDR.
Changes in lib/uuid.c to:
- uuid_str_to_bin()
- uuid_bin_to_str()
New parameter is added to specify input/output string format in listed functions
This change allows easy recognize which UUID type is or should be stored in given
string array. Binary data of UUID and GUID is always stored in big endian, only
string representations are different as follows.
String byte: 0 36
String char: xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
string UUID: be be be be be
string GUID: le le le be be
This patch also updates functions calls and declarations in a whole code.
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
Cc: Stephen Warren <swarren@nvidia.com>
Cc: Lukasz Majewski <l.majewski@samsung.com>
Cc: trini@ti.com
Now we are ready to switch over to real Kbuild.
This commit disables temporary scripts:
scripts/{Makefile.build.tmp, Makefile.host.tmp}
and enables real Kbuild scripts:
scripts/{Makefile.build,Makefile.host,Makefile.lib}.
This switch is triggered by the line in scripts/Kbuild.include
-build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build.tmp obj
+build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build obj
We need to adjust some build scripts for U-Boot.
But smaller amount of modification is preferable.
Additionally, we need to fix compiler flags which are
locally added or removed.
In Kbuild, it is not allowed to change CFLAGS locally.
Instead, ccflags-y, asflags-y, cppflags-y,
CFLAGS_$(basetarget).o, CFLAGS_REMOVE_$(basetarget).o
are prepared for that purpose.
Tested-by: Gerhard Sittig <gsi@denx.de>
In "common/Makefile" "miiphyutil.o" gets built if any of the following
items enabled:
* CONFIG_PHYLIB
* CONFIG_MII
* CONFIG_CMD_MII
So it's possible to not define CONFIG_MII or CONFIG_CMD_MII and still
use functions like "miiphy_get_dev_by_name".
In its turn "miiphy_get_dev_by_name" traverses "mii_devs" list which is
not initialized because "miiphy_init" never got called.
Cc: Rob Herring <rob.herring@calxeda.com>
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
NetServerEther was not being cleared in the tftp server code, so the
destination MAC address would be whatever the last destination MAC
address was.
Scenario:
U-Boot:
dhcp
tftpsrv
Host:
Send device WRQ
Device:
Responds with ACK to dhcp server mac address with
host ip address
By clearing NetServerEther, we force a lookup of the host MAC address
to go with the associated host IP.
Signed-off-by: Andrew Ruder <andrew.ruder@elecsyscorp.com>
When the block 0 store to the memory of client and timeout at this
moment. Because of no ACK packet, the server will send block 0 again,
if this client reconnect to the server at this time,
TftpBlockWrapOffset will become larger than it should be.
Signed-off-by: Rockly <rocklygnome@gmail.com>
Patch: 264417
This flag is to make console aware that NET transfer is running or not.
Signed-off-by: Jim Lin <jilin@nvidia.com>
[trini: Fixup common/cmd_io.c]
Make the link-local code conform more completely with the RFC.
This will prevent ARP queries for the target (such as while it is
rebooting) from causing the device to choose a different link-local
address, thinking that its address is in use by another machine.
tftp.c:464:17: warning: cast to restricted __be16
tftp.c:552:29: warning: cast to restricted __be16
tftp.c:640:33: warning: cast to restricted __be16
tftp.c:642:25: warning: cast to restricted __be16
Cc: Joe Hershberger <joe.hershberger@gmail.com>
This patch tackles the time out problem which leads to break the
boot process, when loading file over nfs. The patch does two things.
First of all, we just ignore messages that arrive with a rpc_id smaller
then the client id. We just interpret this messages as answers to
formaly timed out messages.
Second, when a time out occurs we double the time to wait, so that we
do not stress the server resending the last message.
Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
Tested-by: Enric Balletbo i Serra <eballetbo@gmail.com>
If we try to boot from NET device, NetInitLoop in net.c will be invoked.
If NET device is not installed, eth_get_dev() function will return
eth_current value, which is NULL.
When NetInitLoop is called, "eth_get_dev->enetaddr" will access
restricted memory area and therefore cause hanging.
This issue is found on Tegra30 Cardhu platform after adding
CONFIG_CMD_NET and CONFIG_CMD_DHCP in config header file.
Use setenv_ulong(), setenv_hex() and setenv_addr() in net/
The ip is stored in network order, so we can't test it in host order.
Reviewed-by: Kim Phillips <kim.phillips@freescale.com>
